1389 replies to this topic
#1121 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • Twitter:@Rootuser94
  • LocationPA
Posted 18 December 2012 - 06:52 AM
Let me start off by saying I think this ROM is great. This is the first JB ROM that I have deemed worthy of using as a daily driver because of its stability and speed.
However, I am having a couple of issues. I don't know if this is just something in JB or not, but I am occasionally getting where when I receive emails, the notification is not detailed like it normally is in JB. It basically just looks like the ICS notification that tells me how many emails I have. Is there a setting that controls this or is this just how it it?
Also, I have had a couple of instances where my phone decides it doesn't want to read the external SD card anymore, which is where I keep all my pictures. Is there an easy fix for that? Thanks!
Do a two finger pull down on yo notifications and they will expand.
I have a quick question about the audio. Ok I re-installed the rom Wizzed Bean but I added a different beats audio to it. (just beats audio alone) instead of the ac!d audio. and the beats worked. Is it a way I can write over the ac!d audio beats and use the one that worked for me.
Thank you.
If you reflash the rom and do a full wipe, Ac!d will not be there and you can do whatever your heart desires with audio programs :)
#1122 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 669 posts
  • Twitter:@MrFrankReyna
  • Google+:frankreyna
  • LocationSoCal, USA
Posted 18 December 2012 - 06:59 AM
Try uninstalling and reinstalling from the play store boss
Yeah, I may try that. Sometimes Google Now shows me some status' and sometimes not. Oh well, it's cool though.
#1123 reese
reese
  • 18 posts
  • Twitter:reesemitchell
  • Google+:reese.mitchell
  • LocationShreveport,LA
Posted 18 December 2012 - 07:35 AM
I was hoping to flash ac!d then reboot then flash beats to try to fix the problem it did not work :( thank you for your help RootUster94
#1124 Jrv331
Jrv331
  • 62 posts
  • LocationNE Ohio
Posted 18 December 2012 - 07:39 AM
This ROM is Blazing fast! (nice work) after running it as my daily for a couple of days, I've encountered 2 problems:
1. The clock app will not allow me to browse my files to select a custom song for the alarm (com.sec.android.app.myfiles not found)
2. I am unable to move any apps to the ext SD card. (I've used TI Backup, Rom Manager Pro, and App2SD, but it says insufficient storage.)
I'm rocking a 64GB SD card that has been completely wiped and formatted. There is NOTHING on it. Unfortunately, my internal storage is full, so I can't update Google Maps, Gmail, and about a dozen other apps that need an update now. Any ideas?
When I installed this it put several folders on my ext-sd card. No other rom has done that.
#1125 team420
team420
  • 24 posts
Posted 18 December 2012 - 08:17 AM
Ok, so I can send mms just fine with the fixed messaging but I can't seem to receive them. Anyone have this problem besides me?
same here
#1126 beerman1373
beerman1373
  • 20 posts
  • Current Device(s):Razr Mazz
Posted 18 December 2012 - 09:21 AM
I am ready for the beat down after posting this Question. OP states Reboot into Safestrap 3 only. In know i Know I know it says "Reboot into Safestrap 3 only" but will any other versions of safestrap work .
#1127 joshxdroid
joshxdroid
  • 162 posts
Posted 18 December 2012 - 09:54 AM
Yes, 3.05 will. Lol. Why don't you want to update to safestrap 3? It's freaking awesome. TWRP is so far superior to clockwork in my opinion
  • Rootuser94 and reese like this
#1128 beerman1373
beerman1373
  • 20 posts
Posted 18 December 2012 - 09:59 AM
Well, I just haven't gotten around to it lol. I just installed using SS2.11 and so far so good.
#1129 beerman1373
beerman1373
  • 20 posts
Posted 18 December 2012 - 12:52 PM
All is well except for not being able to get to the gallery due the "No Storage/No External Storage Available error. Searching through the Forums i see some options for re-naming the Pics Folder / clearing cache / and data from gallery So far not going so well. I also fixed permissions and cleared delviks cache. Any one else have success fixing this?
#1130 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 669 posts
Posted 18 December 2012 - 12:54 PM
If you run into much problems don't expect much support if you are not using the version of SS mentioned in the OP.
  • Rootuser94 likes this
#1131 beerman1373
beerman1373
  • 20 posts
Posted 18 December 2012 - 01:05 PM
Got it !! Will update to SS3 and report back.
#1132 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 669 posts
Posted 18 December 2012 - 01:10 PM
It's just a lot of Devs will state that in their OP...no support or limited support if not following their statement. ;)
#1133 joshxdroid
joshxdroid
  • 162 posts
Posted 18 December 2012 - 01:13 PM
You'll love safestrap 3 anyways. it's touch screen, and performs wipes a lot faster. I updated from 2.11 because I wanted to flash this Rom, but now I wonder why I waited.
#1134 ReSuReKtZ
ReSuReKtZ
  • 138 posts
Posted 18 December 2012 - 02:34 PM
That's what I said when I updated the only reason I didn't want to was because you had to wipe your rom
#1135 samwelborn
samwelborn
  • 21 posts
  • Twitter:@samwelborn
Posted 18 December 2012 - 03:25 PM
this
#1136 caseyk44
caseyk44
  • 15 posts
Posted 18 December 2012 - 04:41 PM
When I open or close a folder from home screen the phone talks to me. How do I turn this off?
#1137 joshxdroid
joshxdroid
  • 162 posts
Posted 18 December 2012 - 05:00 PM
Probably a setting in accessibility
#1138 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • LocationPA
Posted 19 December 2012 - 07:11 AM
Answer the Poll at the top of the page regarding dis rom's future please :)
#1139 beerman1373
beerman1373
  • 20 posts
Posted 19 December 2012 - 07:40 AM
So, I dint end up upgading to SS3 YET ( I will be) but everything seems t be working now except for things that are already known such as mms. I ended up adding a new folder again in DCIM and moving all the PICs and I no longer have the External SD Card error. All is well and the Rom flippin rocks. I am not going to bring up any minor things I found until I update to SS3 and re-install.
Edit Edit Edit --- So I thought all was well with Using the Older version of SS. I was wrong lol. Curiosity finally got the best of me and I updated SS2 to SS3 and re-Installed the ROM. Well blow me down! ALOT different lol.. Set up was different and I noticed the Gallery Icon was different. Little glitches i noticed that are hard to explain are now gone. Have not verified the ability to receive MMS but will figure it out eventually. SOOOOO in short do as the OP says and use SS3.
#1140 reese
reese
  • 18 posts
Posted 19 December 2012 - 08:47 AM
I have just voted! It was a very hard decision.
