5.5.905 Fxz With .901-.232 Compatibility And Alternative .886/.893/.902 Fxzs
157 replies to this topic
#1 sargentmajord
sargentmajord
    Moot Master
  • 2,889 posts
Posted 10 October 2012 - 07:20 AM
Certified tested an working new 5.9.905 fxz file for the .901/902/904/905/ICS leaks .2233-.232 update so if you have bricked ur phone/want to remove root on your .901/902/904/905 or ICS .2233-.232 updated phone or just having problems in general. You can now flash this fxz file to put your phone back to 5.9.905/.902/.893 or .886 and unbrick your phone. My FXZs have fixed over an estimated 4000+ Bionics so far. For those that have installed and are running the .901/904/905/ICS.2233-.232 system version or are running either .886/.893/.902 system versions due to flashing my FXZs or updates. all four FXZs can be flashed interchangeably over each other or the .893/.901/902/904/905/ICS .2233-.232 updates. so you don't have to worry about incompatible FXZs or updates So without further ado here are the steps (YOU MUST FOLLOW THE STEPS OR YOU WILL BRICK THE CRAP OUT OF YOUR PHONE I have had personal experience)
!!backups no longer needed all FXZs leave internal storage untouched!! so back up your data prior to FXZing Credit goes to theme developer Mbk for this fix in the FXZs XML file You will lose root once you flash either .886/.893/.902 or .905 FXZ file an must use the exploit to get it back. Make sure you are in charge only an USB debugging is selected when rooting and for ICS usb debugging an MTP mode for rooting also note ICS requires a new set of drivers so make sure they are up to date.
ICS Leaks .235 an above are NOT FXZ able you will soft brick your phone!!!! currently all new hybrid fxzs are on hold indefinitely for now
Step 1 download RSD lite 5.7 here (
) (you may have to run rds lite in xp compatibility mode for some windows operating systems)
Step 2 download the latest moto drivers here (
) if you dont have them.
Step 3 Download the FXZ File from here(under maintenance)
Step 4 open RSD Lite and boot phone into ap fastboot (to get into ap fastboot mode power down the device an hold both volume buttons down an the press the power button all at the same time an a menu will pop up. then scroll down to ap fast boot mode with the volume down button an then use the volume up button to select ( Makes sure you have at least 80% battery life and a reliable usb port if flash fails at 1/20, .893 1/22 or .886 1/15 find a different usb port or a different computer)
Step 5 click the browse button on RSD Lite an find the 5.9.905 FXZ zip file that you downloaded an click uncompress and flash. the entire process will take at least 20-25 minutes (you must leave your phone plugged in untill the status on rds lite says finished. so when you start this just walk away an leave it alone or risk bricking your phone) p.s it will say in the last stages to manually reboot your phone just ignore it an it will go away in 60 sec. if the status on RSD lite doesn't say pass an your phone has been booted for 10 or more mins. without rebooting it is safe to unplug the phone because some times there is a lag with the RSD lite acknowledging that the phone is booted an running. Also if you get a cdt error for some unexplained reason (AKA ap fastboot failure invalid cdt) you can fix it by downloading this file (
Step 6A Download the Universal motorola phone exploit For GB here
Step 6B download the Universal motorola phone exploit For ICS here
an then tada your done
Only use alternative fxzs if your still on GB
"905 FXZ alternative" I have created a 5.5.905 FXZ file that is compatible with the .886 /.893/.902 FXZ and .901/.904. or ICS .2233-.232 also all three FXZs can be flash over one another interchangeably without errors. This FXZ is for those who wish to return to 5.5.905 or are having problems with the .905 system version or just want to roll back because you liked it better you can download the FXZ here (
) an follow the same steps as you would with the 2.7.246 FXZ.
"902 FXZ Alternative" I have created a 5.5.902 FXZ file that is compatible with the .886 /.893/.905 FXZ and .901/.904. or ICS .2233-.232 also all three FXZs can be flash over one another interchangeably without errors. This FXZ is for those who wish to return to 5.5.902 or are having problems with the .905 system version or just want to roll back because you liked it better you can download the FXZ here (
) an follow the same steps as you would with the 5.9.905 FXZ.
