yeah it was mentioned. It's a theming problem. It's there next to to text box. Its just white on white so you can't see it, but it's useable.Is anyone else missing the "send" button on your keypads after the MMS fix?
#1001
Posted 12 December 2012 - 01:20 PM
#1002
Posted 12 December 2012 - 01:22 PM
#1003
Posted 12 December 2012 - 01:26 PM
#1004
Posted 12 December 2012 - 01:57 PM
I get it on quick reply, but in full view I ca see it just fine.
#1005
Posted 12 December 2012 - 02:44 PM
that's weird cause I can see it in quick reply but not in full view. Did you flash the fixed version? That's when the problem started for meI get it on quick reply, but in full view I ca see it just fine.
#1006
Posted 12 December 2012 - 04:42 PM
Yea flashed everything, full view is a black bar and white arrow, quick view is white bar and white arrow.
Disregard I thought the fix was flashed but it wasn't. O well, I'm going to try to download a theme and see if that fixes it.
Ok themes does not fix it, we will just have to wait for another update, but hey MMS is working, that's good enough for me.
#1007
Posted 12 December 2012 - 04:55 PM
I see in the install directions it says:
2. Reboot into Safestrap 3 only!
Just making sure this is what I have, if not what do I need to do to get it? Thanks
#1008
Pudding camera also FC because of Gallery right after pic is taken,
Advice?
#1009
Posted 12 December 2012 - 05:22 PM
Quick question I just Rooted my Verizon Droid Razr using: Droid Razr Utility 1.82( )
If you haven't installed then no you don't have it. If you just rooted then you have SU access, which is needed to install SS 3.
#1010
Posted 12 December 2012 - 05:30 PM
If you used the utility to install the safe strap apk then you have 2.11. You'll want to uninstall that and install 3.05
#1011
Posted 12 December 2012 - 05:34 PM
This is for safestrap 3.05
#1012
Posted 12 December 2012 - 05:58 PM
Build 6 - camera won't open because Gallery force closes when I launch camera.
Advice?
#1013
Posted 12 December 2012 - 06:17 PM
Thanks dude worked for me. I just renamed the photo folder.
#1014
Posted 12 December 2012 - 06:32 PM
#1015
Posted 12 December 2012 - 06:38 PM
I also had to boot into safe strap and fix permissions so pics would show in my gallery (that seemed to fix the low storage notification too?)
#1016
Posted 12 December 2012 - 08:56 PM
- papanut and reese like this
#1017
Posted 12 December 2012 - 11:06 PM
#1018
Posted 13 December 2012 - 12:18 AM
#1019
Posted 13 December 2012 - 12:39 AM
#1020
Posted 13 December 2012 - 05:13 AM
I wonder if I could flash the fixed mms to another CN rom. Hmmm. ..
might work..but keep in mind it is the MMS apk from the galaxy note 2
11 user(s) are reading this topic
0 members, 11 guests, 0 anonymous users
