1389 replies to this topic
#1341 james
james
  • 620 posts
  • Locationsouthern cali
  • Current Device(s):LG G2 Verizon
Posted 14 January 2013 - 08:12 PM
does camera flash work on this
oops sorry just read to try pudding camera
Edited by james, 14 January 2013 - 08:24 PM.
#1342 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • Twitter:@Rootuser94
  • LocationPA
Posted 14 January 2013 - 09:42 PM
No gapps needed
#1343 L4M3N7
L4M3N7
  • 25 posts
  • Twitter:L4M3N7
  • LocationPittsburgh, PA
  • Current Device(s):RAZR Maxx
Posted 15 January 2013 - 06:21 AM
The camera flash is still being a bit tricky. It's being quiet at work today so I'll probably run aLogcat and pull some errors to help pinpoint this. So far nothing I've found has been much help sadly :(
  • Rootuser94 likes this
#1344 L4M3N7
L4M3N7
  • 25 posts
  • Twitter:L4M3N7
Posted 15 January 2013 - 11:19 AM
After beating a divot into my desk... I think I have a basic idea of why this is happening. The actual build this all is based on has a set of values for the camera that are called upon when the camera goes to take a picture. These are usually adjusted based on the device and it's hardware. When a camera app is created it can either try to use the values in the system (which is easier because it doesn't need to make guess work) or use it's own values programmed into the apk. This may require a custom built version of the Gallery apk that calls upon it's own internal values. This might be a tad tricky as the values are in microseconds and will have to be found by breaking down a build with a working camera apk and extracting them.
I'll have to try to extract all the values from the 4.1.2 OTA I have on my computer at home.. and find out how to force the Gallery apk to look at the custom values. FUN!!!!
#1345 james
james
  • 620 posts
Posted 15 January 2013 - 07:17 PM
so anyone know the best setting for processor speed i wanna get the best battery life possible
#1346 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • LocationPA
Posted 15 January 2013 - 08:18 PM
Pegasusq gov and sio scheduler. and obviously the lower you set your processor the better battery, but then you may get a phone slowdown. all in what you want
#1347 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 669 posts
  • Twitter:@MrFrankReyna
  • Google+:frankreyna
  • LocationSoCal, USA
Posted 15 January 2013 - 09:04 PM
I don't know anyone would want to slow down their phone...defeats the purpose of a fast smart phone. And, you're never gonna get the perfect battery life as noone is ever satisfied. Might as well get an older phone then.
#1348 L4M3N7
L4M3N7
  • 25 posts
  • Twitter:L4M3N7
Posted 17 January 2013 - 06:15 AM
It also helps if you freeze some of the auto starts for some of the apps. There's no need for some of those to happen. You can do it at your own risk in Rom Toolbox. For example: locking/unlocking your screen shouldn't start some non-system apps (if you ask me) Also try to uninstall any app you won't use ever again, or use very infrequently. Some apps I just simply need once in a great while and I reinstall them when needed.
#1349 dhenrichs
dhenrichs
Posted 17 January 2013 - 07:25 AM
where can i get a link for the most recent version of RLS7
#1350 L4M3N7
L4M3N7
  • 25 posts
  • Twitter:L4M3N7
Posted 17 January 2013 - 07:36 AM
the latest version will always be in the original post ;)
Here's the link:
#1351 iamhugger
iamhugger
  • 296 posts
  • Locationsouth dakota
  • Current Device(s):droid razr
Posted 17 January 2013 - 07:49 AM
Anyone know what's up with proximity sensor? Very sluggish when u pull phone from face after phone call
Sent from my Motorola Galaxy s3 using Tapatalk 2
#1352 L4M3N7
L4M3N7
  • 25 posts
  • Twitter:L4M3N7
Posted 17 January 2013 - 08:00 AM
I haven't seen any issues with it on mine. Never really looked for it though.
#1353 L4M3N7
L4M3N7
  • 25 posts
  • Twitter:L4M3N7
Posted 17 January 2013 - 10:10 AM
Well the good news is that I made the camera run very well on a test build I just did and not crash 1 time even with abusing it.. the bad news is that the flash still hates working. Might be baby steps.. but they're still steps forward.
  • zllibengood and Rootuser94 like this
#1354 zllibengood
zllibengood
  • 72 posts
  • Locationsioux falls, sd
Posted 17 January 2013 - 12:42 PM
I'm absolutely loving this ROM. Runs great and very smooth. If you get the camera flash working I would have no reason to use another ROM. Very nice work.
-Z
#1355 zllibengood
zllibengood
  • 72 posts
Posted 17 January 2013 - 12:43 PM
-Z
#1356 sdt121
sdt121
  • Current Device(s):Razr maxx
Posted 17 January 2013 - 02:48 PM
How do you get the voice to talk back in Google now or svoice?
#1357 arsenic1234
arsenic1234
  • 45 posts
Posted 17 January 2013 - 07:24 PM
I was checking out the Acid Audio and wondered if anyone got the walkman adon to install?
I've tried twice and I just black screen after the install.
According to the makers of the mod it should work, however no dice here.
Any thoughts?
Here should be the original link for the assumed MOD this rom has?
#1358 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • LocationPA
Posted 17 January 2013 - 07:57 PM
Any thoughts?
Yeah because it's originally for samsung phones i believe so you need to use a universal zip i included.
#1359 arsenic1234
arsenic1234
  • 45 posts
Posted 18 January 2013 - 05:18 AM
I did use the universal zip for acid audio (to get it working), its when I flash the universal add on that it black screens on boot.
Not sure if something inherent in the setting for the ROM (to make it look like a samsung maybe) would be stopping it?
But supposedly you can use the razr and maxx and that add on should work.
/shrug
Just was fishing, seemed like a neat app to have to enhance playback.
Since I really see no setting from Acid Audio to tweak like I used to have with Beats.
Am i missing something?
#1360 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • LocationPA
Posted 18 January 2013 - 05:48 AM
Nope you don't need to tweak it's already pretty tweaked
Sent from my SCH-I605 using Tapatalk 2
    Bing (1)
