[RECOVERY] Safestrap Recovery v3.7x [05/15/2014 V3.73 - TWRP 2.7.0.0]
safestrap recovery
191 replies to this topic
#1 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
  • Twitter:Hashcode0f
Posted 14 October 2012 - 09:27 PM
SAFESTRAP v3.73 (2nd-System Bootstrap / Recovery)
** INSERT STANDARD DISCLAIMER: I'm not responsible for any damage you do to your phone using my tools. Always have a fastboot available for disaster recovery. **
Download the APK Installer:
Mirror 1:
Mirror 2:
FOLLOW THESE INSTRUCTIONS:
[ DOUBLE-CHECK you have the "Targa" version ]
NOTABLE TWRP-BASE CHANGES:
  • Key/button vibration in recovery and MANY more 2.7.0.0 updates
  • Screen saving in recovery. Can set the timeout under Advanced->Settings->Screen *Don't freak out of the screen is dark, try the power button.
  • SElinux support in recovery (1st boot won't take so long)
  • and much much more.. check the TWRP changelog here:
DEVICE SPECIFIC SAFESTRAP CHANGES:
  • [05/15] (3.73) Bugfix for dual SD card UMS mounting and pull in TWRP changes
  • [04/14] (3.72) Mostly other device updates
  • [01/15] (3.71) Code cleanup
  • [01/15] (3.71) Minor hijack updates
  • [12/18] (3.70) Mount cleanup during hijack / debugging output
  • [12/18] (3.70) Splashscreen: Instant stock boot key (needs to be set for Moto OMAP4's still)
  • [11/13] (3.65) recovery init.rc cleanup
  • [11/13] (3.65) fix updater build for cm 10.1 and 10.2
  • [09/20] (3.60) Better handling for virtual images > 2gb
  • [09/20] (3.60) Much improved block device handling
  • [09/20] (3.60) Bugfix in script translation
  • [09/20] (3.60) hijack / init.rc tweaks
  • [09/20] (3.60) update to TWRP 2.6.3.0 base recovery
  • [09/06] (3.53) Fixed mass_storage in recovery (via Mount menu)
  • [09/06] (3.53) Added Webtop to partition backup list (optional)
  • [09/06] (3.53) New virtual systems created will be 640mb (got reset 600mb)
  • [09/06] (3.53) Fixed file selector when changing from internal to external storage (previously location wouldn't update)
  • [09/05] (3.52) added "Reboot to Recovery" in APK
  • [09/04] (3.51) Disabled screen blank while creating a rom-slot
  • [09/04] (3.51) Fixed openrecovery script processing for stock slot to re-inject hijack after .zip install (cmupdater on stock now works)
  • [08/30] (3.50) If running a new CM10.1/CM10.2 ROM (08/30 or later) you *should* be able to install Safestrap and update the recovery w/o having to go back to stock. If Safestrap shows "recovery not installed" while you're on a ROM-slot, then that ROM hasn't been updated and it won't work. Swap back to stock ROM and update Safestrap from there.
  • [08/30] (3.50) Worked on stock ROM flashing and *should* work with CM10.1/CM10.2 builds on or after 08/30 *WILL NOT WORK WITH OLDER ROMs.*
  • [08/30] (3.50) Battery meter is back
  • [08/30] (3.50) Updated TWRP theme
  • [08/30] (3.50) Added partition sizes to ROM-slot screen when it's ACTIVE
  • [08/30] (3.50) Added "Check FS" function to ROM-slot screen when it's ACTIVE
  • [08/30] (3.50) Complete re-write against TWRP 2.6 base (up from version 2.2.2.1):
  • [12/29] (3.11) Allow use of custom updater-binary in .zip files for flashing on stock ROM (virtual slots still use prebuilt updater-binary in recovery).
  • [12/29] (3.11) BUGFIX: Fixed fake flash error at the end of a .zip install. (No real error, .zip installs fine)
  • [12/29] (3.10) Early support for booting custom ROMs on stock partitions.
  • [12/29] (3.10) Enable flashing to stock ROM *BE CAREFUL -- NEW FEATURE -- STILL TESTING*
    • After .zip installations, nandroid restore or system wipe on the stock ROM: the current Safestrap files are restored to the system partition (Doesn't include the APK in /data -- so if you're restoring an old backup, be sure to update the Safestrap APK)
    • During the Safestrap files restore a check is done to be sure there are minimal files on /system to re-enter Safestrap
  • [12/29] (3.10) New virtual system partitions will be 640mb (closer match to stock RAZR/D4)
  • [12/27] (3.07) Bugfix: missed some changes in Safestrap 3.06
  • [12/26] (3.06) Bugfix/Update for JB4.1 OTA for DroidRAZR (Non-JB devices can also use)
  • [10/17] (3.05) Fixed SD card / emmc sharing in recovery (UMS)
  • [10/17] (3.05) Fixed recovery installation/removal from ROM-slots
  • [10/14] Updated to v3.04 BETA.
