[RECOVERY XT910] Safestrap Recovery v3.7x [04/14/2014 V3.72 - TWRP 2.7.0.0]
safestrap recovery
9 replies to this topic
#1 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
  • Twitter:Hashcode0f
Posted 14 October 2012 - 09:46 PM
SAFESTRAP v3.72 (2nd-System Bootstrap / Recovery) for XT910 UMTS_Spyder
** INSERT STANDARD DISCLAIMER: I'm not responsible for any damage you do to your phone using my tools. Always have a fastboot available for disaster recovery. **
Download the APK Installer:
Mirror 1:
Mirror 2:
md5sum: 15040f51ff9a6ad92bfbd288058c1d5e
FOLLOW THESE INSTRUCTIONS:
[ DOUBLE-CHECK you have the "UMTS_Spyder" version ]
This is NOT BMM. I don't support the same features that BMM does. 2 different recoveries that work on the RAZR, use which ever you like.
NOTABLE TWRP-BASE CHANGES:
  • Key/button vibration in recovery and MANY more 2.7.0.0 updates
  • Screen saving in recovery. Can set the timeout under Advanced->Settings->Screen *Don't freak out of the screen is dark, try the power button.
  • SElinux support in recovery
  • and much much more.. check the TWRP changelog here:
DEVICE SPECIFIC SAFESTRAP CHANGES:
  • [04/14] (3.72) Mostly other device updates
  • [01/15] (3.71) Code cleanup
  • [01/15] (3.71) Minor hijack updates
  • [12/18] (3.70) Mount cleanup during hijack / debugging output
  • [12/18] (3.70) Splashscreen: Instant stock boot key (needs to be set for Moto OMAP4's still)
  • [11/13] (3.65) recovery init.rc cleanup
  • [11/13] (3.65) fix updater build for cm 10.1 and 10.2
  • [09/20] (3.60) Better handling for virtual images > 2gb
  • [09/20] (3.60) Much improved block device handling
  • [09/20] (3.60) Bugfix in script translation
  • [09/20] (3.60) hijack / init.rc tweaks
  • [09/20] (3.60) update to TWRP 2.6.3.0 base recovery
  • [09/06] (3.53) Fixed mass_storage in recovery (via Mount menu)
  • [09/06] (3.53) Added Webtop to partition backup list (optional)
  • [09/06] (3.53) New virtual systems created will be 640mb (got reset 600mb)
  • [09/06] (3.53) Fixed file selector when changing from internal to external storage (previously location wouldn't update)
  • [09/05] (3.52) added "Reboot to Recovery" in APK
  • [09/04] (3.51) Disabled screen blank while creating a rom-slot
  • [09/04] (3.51) Fixed openrecovery script processing for stock slot to re-inject hijack after .zip install (cmupdater on stock now works)
  • [08/30] (3.50) If running a new CM10.1/CM10.2 ROM (08/30 or later) you *should* be able to install Safestrap and update the recovery w/o having to go back to stock. If Safestrap shows "recovery not installed" while you're on a ROM-slot, then that ROM hasn't been updated and it won't work. Swap back to stock ROM and update Safestrap from there.
  • [08/30] (3.50) Worked on stock ROM flashing and *should* work with CM10.1/CM10.2 builds on or after 08/30 *WILL NOT WORK WITH OLDER ROMs.*
  • [08/30] (3.50) Battery meter is back
  • [08/30] (3.50) Updated TWRP theme
  • [08/30] (3.50) Added partition sizes to ROM-slot screen when it's ACTIVE
  • [08/30] (3.50) Added "Check FS" function to ROM-slot screen when it's ACTIVE
  • [08/30] (3.50) Complete re-write against TWRP 2.6 base (up from version 2.2.2.1):
  • [12/29] (3.11) Allow use of custom updater-binary in .zip files for flashing on stock ROM (virtual slots still use prebuilt updater-binary in recovery).