"893 FXZ Alternative" I have created a 5.5.893 FXZ file that is compatible with the .886 /.902/.905 FXZ and .901/.904. or ICS .2233-.232 also all three FXZs can be flash over one another interchangeably without errors. This FXZ is for those who wish to return to 5.5.893 or are having problems with the .902/.905 or ICS .2233-.232 system versions or just want to roll back because you liked it better you can download the FXZ here (
"886 FXZ Alternative" I have created a 5.5.886 FXZ file that is compatible with the 5.5.893/.902/.905 FXZ and .901/904 or ICS .2233-.232 update plus both 5.5.886 and 5.5.893/.902/.905 FXZ files can be flash over one another interchangeably without errors. This FXZ is for those who wish to return to 5.5.886. All you have to do is download the FXZ file from here (
) an follow the same steps as you would with the 5.9.905 FXZ P.S I will be adding support to these fxz files for the next update that rolls out but hopefully the new update will be ICS Please leave feedback on this thread to let people know that these are working FXZ files thank you
Free mobile hotspot with stock phone hotspot (GB and ICS)
Step 1 Download an install Sqlite editor from the market here
Step 2 Open sqlite editor an select settings an storage (one with hammer an anvil not the one with the gear)
Step 3 Select setting.db
Step 4 Select settings
Step 5 Scroll down to _id 147 entitlement check
Step 6 Long press the value number 1 to the left of entitlement check in the next column an select Edit Field
Step 7 Change the value from 1 to 0 an then reboot the phone
Step 8 Open mobile hotspot an an configure the mobile hotspot the way you want it then before you select save change the DHCP from 192.168.42.2 to 192.168.99.2
Technical Support:
Answers: $1.00
Answers requiring Brain power: $2.00
Correct Answers: $3.00
Dumb looks for stupid questions: FREE
thought I would add a little humor to this post
  • FastKatt, lc75, mrthing2000 and 1 other like this
#2 SamuriHL
  • 44,416 posts
Posted 10 October 2012 - 08:27 AM
Thanks, Sarge. I've stickied this one.
  • dandersn330 likes this
#3 sargentmajord
sargentmajord
    Moot Master
  • 2,889 posts
Posted 10 October 2012 - 08:28 AM
#4 medic
medic
    It's not my blood....
  • 256 posts
  • LocationGhent
  • Current Device(s):Bionic 16gb, Nexus 7
Posted 10 October 2012 - 09:08 AM
I'll take dumb looks for stupid questions..... Love it!
Wooohoooo, Jelly Belly!
#5 mhous33
mhous33
  • 480 posts
Posted 10 October 2012 - 10:10 AM
nice write up! just a quick note, entitlement check is id 79 on ics.
#6 sargentmajord
sargentmajord
    Moot Master
  • 2,889 posts
Posted 10 October 2012 - 10:12 AM
Thanks ^_^
#7 SamuriHL
  • 44,416 posts
Posted 10 October 2012 - 10:14 AM
Sarge, mhous33 is very important to our little community. He's the one that cheesecakes for us. :) He's found SEVERAL of the leaks and posted them for us so far. Thanks, mhous33!!
  • mhous33 likes this
#8 sargentmajord
sargentmajord
    Moot Master
  • 2,889 posts
Posted 10 October 2012 - 10:17 AM
Sarge, mhous33 is very important to our little community. He's the one that cheesecakes for us. He's found SEVERAL of the leaks and posted them for us so far. Thanks, mhous33!!
Ahh an so the rival shows himself
#9 SamuriHL
  • 44,416 posts
Posted 10 October 2012 - 10:18 AM
LMAO. No rivals here. Close knit community. :)
#10 sargentmajord
sargentmajord
    Moot Master
  • 2,889 posts
Posted 10 October 2012 - 10:21 AM
But samuri u cheated on me :'( lmao
  • humbleopus likes this
#11 SamuriHL
  • 44,416 posts
Posted 10 October 2012 - 10:25 AM
Well....your parts are "out of commission." LMAO! :D
#12 mhous33
mhous33
  • 480 posts
Posted 10 October 2012 - 10:35 AM
glad i can help, although the more it seems like 247 will be ota, the more difficult to not say "f it" and flash. think i'll stay on <= 232 as long as possible though so i can pull jb leaks when they start dropping :)
#13 SamuriHL
  • 44,416 posts
Posted 10 October 2012 - 10:39 AM
Both Matt and Sarge will have Bionics that will stay on 905 (assuming Sarge gets his stuff working again....cough cough :D). So they should be able to cheesecake for us which is great.
#14 ggordon
ggordon
Posted 12 October 2012 - 10:46 PM
I get an error message - "Please check input file. EIther XML format is wrong or image files associated with it are missing." Can't get any further. Any ideas?
