1389 replies to this topic
#1161 desireaftergod
desireaftergod
  • 536 posts
  • LocationNH
Posted 20 December 2012 - 07:06 PM
Is anybody having an issue on this rom with notifications for Calendar, text..etc only working some of the time for me. I notice quite often that I never hear a notification and at some point I happen to look at my phone and notice that I missed a text or other reminder. Any way to fix this that anyone knows of?
#1162 Jrv331
Jrv331
  • 62 posts
  • LocationNE Ohio
Posted 20 December 2012 - 07:34 PM
I have this version of flash installed still no web videos stock or chrome browsers. Any ideas for me?
Use Dolphin or ICS Browser. Flash works fine on those two for me.
#1163 VLSM
VLSM
  • 9 posts
Posted 21 December 2012 - 03:52 AM
Hi there, I recently bought the xt912 and am using it in New Zealand, I need GSM to work however I am not getting any signal. I know that GSM does work as iv'e had it working on FLICK, Is there any way I can get this working as this is a great rom.
#1164 mhotovec
mhotovec
  • 175 posts
  • LocationJacksonville, Fl
  • Current Device(s):Razr Maxx, Asus TF700
Posted 21 December 2012 - 04:13 AM
I voted for using a 4.2 base on the next ROM just because I (we all, probably) like to be on the latest and greatest. In reality though, I want whichever one will be the most stable and give us the best quality. In particular, for me, is working bluetooth.
#1165 reese
reese
  • 18 posts
  • Twitter:reesemitchell
  • Google+:reese.mitchell
  • LocationShreveport,LA
Posted 21 December 2012 - 07:02 AM
Before voting i would recommend everyone look up the main differences between 4.2 and 4.1
for me I voted to keep 4.1. Don't get me wrong I love bleeding edge technology. But this (4.2) rom I think as of right now not nearly as stable as 4.1. I don't think people would NOT notice if any that much of a difference in speed. Also a lot of the issues your having in 4.1 will STILL BE THERE. Ex: bluetooth. When bluetooth for 4.1 get fix. there is a 87% chance it will be for 4.2 also. If you need to youtube the rom to see it in action go for it. 4.2 I would recommend google it and seeing if it is something you really want as of right now. I guess this is how I would break it down for you.
ROM (4.1) I would recommend this one for EVERYDAY use. It is very stable, customize to meet your needs, great feed back on it. More help with this one.
Rom (4.2) I would NOT recommend this one for everyday use. If you want bleeding edge, don't mind a couple of more crashes... and HAVE to run the newest latest and greatest this one is for you. But don't expect everything to work right off with this one and expect to see that much of a difference... If it was 5.1 or so you would expect a lot more.
  • Rootuser94 likes this
#1166 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • Twitter:@Rootuser94
  • LocationPA
Posted 21 December 2012 - 07:15 AM
Right now i'm leaning toward 4.1 due to stability and some issues. Personally i don't think you gain that much in 4.2.
  • reese likes this
#1167 bolden88
bolden88
  • 38 posts
Posted 21 December 2012 - 07:20 AM
I like stability. My only issue other than the known which don't faze me, my Wi-Fi connection does not restart once I leave a Wi-Fi area. If I leave my house and come back I have to go in and reconnect each time. Drives me nuts because it doesn't always reconnect. I looked in the advanced settings. I do not have a secure setup so that should rule out security issues.? Other than that this is the cats meow. I used to flash one a day but don't even look elsewhere now.
#1168 Pike
Pike
  • 20 posts
Posted 21 December 2012 - 07:37 AM
Um I don't care about 4.1 or 4.2, why you may ask? Because this ROM is pretty AWESOME as it is. I love it x10000. Keep up the great work!
#1169 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • LocationPA
Posted 21 December 2012 - 07:38 AM
Check in wifi settings/advanced to keep wifi on while sleeping and theres some other stuff for you too play around ;)
#1170 bolden88
bolden88
  • 38 posts
Posted 21 December 2012 - 07:56 AM
The only options are 5 minutes up through 3 hours. There is no NEVER turn off. I am currently on the 15 minutes option. Maybe I will try the max 3 hours.
As for 4.1 or 4.2... Rootuser, you are the man that has to listen when people b*tch about things not working. If you are up for that pain then go 4.2 else 4.1 works great for most. From other 4.2 ROMs if have seen the list of what works is really short... basically just a phone right now.
Thanks again for your efforts
#1171 jamminjon82
jamminjon82
  • 610 posts
  • Twitter:@jamminjon82
  • LocationGloucester, VA
  • Current Device(s):LG G2, Moto X, Kindle Fire 2,Razr M, Nexus 7, Acer A100
Posted 21 December 2012 - 08:45 AM
if those are your options then you are looking at the wrong thing
#1172 joshxdroid
joshxdroid
  • 162 posts
Posted 21 December 2012 - 08:51 AM
I voted for 4.1 because of stability. I would love to see improvement on 4.1, but if you've improved it as much as you think you can, then move on to 4.2 but leave the link to the current version. I'm hoping there are further improvements to be made before moving on
#1173 ReSuReKtZ
ReSuReKtZ
  • 138 posts
Posted 21 December 2012 - 01:08 PM
Any one have a fix for the FFC or is that a kernel problem
#1174 riggsdaruler
riggsdaruler
  • 110 posts
  • Twitter:riggsdaruler
  • Google+:riggsdaruler
  • LocationGeorgia
Posted 21 December 2012 - 05:27 PM
Can't seem to get play store to connect
#1175 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • LocationPA
Posted 21 December 2012 - 06:51 PM
Clear app data in settings/ delete and resign in your google account
#1176 1ckrobinson
1ckrobinson
Posted 22 December 2012 - 05:29 AM
Running CN3 version now. Fast and smooth, going to try CNVi now. When I tried the 1.3ghz version of the CN3 the phone is buggy. Here goes nothing :o
#1177 chrisvx930
chrisvx930
  • 32 posts
Posted 22 December 2012 - 12:51 PM
Thanks for all your hard work Rootuser! Do you know when the next update will be ready?
#1178 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • LocationPA
Posted 22 December 2012 - 01:36 PM
I'm hoping for a "christmas gift" style update ;)
  • mhotovec, Badger50, DarkOverDroid and 3 others like this
#1179 desireaftergod
desireaftergod
  • 536 posts
  • LocationNH
Posted 22 December 2012 - 02:09 PM
:) :) :) :) :) :) :) :) :) +1
  • thrasher194 likes this
#1180 chrisvx930
chrisvx930
  • 32 posts
Posted 22 December 2012 - 02:19 PM
Thanks man!
