#1281
Posted 01 January 2013 - 11:43 AM
#1282
Posted 01 January 2013 - 02:39 PM
Don't have to mess with wiping 15 times or that nonsense.
#1283
Posted 01 January 2013 - 07:18 PM
EDIT: Realized I was using the previous version and say your update notes "Added in MMS fix" Looking forward to it!
- Rootuser94 likes this
#1284
Posted 02 January 2013 - 12:14 AM
#1285
Posted 02 January 2013 - 12:35 AM
NEEDA GO HEAD AND START DOING THE JB OTA LOL
I don't think posts like these are necessary. Not intending to be rude.
#1286
Posted 02 January 2013 - 08:30 AM
dev made 6 updates for cdma version but gsm one is still v1. no complaints, just curious to know
#1287
Posted 02 January 2013 - 09:13 AM
gsm will be getting update soon too. The reason that there are 6 builds for the razr is that it was started earlier. So the 1 gsm version has most everything from the other 5 razr buildsi'm asking without much hope: does the gms patch works for this build?
- v1tru likes this
#1288
Posted 02 January 2013 - 11:20 AM
#1289
Posted 02 January 2013 - 11:25 AM
#1290
Posted 02 January 2013 - 01:59 PM
You can also purchase tomasafca's touchwiz theme which is excellent in my opinion. . And you can pull the app seclauncher2.apk and the lib drawglsomething.so and push them to your phone in the app and lib folders and they both may work!Hey Rootuser, is there anyway you could tell me how you got the Touchwiz theme working or where you got it? I had a Razr Maxx and just moved to a Razr M, so that means I lost access to this awesome ROM and I was missing the theme. Thanks for your help and your hard work!
#1291
Posted 02 January 2013 - 03:21 PM
#1292
Posted 02 January 2013 - 04:39 PM
you need to download apk tool, but if you pm me and i can help you with it if you'd likeThanks Rootuser! I tried moving the files and it actually somewhat worked, only it has some fc issues and it has to be resized, and I have no idea how to fix those ha ha ha.
#1293
#1294
Posted 02 January 2013 - 10:03 PM
- boom83 likes this
#1295
Posted 03 January 2013 - 04:51 AM
Also, if I want to update some of these Google apps that are pre-installed, I guess I would have to remove them with Titanium Backup, reboot, and then install them from the Play store?
Thanks.
#1296
Posted 03 January 2013 - 05:01 AM
I had something weird happen this morning when I pulled down the notification shade to turn off bluetooth. The phone acted like I hit the Settings button and it went into Settings. I hit the Home button and the top of the screen was flickering some, like it was trying to partially pull down the notification screen multiple times. It eventually stopped doing that.
Thanks.
I've found sometimes I accidently smudged my screen and it will freak out like that.
As for the apps.. you can find the apps in the Play Store and try to update there. If the update fails you can uninstall and reinstall right there. I've done this without issue several times. Feel free to get them backed up if you want just as a precaution.
#1297
Posted 03 January 2013 - 07:22 AM
#1298
Posted 03 January 2013 - 07:33 AM
Something special is coming for those of you who are on the JB OTA....soon!
#1299
Posted 03 January 2013 - 07:45 AM
For all those on the Jelly Bean Leak, Jellywiz is now Live! Now if you want to stay on ICS though to continue using this rom, i understand
#1300
Posted 03 January 2013 - 10:51 AM
