#121
Posted 10 October 2012 - 02:09 PM
#123
Posted 10 October 2012 - 02:58 PM
- toymachine234 likes this
#124
Posted 10 October 2012 - 03:45 PM
PS-changing device name in build prop doesn't help voice
#125
#126
Posted 10 October 2012 - 04:00 PM
'abrasher', on 10 Oct 2012 - 11:45 PM, said:
Haha got to let the battery callibrate man.Loved the rom this morning! As the day spent on, began having real MMS trouble (sending and receiving). The battery seemed to scream by... Droid MAXX FROM 100 - 83 in 58 minutes. For me, this is unheard of with other ROMS. IN THE END I HAD TO SWAP BACK, THOUGH I LOVE WHERE THIS ROM IS GOING. IF IT IS EVER ALL STABLE... IM ALL OVER IT.
#127
Posted 10 October 2012 - 05:06 PM
- NattyBee likes this
#128
Posted 10 October 2012 - 05:15 PM
'0145ethan', on 11 Oct 2012 - 01:06 AM, said:
Thank youMy bat did great! Just you have to manually turn on CPU sleeper (lol it got really warm in my pocket for awhile) I do like the ROM (love the ROM) and it isnt any fault of the developers, JB just isnt even closed to finished. I have to remind myself that this is all alpha stage...
#129
Posted 10 October 2012 - 05:50 PM
the MMS issue is a common issue among JB roms at the moment (seemingly especially AOKP roms)...to get around this:
install GO SMS
go into Go SMS settings
go into Important Tips
check "stock SMS uninstalled?"
go into system settings
go to Apps > All
go to Messaging and disable it.
now Go will handle your SMS/MMS rather than the system, and you shouldn't have any issue.
#130
Posted 10 October 2012 - 05:53 PM
- Rootuser94 likes this
#131
Posted 10 October 2012 - 06:22 PM
#132
Posted 10 October 2012 - 06:32 PM
'fishaholic', on 11 Oct 2012 - 02:22 AM, said:
anyone know how to swap the keyboard for a larger one? i tried replacing the system latinIME.apk from another AOKP rom and it wont work!! :/
not to make assumptions, but did you fix the permissions and reboot before trying the new keyboard?
#133
Posted 10 October 2012 - 06:43 PM
tried a cache and dalvik wipe and fix permissions too
#134
Posted 10 October 2012 - 06:46 PM
'fishaholic', on 11 Oct 2012 - 02:43 AM, said:
yep, even tried to install the apk. i can use other apk's from JB roms where the keyboard is the same but when i try the larger AOKP keyborad and try too install it says app not installed.
I didn't mean fix permissions in recovery, I meant manually set them for the apk file in system/app...I dunno why it wouldn't work if you did that, unless there is a problem with the apk or compatibility...
Sent from my RAZR Maxx using Tapatalk 2
#135
Posted 10 October 2012 - 07:55 PM
'NattyBee', on 11 Oct 2012 - 02:46 AM, said:
Yeah this is how i would suggest doing it if your trying to intstall a system app, set the permissions to rw-r-r i believe you check the whole first column and the first box in the second column. Then rebootI didn't mean fix permissions in recovery, I meant manually set them for the apk file in system/app...I dunno why it wouldn't work if you did that, unless there is a problem with the apk or compatibility...
#136
Posted 10 October 2012 - 09:34 PM
My only complaint is my wifi speeds are HORRIBLE, compared to other roms. And when i'm connected to wifi or 4g, the color in status bar doens't change. Just stays grey...as if i'm not connected, although i am. I see the 4g arrows change colros, but no color change when i'm connected to 4g or wifi. Always stays grey.... ? Any idea as to why, or is that how it's supposed to be?
#137
Posted 10 October 2012 - 09:55 PM
'shorte_33', on 11 Oct 2012 - 05:34 AM, said:
I do know how thats supposed to be lol. I themed them that way. In the galaxy s3 thats how it looks and this is a touchwiz rom soooo........ in wifi hit advanced and hit always under keep wifi on during sleep.Great rom, great battery, everything is great. The aftermarket camera apps work just fine. Not an issue. Go Sms fixed the mms issue (Root, maybe make that a system app...Just an idea to avoid less complaints from folk).
#138
Posted 11 October 2012 - 12:22 AM
#139
Posted 11 October 2012 - 05:05 AM
If it wasn't clear, I greatly appciate the work you put into this ROM. I also was in no way trying to complain... Especially as I know that issues the reside with current JB ROMS. I was only trying to post in response to direct questions regarding battery and MMS... As there hadn't been any response to those specific points yet, from users.
This is BY FAR my favorite JB ROM that I have touched! It is AWESOME.
Perhaps I will give her another go, and give the fixes mentioned a shot.
#140
Posted 11 October 2012 - 05:49 AM
