#101
Posted 09 October 2012 - 02:20 PM
#102
Posted 09 October 2012 - 02:25 PM
i just flashed this rom and i have a few questions..... the wifi hotspot do you you use wifi tether w/ root and if so what are the settings?.........also after i flashed it promted me to an OTA update so i did it looks like a completely different rom now. should i not have done that and should i wipe again and reflash original file?
Taking the ota puts you on the latest stock aosp version :-P
#103
Posted 09 October 2012 - 02:49 PM
#104
Posted 09 October 2012 - 02:52 PM
I am getting random notifications that come up for stupid stuff like win a free ipod and stuff like that. If you click on the notification it takes you to the internet. How can I make this stop. This is the only rom that I have ever used that has had (Add Notifications) tagged to it. It happens like 3 times a day and is very annoying. Any help would be appreciated.
Very likely this is due to some app you have installed...I have encountered this several times in the past, and it's always been an app
#105
Posted 09 October 2012 - 02:56 PM
Like natty said its most likely an app. I call it aggressive advertising. So what ever you have installed recently get rid of it
#106
Posted 09 October 2012 - 03:41 PM
#107
Posted 09 October 2012 - 03:44 PM
This is called airpush, its very easy to block. Download Adaway from the market and press the block ads button and voila they are gone!I am getting random notifications that come up for stupid stuff like win a free ipod and stuff like that. If you click on the notification it takes you to the internet. How can I make this stop. This is the only rom that I have ever used that has had (Add Notifications) tagged to it. It happens like 3 times a day and is very annoying. Any help would be appreciated.
#108
Posted 09 October 2012 - 03:45 PM
Yeah dont take the ota it will take you to a new unmodded version.i just flashed this rom and i have a few questions..... the wifi hotspot do you you use wifi tether w/ root and if so what are the settings?.........also after i flashed it promted me to an OTA update so i did it looks like a completely different rom now. should i not have done that and should i wipe again and reflash original file?
#109
Posted 09 October 2012 - 05:40 PM
- Rootuser94 likes this
#110
Posted 09 October 2012 - 06:19 PM
ve used that i think I'll be on for a LONG time.
#111
Posted 09 October 2012 - 06:57 PM
I'm aiming for an update sometime soon with some more theming and tweaksSir may i just say, that I absolutly LOVE this rom..i can not wait for an update...you did great work with this. First rom i
- mike_augie likes this
#112
Posted 09 October 2012 - 08:08 PM
#113
Posted 09 October 2012 - 08:58 PM
Not really sure, its kinda buggy since it only fully works on the s3. if you know how, you can use a build prop editor and change your device name from XT910 or whatever it is to i90300, which is the galaxy s3's name. Sometimes it works better then, its pretty weirdOkay... so I M shocked how much I am enjoying this ROM. GREAT WORK!!!! Any idea how I can get svoice to save alarms, memos, or tasks? Or how to get it to search using my browser, not the AdSense thing.
#114
Posted 09 October 2012 - 09:13 PM
in any case this is by far the smoothest, fastest JB rom ive come across yet. thanks.
#115
Posted 10 October 2012 - 05:43 AM
app info then Force Close, then Clear data & factory reset,
restarting my device,
re flashing the rom,
i even re downloaded the rom and re flashed it, with no luck,
when i re flash it, it works for only 2 times, after that it stops working and crashes and tells me Unfortunately, Gallery has stopped
#116
Posted 10 October 2012 - 09:30 AM
#117
Posted 10 October 2012 - 11:10 AM
#118
Posted 10 October 2012 - 01:01 PM
#119
Posted 10 October 2012 - 01:09 PM
how long for a update having flash withdrawls
#120
Posted 10 October 2012 - 01:39 PM