  • [12/29] (3.11) BUGFIX: Fixed fake flash error at the end of a .zip install. (No real error, .zip installs fine)
  • [12/29] (3.10) Early support for booting custom ROMs on stock partitions. (Custom ROMs will need to be worked out for XT912 on JB4.1 still)
  • [12/29] (3.10) Enable flashing to stock ROM
    • After .zip installations, nandroid restore or system wipe on the stock ROM: the current Safestrap files are restored to the system partition (Doesn't include the APK in /data -- so if you're restoring an old backup, be sure to update the Safestrap APK)
    • During the Safestrap files restore a check is done to be sure there are minimal files on /system to re-enter Safestrap
  • [12/29] (3.10) New virtual system partitions will be 640mb (closer match to stock RAZR/D4)
  • [12/27] (3.07) Bugfix: missed some changes in Safestrap 3.06
  • [12/26] (3.06) Bugfix/Update for JB4.1 OTA for DroidRAZR (Non-JB devices can also use)
  • [10/17] (3.05) Fixed SD card / emmc sharing in recovery (UMS)
  • [10/17] (3.05) Fixed recovery installation/removal from ROM-slots
  • [10/14] Updated to v3.04 BETA.
  • [10/14] Recovery is now based off TWRP 2.2.2.1 (fully featured touch-based recovery)
  • [10/14] Can create up to 4 Virtual ROM-slots to flash ROMs to and when "Active" ALL TWRP functions affect that ROM-slot (For example: Flashing .zips, Backup and Restore)
  • [10/14] Nearly instant swapping from ROM to ROM
  • [10/14] User selectable data partition sizes during ROM slot creation: 1GB, 2GB or 3GB
  • [10/14] ROM slots are saved on the internal emmc space so that preinstall and webtop partitions are no longer used and shouldn't break OTAs.
  • [10/14] Charging in recovery
  • [10/14] Supports "Reboot Recovery" from Android OS
Entry to recovery via Splashscreen on boot-up. The screen stays up for around 8-10 seconds and if you hit the menu button, it takes you to Safestrap Recovery.
SPECIAL THANKS TO:
  • The entire TWRP team who has built an AMAZING recovery system.
  • The testers which have helped in past and present versions of Safestrap, knowing that it could mean they brick their devices.
As always, let me know what you think!
  • lownslow200sx, halfbosss and Bologna like this
#2 Alex.Abraham
Alex.Abraham
  • 477 posts
  • Twitter:aabraham123456
  • LocationNew Jersey
Posted 14 October 2012 - 09:53 PM
Awesome hash I just saw your tweet!!!
So happy to see your still alive and posting on DroidRZR.com!!!!! Keep up the good work and honestly I think once this thing goes out of beta you should take a break for a few weeks. Maybe even go on a vacation with the family :lol:
#3 Bologna
Bologna
  • 163 posts
  • Twitter:@Bolognasez
  • Google+:bolowneeez@gmail.com
  • LocationGulf of Mexico
Posted 15 October 2012 - 03:46 AM
I just went back to stock so I can run a clean install with this. I AM AMPED!!!!
#4 halfbosss
halfbosss
Posted 04 November 2012 - 05:17 AM
hi hascode it's possible to install the rom on external sd card? i explain i don't have any free space on my razr to make another partition fo install a third rom it's possible to put him on the external sd card? thanks for the replies and sorry for my bad english but i'm italian :D
#5 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
Posted 04 September 2013 - 02:52 PM
Updated the OP for new Safestrap 3.51.
It's VERY Work-In-Progress.
Enjoy
#6 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
Posted 06 September 2013 - 11:29 PM
Updated the OP for a new Safestrap 3.53:
md5sum:4c57443d8fcfa392c0e730cde450b111
SAFESTRAP CHANGES:
#7 areavip
areavip
  • LocationBrazil
  • Current Device(s):XT912
Posted 12 November 2013 - 08:32 PM
can you please update the link to the SS APK for the UMTS_SPYDER.
#8 robocuff
robocuff
  • 415 posts
Posted 05 December 2013 - 04:16 PM
#9 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
Posted 14 April 2014 - 09:14 PM
Updated OP for Safestrap v3.72
Enjoy
  • livinginkaos and RikRong like this
#10 livinginkaos
Posted 15 April 2014 - 03:11 AM
Hash, you are amazing.
Sent from my S-Offed One M8
Also tagged with one or more of these keywords: safestrap recovery
