#1181
Posted 22 December 2012 - 02:31 PM
#1182
Posted 22 December 2012 - 03:29 PM
I'm hoping for a "christmas gift" style update
I love Santa. Merry Christmas Root, and thanks for all the presents you've given us :-)
- DarkOverDroid and Rootuser94 like this
#1183
Posted 22 December 2012 - 03:30 PM
Merry Christmas to you too my friendI love Santa. Merry Christmas Root, and thanks for all the presents you've given us :-)
- DarkOverDroid likes this
#1184
Posted 22 December 2012 - 04:55 PM
#1185
Posted 22 December 2012 - 06:15 PM
#1186
Posted 22 December 2012 - 07:30 PM
#1187
Posted 22 December 2012 - 07:34 PM
#1188
Posted 22 December 2012 - 07:36 PM
#1189
Posted 22 December 2012 - 07:38 PM
#1190
Posted 22 December 2012 - 07:41 PM
I will have to find the way to restore my apps from titanium. Right now when I open titanium it shows that there were never any backups made.
Go into TB's preferences and set it to where your backup files are, you may have to search for them. Had the same problem.
#1191
Posted 23 December 2012 - 04:18 AM
What camera are you guys using with this ROM, I see that the stock camera's flash is not working correctly. Can I use the stock camera taking vids and use the Pudding camera for taking normal pics?
#1192
Posted 23 December 2012 - 07:53 AM
Ok I was able to auto detect and find the missing backups, I am going to go through and reinstall some of the apps manually since I had a bunch of crap on my phone that I really didn't need before. I already installed most of the apps that I really want so can I reinstall just the data for those apps? Also can I reinstall all my old text messages and phone calls?
The camera flash not working is a JB issue not just a rom issue. As far as restoring data, most say not to do it and to start over fresh. If your data was backed up on a ICS rom I would not restore it on a JB rom, you can always try and if you have issues reflash and start fresh.
#1193
Posted 23 December 2012 - 07:55 AM
#1194
Posted 23 December 2012 - 08:18 AM
I like pudding camera its yummyYep I realize that the camera problem is a JB issue but I thouht I read that some camera's work better than other's?
#1195
Posted 23 December 2012 - 08:54 AM
#1196
Posted 23 December 2012 - 08:58 AM
Anyone having issues with the alarm not making any noise? Thought I slept through my alarm this morning (and I did), but turns out it just doesn't make any noise on my phone... :/
My default tone didn't work but once I changed it I have no problem. Also when looking at your alarms hit menu and make sure you have "alarm on silent" checked.
#1197
Posted 23 December 2012 - 09:07 AM
Man. That was the problem. Thanks, sir.
#1198
Posted 23 December 2012 - 02:37 PM
Yep I did also
To fix every time you set alarm set sound for alarm also then it will go off with sound
I was annoyed with that so I flashed clock from another aokp ROM and it works flawless just use root explorer and set permissions
#1199
Posted 23 December 2012 - 10:20 PM
Been out of the loop for a bit and looking to get something fresh over this 4.0.4 ics build iebeen on forever. Thanks!
#1200
Posted 24 December 2012 - 12:05 AM
Of course I am. This ROM is awesome!Are you guys using this as a daily driver or no?
