1389 replies to this topic
#1221 beerman1373
beerman1373
  • 20 posts
  • Current Device(s):Razr Mazz
Posted 26 December 2012 - 04:02 PM
Was tempted to update to official Big Red release but i love this rom. Ganna wait for the overlord to give us the goodies instead.
  • Rootuser94 likes this
#1222 L4M3N7
L4M3N7
  • 25 posts
  • Twitter:L4M3N7
  • LocationPittsburgh, PA
  • Current Device(s):RAZR Maxx
Posted 27 December 2012 - 11:44 AM
Loving this ROM. Fixed my camera/video recorder and MMS and I'm not looking back. Very nice job, RU94 ^_^
#1223 SoAz4Runner
SoAz4Runner
  • LocationAZ
  • Current Device(s):Wizzed Razr to the Maxx
Posted 27 December 2012 - 06:16 PM
Sweet ROM! Kudos!
One issue...I have a folder on my home screen and when I open it and close it a women tells me "folder is open" and "folder is closed". The same voice comes through when i tap on "edit page" from the menu. Talkback is off. I have toggled it to see if that would work...nada...suggestions? Btw second time flashed this rom...first time seemed like it was missing something, extremely choppy but now it's all good minus the woman's voice lol.
#1224 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • Twitter:@Rootuser94
  • LocationPA
Posted 27 December 2012 - 06:41 PM
Sweet ROM! Kudos!
Could be S Voice doing that lolz
#1225 SoAz4Runner
SoAz4Runner
  • LocationAZ
Posted 27 December 2012 - 06:55 PM
Couldn't find any settings in S Voice pertaining to my issue. Went in and disabled the app entirely. Wiped cache. Still got that woman nagging me...
#1226 NoAckUp
NoAckUp
  • 8 posts
Posted 27 December 2012 - 06:58 PM
Could you explain what you did to fix both issues? Thanks
#1227 Edward_htownrazr
Edward_htownrazr
  • 11 posts
  • LocationLake Chuck, La
Posted 27 December 2012 - 10:30 PM
Hey, first thing great from. But I have 2 issues, my camera crashes randomly and I have no sound with n7 player n win amp crashes when scanning. I've tried reflashing, I might try again but maybe wiping a couple extra times. Im looking forward to an update, might fix the issues.
#1228 beerman1373
beerman1373
  • 20 posts
Posted 28 December 2012 - 06:55 AM
My Camera was crashing as well. I also had a few other apps that would crash so I decided to re install the Rom. Wiped cache 4 times as well as factory reset twice. Did the trick! I have not had one singe issue so far. I downloaded the n7 player to see if it crashed during scan and no issues. Hope re-flash and wipe worked for you. This is by far one the top rom that i have used and will only get better.
#1229 Edward_htownrazr
Edward_htownrazr
  • 11 posts
Posted 28 December 2012 - 10:01 AM
Thx man ima reflash as soon as my battery is back to 100%. And yea this is one of the cleanest smoothest rooms.
#1230 L4M3N7
L4M3N7
  • 25 posts
  • Twitter:L4M3N7
Posted 28 December 2012 - 10:02 AM
The old camera folder seems to have some screwy permissions when MotoBlur created it initially. All I did was go to /storage/sdcard1/dcim and rename the 'Camera' folder to 'BlurCamera' and create a new folder called 'Camera' in it's place. No more instant FC when you launch your camera. Camera, camcorder, and panorama work perfectly. This WILL NOT make PhotoSphere work though. That particular feature requires hardware the XT910/912 doesn't have. It will just sit there and try to calibrate endlessly.
The MMS fix is located on the first post in the thread. Save it to your SD card and reboot into SafeStrap. After that, flash it to the slot you have Wizzed Bean on. I've tested it and it worked like a dream.
Good luck and happy flashing ^_^
  • Rootuser94 and NoAckUp like this
#1231 NoAckUp
NoAckUp
  • 8 posts
Posted 28 December 2012 - 10:12 AM
Thanks for the quick response, appreciate your help!!! This is an awesome ROM!!!
#1232 james
james
  • 620 posts
  • Locationsouthern cali
  • Current Device(s):LG G2 Verizon
Posted 28 December 2012 - 10:42 AM
i am guessing that this has gapps included
#1233 L4M3N7
L4M3N7
  • 25 posts
  • Twitter:L4M3N7
Posted 28 December 2012 - 10:47 AM
No problem. Thankfully a quiet day at the helpdesk here. Been sitting around torturing an old Mac Mini all day :D
#1234 L4M3N7
L4M3N7
  • 25 posts
  • Twitter:L4M3N7
Posted 28 December 2012 - 10:51 AM
Yes. GApps are included.
#1235 james
james
  • 620 posts
Posted 28 December 2012 - 11:14 AM
thanks
#1236 james
james
  • 620 posts
Posted 28 December 2012 - 04:32 PM
so i was using pudding camera and the flash but it took the pic with the flash on and then i viewed the picture and it was dark like the flash didnt even go off
#1237 joshxdroid
joshxdroid
  • 162 posts
Posted 28 December 2012 - 05:54 PM
yeah, I've noticed on jelly bean even if the flash works, the timing isn't right
#1238 L4M3N7
L4M3N7
  • 25 posts
  • Twitter:L4M3N7
Posted 29 December 2012 - 07:50 AM
I've got my camera flash starting to work in stock, but the gallery does FC quite a bit still. Hopefully I can nail that down today.. but first I need to dig myself out of my apartment and get coffee ._.
#1239 Edward_htownrazr
Edward_htownrazr
  • 11 posts
Posted 29 December 2012 - 12:29 PM
Im having another problem after i updated to safestrap 3.07, I tried flashing this ROM and the fat free bean ROM and either way i get the same black screen after the M n dualcore splashscreen. Anybody had this happen?
#1240 L4M3N7
L4M3N7
  • 25 posts
  • Twitter:L4M3N7
Posted 29 December 2012 - 01:08 PM
I've had a similar issue where I had an empty ROM slot set to active somehow. I'd load into SafeStrap and check to make sure the one you want to boot into is marked active.
