1389 replies to this topic
#741 Alex.Abraham
Alex.Abraham
  • 477 posts
  • Twitter:aabraham123456
  • LocationNew Jersey
Posted 20 November 2012 - 08:49 PM
If there are any GSM users here in this thread and would like to test a GSM version of Wizzed Bean please message me!
I don't need a GSM version but if you could edit the build.prop and change the default network to 3 and delete all the LTE stuff that would be awesome :)
#742 omihead
omihead
  • 5 posts
  • LocationWashington DC Metro
Posted 21 November 2012 - 05:07 AM
Has any one had issues with WI-FI not working at all after Flashing this rom?
It tries to connect and just sits there and then bombs out, I tried another JB ROM and it did the same thing.
But when I restore my ICS backup it works with no problem.
I did a factory restore, wiped cache, fixed permissions but all with the same results.
This ROM is SICK but I can't use it at my Daily if Wi-FI doesn't work
#743 pm1066
pm1066
  • Validating
  • 140 posts
Posted 21 November 2012 - 05:12 AM
Well, this was interesting. I was syncing media last night, and found the ROM was wiped overnight. As in, it looked like a fresh install. Very weird. and I was this close to making it a daily driver...
#744 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • Twitter:@Rootuser94
  • LocationPA
Posted 21 November 2012 - 05:31 AM
Did you do something?, i'm pretty sure it probably wasn't the roms fault.
  • MrFrankRazr likes this
#745 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • LocationPA
Posted 21 November 2012 - 05:32 AM
You need to do a factory reset twice, wipe cache, wipe dalvik cache, Wipe System and then go back and install the rom and then install the gapps. Then reboot
#746 omihead
omihead
  • 5 posts
Posted 21 November 2012 - 05:35 AM
I will give this a shot and I will let you know the results. thank you for the quick response
#747 bolden88
bolden88
  • 38 posts
Posted 21 November 2012 - 05:56 AM
Grand Wizzed Bean: You said we shouldn't have Play Music and you imbedded Beats into the ROM. If I uninstall Play Music what shoudl I use as my music player to get the effects of the imbedded Beats? I want the full use of your hard work. I don't care about the little issues people think they are having, this ROM ROCKS !!! Best I ever used.
  • Rootuser94 likes this
#748 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • LocationPA
Posted 21 November 2012 - 06:11 AM
Thanks a bunch man, Beats and Dolby audio is imbedded in the rom and should work with any music player. I had said that i didnt include the app (Play Music) into the rom, but it still should work!
#749 bobcat54s
bobcat54s
  • 32 posts
Posted 21 November 2012 - 06:21 AM
What's he stock music player in this? I Shawn google play, but an earlier post said google play wasn't supposed to be there. Just wondering.
#750 bobcat54s
bobcat54s
  • 32 posts
Posted 21 November 2012 - 06:22 AM
Stupid autocorrect. Google play is in my apps, but an earlier post said it shouldn't be there. So what's the music player for the new version of the rom?
#751 omihead
omihead
  • 5 posts
Posted 21 November 2012 - 06:27 AM
Awesome that worked, so now I have Wi-FI and data connectivity. I am able to use Bluetooth to stream music, but there is still a bug in regards to Bluetooth calls right?
#752 bobcat54s
bobcat54s
  • 32 posts
Posted 21 November 2012 - 06:28 AM
Sorry, I just read the above posts about my question. Sorry again.
#753 twith70
twith70
  • 180 posts
Posted 21 November 2012 - 06:34 AM
In the next version would it be possible to do something about the cartoon images in the weather panel on the lockscreen? I enjoy the weather feature but it looks awful with those images. Other than that this ROM is smooth and fast. Takes some getting used to after running other ROM's but it is definitely unique. Great job on the ROM and updates!
#754 garywojdan81
garywojdan81
  • 633 posts
  • Twitter:gwojdan_81
Posted 21 November 2012 - 08:29 AM
All the CNA builds I've tried have used the CM10 weather style instead of the detailed aokp version. IMO the aokp looks nicer.
#755 Papa T
Papa T
    ROM Flashaholic
  • 188 posts
  • Twitter:@JTHardee
  • LocationDouglas (South Georgia)
Posted 21 November 2012 - 11:33 AM
Should definately have 4g. You can try toggling network modes, wiping cache and or reflash the rom
Toggling the network modes did the trick. Once I did that, it immediately picked up 4g. Thanks for the advice.
#756 pcavuoto
pcavuoto
  • 63 posts
  • Twitter:pcavuoto
Posted 21 November 2012 - 11:48 AM
Is anyone else having random freeze ups? I've already had to restart my phone (holding both volumes and power) a few times today. I followed the flashing directions to a T and am running the hotplugx governor
#757 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • LocationPA
Posted 21 November 2012 - 11:52 AM
Try pegasusq governor
#758 omihead
omihead
  • 5 posts
Posted 21 November 2012 - 01:14 PM
I
I stand corrected, Wi-Fi is still not working, at home now and it is doing the same thing. Did the factory reset twice, wiped everything and reinstalled twice with the same results. I put my ICS ROM back on to test and the wireless works
Reflashed ROM again after the wipes, reset my router with the same results...
#759 pcavuoto
pcavuoto
  • 63 posts
  • Twitter:pcavuoto
Posted 21 November 2012 - 02:17 PM
I'm still getting freeze ups with pegausq. I've forced rebooted my phone twice already with it. Hmm
#760 crbdenver
crbdenver
  • 30 posts
  • Twitter:ChuckBanning
Posted 21 November 2012 - 02:23 PM
Camera worked at first, but I used SS3 to fix permissions and the camera won't load at all, "Unfortunately, Gallery has stopped". Wonder what happened?
Also, don't see where I've got the 4.2 keyboard?
