1389 replies to this topic
#1021 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • Twitter:@Rootuser94
  • LocationPA
Posted 13 December 2012 - 05:28 AM
I wonder if I could flash the fixed mms to another CN rom. Hmmm. ..
But why would you ever want to silly :P
#1022 joshxdroid
joshxdroid
  • 162 posts
Posted 13 December 2012 - 05:39 AM
Don't worry, wizzed will remain in a rom slot. But I need my crackflash fix. :) and what's the point of safestrap 3 if you only use one rom
#1023 escobardiablo
escobardiablo
  • 6 posts
Posted 13 December 2012 - 07:14 AM
Thanks for this rom this is great..
im still having the same trouble with mms i have try wiping everything and and re downloading and nothing i love the rom but i need my pics is there anything i can do please help thanks..
#1024 kbuck13
kbuck13
  • 105 posts
Posted 13 December 2012 - 08:05 AM
I have applied your MMS fix to my installation of CM 10-20121212-UNOFFICIAL-spyder with wiping both cache and Dalvik + fixed permissions and it works thank you for the fix!
I'm not sure if this will work for everyone on a CM 10 rom or not.
#1025 hd0120
hd0120
  • 65 posts
  • LocationUSA
Posted 13 December 2012 - 10:29 AM
Fixed MMS send button theming and Updated some stuff in OP! New mms flashable zip is in same spot but labeled with todays (12-12) date! :) Enjoy
The new MMS flashable zip works fine. To be able to send MMS texts, wipe both cache and Dalvik then fix permissions after flashing the zip file.
Thanks a lot, Rootuser94.
  • Rootuser94 likes this
#1026 joshxdroid
joshxdroid
  • 162 posts
Posted 13 December 2012 - 11:23 AM
I applied the fixed mms to black widow CN Rom and it doesn't send mms still. Works great in wizzed however :)
#1027 inssane
inssane
  • 38 posts
Posted 13 December 2012 - 12:50 PM
I tried the gallery rename for the camera FC and it worked once, now it doesn't work again.
I renamed "camera" to "camera1" and the camera worked right away, it just reassigned a default "camera" folder, with the one new pic I took in there.
Just doesn't work now, not sure what else to do.
#1028 joshxdroid
joshxdroid
  • 162 posts
Posted 13 December 2012 - 01:00 PM
Try clearing the data and cache from gallery
#1029 inssane
inssane
  • 38 posts
Posted 13 December 2012 - 01:05 PM
Funny you responded just as I did this.
Just clearing cache didn't work - clearing data did work. I hope I don't have to keep doing this though.
Just as a side note, did anyone notice that when you take a picture, not zoomed, then look at it in the gallery, there is "more picture" than what you thought you had in the frame?
It's almost forcing me to crop some photos. Any way around this?
#1030 raw57
raw57
  • 37 posts
Posted 13 December 2012 - 03:16 PM
Is anyone else having trouble with gapps force closing
#1031 admiralriker
admiralriker
  • 11 posts
Posted 13 December 2012 - 03:17 PM
I have an interesting bug. When sending a text from a 3rd party program like handcent, when I put someone's name into the To: section, when it shows my matches for the name the list is blacked out. The numbers are visible, but the names are totally blank.
#1032 ReSuReKtZ
ReSuReKtZ
  • 138 posts
Posted 13 December 2012 - 05:39 PM
I'm loving this Rom, even though i cant figure out the issue with S voice but i can deal with it since i won't really use it anyways.
#1033 ReSuReKtZ
ReSuReKtZ
  • 138 posts
Posted 13 December 2012 - 06:06 PM
Sorry about posting alot in your thread with problems. But i flashed the MMS fix on a fresh install and it didnt work, any ideas?
#1034 LukeB5301
LukeB5301
  • Twitter:@LukeB5301
Posted 13 December 2012 - 06:19 PM
Got this on my Razr today and it works great.. Love it! MMS not working but haven't tried fix yet...
Question:
Going to put this on my GFs RAZR, and she doesn't have a SDcard. Can I put my SDcard in her phone to do the Root & Flash then take my SDcard back or do you always have to have the SDcard??
#1035 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • LocationPA
Posted 13 December 2012 - 06:51 PM
Wipe cache, dalvik cache and fix permissions. Then flash the mms fix and do all 3 things again and reboot
#1036 ReSuReKtZ
ReSuReKtZ
  • 138 posts
Posted 13 December 2012 - 07:14 PM
Thanks that worked!
#1037 fatmando2
fatmando2
  • 235 posts
  • LocationMichigan
Posted 13 December 2012 - 07:18 PM
Really like this rom, but a couple things.. I installed the fix for the mms and now the theme is light and I see no option to switch back to the dark theme also there are white boxes around the timestamps.. is that just how it is? Also I can't figure out how to change the equilizer with the ac!d mod.. sorry I'm a noob :P
#1038 desireaftergod
desireaftergod
  • 536 posts
  • LocationNH
Posted 13 December 2012 - 07:41 PM
as soon as hashcode's screen rotation fix starts showing up in these JB builds I may be rocking this for a while. Very unique concoction you've whipped up for us. Thanks for the work man!
I dig the new boot animation as well
+1
#1039 phrite
phrite
  • 25 posts
  • LocationEast Texas
  • Current Device(s):Razr, Nexus 7
Posted 13 December 2012 - 08:26 PM
I love this rom, have not had a single problem with it since update. MMS working fine on my end, have not used the mms fix.
#1040 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • LocationPA
Posted 13 December 2012 - 09:04 PM
For now it is lolz, The mms apk will be rethemed in the next update, but for now in order to get fixed mms you'll have to deal with the white :P
