1389 replies to this topic
#661 Zack
Zack
    Developer
  • 94 posts
  • LocationArkansas
  • Current Device(s):OG Razr
Posted 16 November 2012 - 08:00 AM
It appears that this only happens when I call *228 to update roaming. All I have is a BACk button and a SPEAKER button. I don't seem to have the same coverage as when I was on stock. Thought I could try update roaming.
Try the menu button and see if the dial pad comes up. Seems like that worked on the old INC
Why do I love jacking with my phone so much??
#662 o0kot0o
o0kot0o
  • Google+:o0kot0o@gmail.com
Posted 16 November 2012 - 08:31 AM
This thing is really fast.. I like it.. GJ
#663 the.internet
the.internet
  • 31 posts
Posted 16 November 2012 - 10:03 AM
I've had a few freeze-ups running pegasusq, seemed to only happen when unlocking (would type in my PIN, and then it would just freeze). Going back to default settings, as I never had an issue on the other versions and I never messed with that.
One small bug I noticed, I've been using my Nav nonstop in Newark (here on business, and I'm so lost without it, it's not even funny), and for some reason, the media volume was super low for the voice directions. I must have turned it down while on YouTube or Pandora, but when I went into Audio Settings, it showed the media volume all the way up. Changing it, and then setting it back to max corrected it. Not a big deal, just thought I'd share. Haven't had a chance to replicate yet.
#664 bolden88
bolden88
  • 38 posts
Posted 16 November 2012 - 11:46 AM
Does the Nav use the Beat booster? This caused the opposite effect with music. New sound = max volume. Upon turning down it would go super low. Check out Post 531 for Beats fix. This may help you also on the Nav.
#665 bolden88
bolden88
  • 38 posts
Posted 16 November 2012 - 11:50 AM
I tried all the hardkeys for the dial pad fix. No success. Does anyone know if you still need to update roaming capabilities? I have heard it is not necessary. I seemed to had slightly better reception on stock so I thought I would try update roaming. This is by far Not a deal breaker for Wizzed Bean. This is the best. If you are researching what ROM to flash and read these post, ignore and just flash Wizzed Bean.
  • Rootuser94 likes this
#666 deejay1111
deejay1111
  • 37 posts
Posted 16 November 2012 - 05:49 PM
It is my understanding that using *228 to update your PRL on LTE phones will not work as the sim card does this for you. I have heard that if you feel like your roaming capabilities have not been updated you can turn off the phone and pull out the sim card, reinstall it, and power your phone back on. Not sure if this method is just Verizon's way of making someone feel as though everything is up to date or if it actually helps ha ;P Just be careful not to touch the connections on your sim card. Hope this helps :)
  • sirphobos likes this
#667 deelorr
deelorr
Posted 16 November 2012 - 10:14 PM
It doesn't recognize the internal storage at all? Or am I missing something? Probably.
#668 team420
team420
  • 24 posts
Posted 17 November 2012 - 04:56 AM
OK...so out of the blue yesterday 4g starts working... I checked, and network mode was lte/CDMA/evdo...
Pretty sure i tried this mode before with no luck, but now it works!!
Now everything is working fine here!
Thanks for a most excellent rom :-)
#669 Alex.Abraham
Alex.Abraham
  • 477 posts
  • Twitter:aabraham123456
  • LocationNew Jersey
Posted 17 November 2012 - 07:43 AM
I am using a RAZR XT912, its just unlocked. Can I flash GSM Roms?
#670 thevillageidiot
thevillageidiot
  • 104 posts
  • LocationOmaha, NE
Posted 17 November 2012 - 07:58 AM
No. You'll bootloop
#671 Alex.Abraham
Alex.Abraham
  • 477 posts
Posted 17 November 2012 - 08:48 AM
Ya that's what I thought. So how would I solve my issue of APN settings not taking effect?
Weird thing: If OEM and getIEMI are both off, APN settings appear to be blank but any other combination of the two settings and the APN settings are visible
#672 jonniec34
jonniec34
  • LocationOver Yonder
Posted 17 November 2012 - 09:04 AM
Absolutely in love with this ROM. Best ROM I've flashed so far! Thank you for the beautiful work!
#673 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • Twitter:@Rootuser94
  • LocationPA
Posted 17 November 2012 - 09:21 AM
Thanks man, glad you like it and Enjoy!
#674 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 669 posts
  • Twitter:@MrFrankReyna
  • Google+:frankreyna
  • LocationSoCal, USA
Posted 17 November 2012 - 10:25 AM
Yep,, this ROM is very smoovvv! Very snappy and fluid. My DD for a long time!
#675 cgrass12
cgrass12
  • Twitter:@cgrass87
Posted 17 November 2012 - 03:45 PM
Still having a lot of fc with this.....thoughts ? Anybody help me get at me on twitter @ cgrass87
#676 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • LocationPA
Posted 17 November 2012 - 04:07 PM
Did you follow op directions exactly, try wiping cache and dalvik
#677 somefknguy
somefknguy
  • 12 posts
Posted 17 November 2012 - 08:09 PM
loving the rom, loving it even more since BT works! however, its extremely quiet when paired to my truck's deck...is there a way to boost the volume?
#678 osnoozeo
osnoozeo
  • 108 posts
Posted 18 November 2012 - 11:12 AM
Hey just wanted to say thank you. I get my note 2 in 10days or so, and I'm getting my wife gs3 black Friday. She's got facinate so it was nice to show her what her phone will be like. Best from I've used in long long time . Great work
#679 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • LocationPA
Posted 18 November 2012 - 11:30 AM
Thanks man, feel free to send a Note 2 or Galaxy s3 over this way ;))
#680 Alex.Abraham
Alex.Abraham
  • 477 posts
Posted 18 November 2012 - 11:05 PM
Hey I realized that there are 2 ROM posts and I have been accidentally posting in both but this is the ROM I have.
Basically I need to edit build.prop to change default network mode from 10 to 3 and also delete all the LTE stuff in build.prop to get data working in Israel.
Can someone with experience in build.prop do this for me? I love this ROM but I can't use it without data! :'(