  • [10/14] Recovery is now based off TWRP 2.2.2.1 (fully featured touch-based recovery)
  • [10/14] Can create up to 4 Virtual ROM-slots to flash ROMs to and when "Active" ALL TWRP functions affect that ROM-slot (For example: Flashing .zips, Backup and Restore)
  • [10/14] Nearly instant swapping from ROM to ROM
  • [10/14] User selectable data partition sizes during ROM slot creation: 1GB, 2GB or 3GB
  • [10/14] ROM slots are saved on the internal emmc space so that preinstall and webtop partitions are no longer used and shouldn't break OTAs.
  • [10/14] Charging in recovery
  • [10/14] Supports "Reboot Recovery" from Android OS
Entry to recovery via Splashscreen on boot-up. The screen stays up for around 8-10 seconds and if you hit the menu button, it takes you to Safestrap Recovery.
SPECIAL THANKS TO:
  • The entire TWRP team who has built an AMAZING recovery system.
  • The testers which have helped in past and present versions of Safestrap, knowing that it could mean they brick their devices.
As always, let me know what you think!
  • mhous33, chiahead52, dshu and 11 others like this
#2 dman1049
dman1049
  • 94 posts
Posted 14 October 2012 - 09:35 PM
This is sick. Not sure if I want to flash now or to wait for it to not be in beta.
#3 YouthD
YouthD
  • 31 posts
  • Twitter:YouthD
Posted 14 October 2012 - 09:42 PM
Been wating for SOO long! I love TWRP! Thank you so much!
#4 raw57
raw57
  • 37 posts
Posted 14 October 2012 - 09:49 PM
Sweet! Works beautifully.
#5 mhous33
mhous33
  • 480 posts
Posted 14 October 2012 - 10:43 PM
awesome, totally awesome!
  • hadeshorn9 likes this
#6 Bulldog88
Bulldog88
  • 93 posts
Posted 14 October 2012 - 10:51 PM
Agree with you mhous33 totally awesome
#7 dman1049
dman1049
  • 94 posts
Posted 14 October 2012 - 10:56 PM
Did something wrong... fxzing and rerooting... again. I removed old and installed 3.04 and went to reboot,,, got the old boot sound no screen. Not anyone's fault but my own. Still not sure what I fddd up
#8 dman1049
dman1049
  • 94 posts
Posted 15 October 2012 - 12:07 AM
Now after all the flashing and fxzing I made a backup and the 3.04 is awesome
#9 magicmaster141
magicmaster141
  • 18 posts
  • Locationcolorado springs
Posted 15 October 2012 - 07:06 AM
link for download isnt working
#10 TragicRemedy
TragicRemedy
  • 87 posts
Posted 15 October 2012 - 09:32 AM
Hash, you make my bionic kewl, hats off to you sir, great work. Switching between roms in half a second the only wait is booting.... winning.
  • d73t likes this
#11 Hashcode
Hashcode
    King-Of-Code
  • 227 posts
Posted 15 October 2012 - 10:16 AM
Link fixed.
#12 G8orDroid
G8orDroid
  • 392 posts
  • Twitter:G8orDroid
Posted 15 October 2012 - 10:57 AM
...that awkward moment when you are using SS v2.11 for probably the last time and realize that you could have been using the capacitive keys to navigate through the menus all this time but instead have been using the volume rocker and on/off button... :wacko:
  • Rootuser94 likes this
#13 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • Twitter:@Rootuser94
  • LocationPA
Posted 15 October 2012 - 11:38 AM
This was me except i realized it like a month ago and was like, wow this is so much easier
#14 hadeshorn9
hadeshorn9
    Moot Minion
  • 961 posts
  • LocationBoston MA area
  • Current Device(s):Nexus 6 64gb, Dell Venue 8, Chromecast
Posted 15 October 2012 - 02:17 PM
Hash as always you make damn good stuff! Thank you for this new and improved SS3 !!
Many thanks to all involved in this! Great job!
OG -> Bionic -> (2013) Moto X DE -> Nexus 6 64gb Running 5.1 via Samuri's HoN
#15 Halloween240
Halloween240
  • 83 posts
  • Twitter:Twitter.com/Halloween240
  • Google+:Halloween240
  • LocationCharlottesville, VA
Posted 15 October 2012 - 04:52 PM
Hash= the man, great work as always sir
#16 shanewerner
shanewerner
  • 61 posts
Posted 15 October 2012 - 09:28 PM
:D just awesome hash thanks you so much for this and jm10
#17 mhous33
mhous33
  • 480 posts
Posted 15 October 2012 - 11:20 PM
well i know hashcode has a theme template on the way, so here's the twrp theme guide for those who want to get a jump on it:
#18 dshu
dshu
  • 17 posts
  • LocationSanford, Maine
  • Current Device(s):RAZR MAXX
Posted 16 October 2012 - 08:24 AM
Safestrap v3.04 is fantastic..thanks so much hashcode
#19 bwillis23
bwillis23
  • 10 posts
Posted 16 October 2012 - 10:16 AM
Will we still be able to flash V2 backups with V3? If not I'll just make new ones. Great work on this always a fan
Bionx RAZR overclocked and supercharged
#20 garywojdan81
garywojdan81
  • 633 posts
  • Twitter:gwojdan_81
Posted 16 October 2012 - 01:49 PM
No, nothing from v2 is transferrable.
Also tagged with one or more of these keywords: safestrap recovery
