1389 replies to this topic
#981 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 669 posts
  • Twitter:@MrFrankReyna
  • Google+:frankreyna
  • LocationSoCal, USA
Posted 11 December 2012 - 10:19 PM
How do I get Google Now to show up? And, the default weather widget does not find any location.
#982 tmyinc
tmyinc
    Resident Insomniac
  • News Writer
  • 1,276 posts
  • Twitter:TMYINC
  • LocationPA
Posted 11 December 2012 - 10:20 PM
How would I go about installing the host files for ad blocking from ROM toolbox if there is apparently no room to install the hosts?
Use adaway. Go to preferences, target host files and switch the location to
/data/data/hosts.
Sent from my DROID BIONIC using Xparent ICS Tapatalk 2
#983 droidrazrkid
droidrazrkid
  • 112 posts
Posted 12 December 2012 - 02:50 AM
ok so idk wats wrong but none of my music shows on any music player apps please help and yes i tried wiping data and etc
#984 mdowney916
mdowney916
  • 28 posts
Posted 12 December 2012 - 05:31 AM
Rootuser.....this ROM is amazing! Speed and battery life and one of the first ROMS I have not had an mms problem on. I cannot say enough good things about it....there's always a but though isn't there. :) The only thing I can point out is after the MMS update zip the button to send the text is white against the white background so you can no longer see it. Works just fine though. Anyways thank you for all your hard work on this ROM.
#985 joshxdroid
joshxdroid
  • 162 posts
Posted 12 December 2012 - 05:51 AM
MMS should be now Fixed! Flash the new update zip in the OP! Also added new sms bubbles and updated OP
You sir are the freaking master! When I get the funds, a donation will be headed your way. Thanks for your work
#986 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • Twitter:@Rootuser94
  • LocationPA
Posted 12 December 2012 - 05:56 AM
I'm going to retheme the app then, but i wanted to get it out to you guys ASAP.
#987 atcjeff
atcjeff
  • 52 posts
  • LocationCleveland, Ohio
  • Current Device(s):Droid Razr XT912
Posted 12 December 2012 - 07:10 AM
Go to setting>location access and make sure access to my location is on. Also make sure ur GPS or other location services is enabled
Remember, crowded elevators smell different to midgets.
#988 pm1066
pm1066
  • Validating
  • 140 posts
Posted 12 December 2012 - 07:22 AM
The mms fix has done something with the color scheme. The send button isn't visible anymore. It's still there, just can't be seen.
#989 dubsx
dubsx
  • 400 posts
  • Twitter:dubs_x
  • LocationThe OH
Posted 12 December 2012 - 07:34 AM
as soon as hashcode's screen rotation fix starts showing up in these JB builds I may be rocking this for a while. Very unique concoction you've whipped up for us. Thanks for the work man!
I dig the new boot animation as well ;)
#990 mdowney916
mdowney916
  • 28 posts
Posted 12 December 2012 - 07:36 AM
Haha insert foot in mouth....well like i said I appreciate the work so much and appreciate it even more you wanted to get this out so fast. Big thanks.
#991 joshxdroid
joshxdroid
  • 162 posts
Posted 12 December 2012 - 07:39 AM
It's not a huge deal, everyone knows where the send button is. :)
#992 sibley
sibley
  • 32 posts
  • LocationFort Bragg, NC
  • Current Device(s):Motorola Droid Razr XT912
Posted 12 December 2012 - 10:08 AM
This ROM is awesome. Major Props Dude. Thanks!
  • Rootuser94 likes this
#993 saycbone
saycbone
  • 68 posts
Posted 12 December 2012 - 10:31 AM
Added the mms fix and xperia keyboard fix..all well except no Notification Light (it is checked in Display)..
Anyone having issues with the Notification Light?
Thanks..
c
#994 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • LocationPA
Posted 12 December 2012 - 11:06 AM
Thanks..
c
Check in your messaging settings or in, settings/interface/ display/ notification light and make sure its checked
#995 reese
reese
  • 18 posts
  • Twitter:reesemitchell
  • Google+:reese.mitchell
  • LocationShreveport,LA
Posted 12 December 2012 - 11:09 AM
Thanks..
c
I have not tested the notification light YET. But I have been having trouble with the new audio system AC!D/beats ect... not wanting to work. After a notification sound go thew. The first thing I am going to do is format/wype.... ect.... to see if it is me and not a bug.If it is a bug I am sure it is an easy fix. BTW with the Notification light can you be more specific. like are you getting lights? are you just not getting the color your choosing. is it not blinking. ect...
#996 Papasmurf
Papasmurf
  • 135 posts
Posted 12 December 2012 - 11:31 AM
I want to give this ROM the shot but can't get it to download from the link in the OP. Is there a mirror somewhere?
If DROID DOES..... then iDroid
#997 dhayman11
dhayman11
  • LocationSan Diego
  • Current Device(s):Galaxy Nexus
Posted 12 December 2012 - 11:35 AM
Anybody know how to turn on the RAM usage in the recents window? Is that available on this build?
#998 joshxdroid
joshxdroid
  • 162 posts
Posted 12 December 2012 - 11:41 AM
Are you trying to download it straight to your phone? Just always have trouble downloading from devhost because the download status doesn't show up in my notification bar until it's finished. So unless it's a small file where I wait for a minute to see if it shows up. I never know if it failed or something. So I just go on a pc and download rom files straight to my dropbox folder, then either transfer it via usb or from the dropbox app.
#999 saycbone
saycbone
  • 68 posts
Posted 12 December 2012 - 12:26 PM
Works!! thanks a lot..excellent Rom here..
i had Notification checked , a reboot and wipe seems to have fixed the issue. The light blinks white..is there somewhere to change the color?
c
#1000 ibdabigdog
ibdabigdog
  • 20 posts
Posted 12 December 2012 - 01:17 PM
Is anyone else missing the "send" button on your keypads after the MMS fix?
