#761
Posted 21 November 2012 - 02:34 PM
I noticed I'm getting a wake lock every time i connect to my Wi-Fi. Which hits the battery hard of course. What can i do to fix this. What can i edit? Lol
#762
Posted 21 November 2012 - 04:52 PM
Wifi sleep policy under wifi>settings>advanced?Question..
- Badger50 and Rootuser94 like this
#764
Posted 21 November 2012 - 07:30 PM
#765
Posted 21 November 2012 - 07:31 PM
Yeah dont know why this happens..... Just a little annoying lolStill loving this rom. One thing I noticed was moving apps to my sdcard removed them from my desktop. It confused me at first when several apps I put into folders were suddenly missing.
#766
Posted 21 November 2012 - 08:53 PM
Keep Wi-Fi on during sleep is set to never
#767
Posted 22 November 2012 - 10:24 AM
- Rootuser94 likes this
#768
Posted 22 November 2012 - 11:01 AM
#769
Posted 22 November 2012 - 11:30 AM
Camera worked at first, but I used SS3 to fix permissions and the camera won't load at all, "Unfortunately, Gallery has stopped". Wonder what happened?
Also, don't see where I've got the 4.2 keyboard?
When you're entering text anywhere, you just pull down from notification bar and select input method. should be the second input method bro.
#770
Posted 22 November 2012 - 01:36 PM
is there a way to get the stock camera to work or is there a different camera app that you can get from the market that will work with this rom? It is kind of a deal breaker to have a rom that you cant get any camera to work on.
The ROM comes with camera fx in addition to the stock. Stock camera works perfectly for me including FFC. Only flash is not working but then I use the fx camera if I need flash.
Sent from my XT912 using Xparent Purple Tapatalk 2
#771
Posted 22 November 2012 - 01:56 PM
I also finally got all media apps to recognize my 64 GB SD card, though it took some manipulation to make it work.
#772
Posted 22 November 2012 - 02:14 PM
I've never had this issue, and per the Market I have G Voice Search "installed"....
Any help here? I use my voice to type every day direct from my keyboard. Yes my setting to enable the voice type button is set to on in the settings.
#773
Posted 22 November 2012 - 03:36 PM
#774
Posted 22 November 2012 - 04:08 PM
#775
Posted 22 November 2012 - 04:13 PM
#776
Posted 22 November 2012 - 04:17 PM
Its a known issue and is listed in the bugs section in the OPCamera works, flash timer is off. When taking a picture, it flashes, but the camera takes the pictures seconds after the flash. This is using FX camera. Just making it know.
Not having this issue, did you try like an app like audio manager in the market to check the media and normal phone volume?The Speakerphone volume is low as well when turned to highest level..
#777
Posted 22 November 2012 - 05:10 PM
I saw the post. I just read some had the occasional success so, just throwing it out for information sake. Good job on it.
#778
Posted 22 November 2012 - 07:36 PM
#779
Posted 22 November 2012 - 08:11 PM
#780
Posted 22 November 2012 - 08:12 PM
Nope, still works fine for me. Keep tryingI tried a dev host link from Hashcode for something else and it works fine, did you deactivate your link?
- possnfiffer likes this
