#961
Posted 11 December 2012 - 12:11 PM
#962
Posted 11 December 2012 - 01:00 PM
- GNOM likes this
#963
Posted 11 December 2012 - 02:15 PM
- joshxdroid likes this
#964
Posted 11 December 2012 - 02:23 PM
I've been having fc on alarm clock. Its on slot 3 do I need to be on slot 1 or what. I wiped them all and even tried dalvik and cache wipe a few times to no avail
Well I redownloaded the file and all is good.
- Rootuser94 likes this
#965
Posted 11 December 2012 - 02:46 PM
Might be a setting you need to changei dont know if this has been said already but, S voice won't speak back, it will pop up with what it says but wont actually "speak"
Glad all is good with the worldWell I redownloaded the file and all is good.
#966
Posted 11 December 2012 - 02:52 PM
#967
Posted 11 December 2012 - 03:28 PM
Fully wipe silly, you didnt read the Q and A lolzDo we need to do a total wipe if coming from cnv or can we wipe cach/dalv?
- dadof10 likes this
#968
Posted 11 December 2012 - 03:31 PM
So far the WiFi tether fix does not work for me. installed wifi tether for root users, made the changes as stated in OP but it still does not work for me. Can't get it to show up an any of my other devices, tablet, laptop etc. so far that's my only disappointment. anyone with other suggestions?
same
wifi to usb tethering not work
#969
Posted 11 December 2012 - 04:24 PM
did you reflash to get Svoice to work
#970
Posted 11 December 2012 - 05:54 PM
checked everything wiped both caches, did nothing, going to redownload and try a reflash maybe it was a bad flash since GPS is acting funnyMight be a setting you need to change
#971
Posted 11 December 2012 - 06:31 PM
EXCELLENT job. Has better features than my SG3! (You should really dev for that device )
#972
Posted 11 December 2012 - 07:00 PM
If i ever can get one i would like toThis is really impressive. First rom I've flashed on a RAZR since Arctic.
#973
Posted 11 December 2012 - 07:52 PM
#974
Posted 11 December 2012 - 07:57 PM
#975
Posted 11 December 2012 - 08:42 PM
Thank you sir, support is mucho appreciated!This is by far the most impressive ROM work I've EVER seen. You've literally covered every possible base. This will be my daily driver until my upgrade in a year and a half. I will eventually be donating- a little strapped for cash this week though. Thanks for the dedication!
#976
Posted 11 December 2012 - 09:27 PM
#977
Posted 11 December 2012 - 09:30 PM
Thanks a bunch man!I just sent donation. When I first flashed the ROM camera flash did not work and camcorder would FC every time I tried to record. I followed advice and deleted all picture folders on both sd card and internal storage then rebooted. No more FC when recording.
#978
Posted 11 December 2012 - 09:50 PM
- BrianKLV likes this
#979
Posted 11 December 2012 - 10:07 PM
#980
Posted 11 December 2012 - 10:11 PM
Ads should be blocked already, but id try using adaway insteadHow would I go about installing the host files for ad blocking from ROM toolbox if there is apparently no room to install the hosts?