OK, I think it's because I'm at 866. I can't find the newvrz_xt875_5.9.902.xt875.verizon.en.us_cfc_01.xml.zip on 4-shared?
#15 sargentmajord
sargentmajord
    Moot Master
  • 2,889 posts
Posted 12 October 2012 - 10:53 PM
OK check the zip an tell me all the files that are there then open the XML file in the zip an copy an past it below the list of files u made an put all that in our next post
#16 sargentmajord
sargentmajord
    Moot Master
  • 2,889 posts
Posted 12 October 2012 - 10:54 PM
Open the XML file in the zip in note pad*
#17 mhous33
mhous33
  • 480 posts
Posted 12 October 2012 - 11:11 PM
i got that error before also. i think it has to do with allowing access to rsdlite, because i fixed it by launching rsdlite by itself (not through the HoB script). just navigate to the "rsd" directory in your HoB installation and launch SDL.exe and allow access on the popup. hope this helps.
#18 sargentmajord
sargentmajord
    Moot Master
  • 2,889 posts
Posted 12 October 2012 - 11:21 PM
This isn't HoB but yeah the swdl file will work
#19 sargentmajord
sargentmajord
    Moot Master
  • 2,889 posts
Posted 12 October 2012 - 11:23 PM
Doesn't matter what build ur on 905 will flash it its a problem with the fxz that's why I need u to post the info I asked for
#20 ggordon
ggordon
Posted 13 October 2012 - 04:56 AM
File list:
allow-mbmloader-flashing-mbm.bin
boot.img
cdrom
cdt.bin
device_tree.bin
ebr
grfs.img
lbl
logo.bin
mbm.bin
mbmloader.bin
mbr
preinstall.img
radio.img
recovery.img
system.img
VRZ_XT875_5.9.905.XT875.Verizon.en.US_CFC.xml
XML script:
<?xml version="1.0" encoding="UTF-8"?>
-<flashing>
-<header>
<phone_model model="TARGA"/>
<software_version version="5.5.1_84_DBN-74"/>
-<interfaces>
<interface name="AP"/>
</interfaces>
</header>
-<steps interface="AP">
<step MD5="f6102e4b34c74cfefd5e80151a6913ff" filename="allow-mbmloader-flashing-mbm.bin" partition="mbm" operation="flash"/>
<step operation="reboot-bootloader"/>
<step MD5="b0c30799c8509c4d66599550e3fbdd82" filename="mbmloader.bin" partition="mbmloader" operation="flash"/>
<step MD5="da0b9ae7f38048a2987e0ae24593fb4b" filename="mbm.bin" partition="mbm" operation="flash"/>
<step MD5="fd8c44b060415dfd963fa870ae7a4f35" filename="cdt.bin" partition="cdt.bin" operation="flash"/>
<step partition="cache" operation="erase"/> <step partition="userdata" operation="erase"/>
<step MD5="239bbc49a9cdb329577074ba60bbf1e5" filename="lbl" partition="lbl" operation="flash"/>
<step MD5="06c07c2970460a4e656a3206859a3617" filename="logo.bin" partition="logo.bin" operation="flash"/>
<step MD5="4c6df9afcd64661036a982e03eb1aa1a" filename="ebr" partition="ebr" operation="flash"/>
<step MD5="712e3e3757219ecfd925eb43be14f944" filename="mbr" partition="mbr" operation="flash"/>
<step MD5="2404a4f245f1da389d3422d0d59be24a" filename="device_tree.bin" partition="devtree" operation="flash"/>
<step MD5="8e306ac58dd4fcf01566c517eabc098d" filename="system.img" partition="system" operation="flash"/>
<step MD5="b64b38a48897c51fe229cf80a095d235" filename="boot.img" partition="boot" operation="flash"/>
<step MD5="ce9ee505c7fc708f7394617907ae5694" filename="recovery.img" partition="recovery" operation="flash"/>
<step MD5="6bdf130ecaa5183c0e463d2f3fa5d966" filename="cdrom" partition="cdrom" operation="flash"/>
<step MD5="f7f2ff434d2b0c819c1e28744d1b4d01" filename="preinstall.img" partition="preinstall" operation="flash"/>
<step MD5="c9502cd8fd6fa7206c64e4dae3ed9b50" filename="grfs.img" partition="webtop" operation="flash"/>
<step MD5="683184cc2522ba00e6a0c38d321a8806" filename="radio.img" partition="radio" operation="flash"/>
</steps>
</flashing>
