1389 replies to this topic
#601 team420
team420
  • 24 posts
Posted 12 November 2012 - 06:00 AM
LTE is definately working, Try wiping cache and toggling network modes in the settings
Yep... still no lte for me. Tried wiping cache's, toggling network modes etc... no luck. When I put it in lte only mode, I get no signal at all, tried rebooting in lte only mode to no avail... Any thoughts b4 I revert to stock?
#602 Beckeramos
Beckeramos
  • 10 posts
Posted 12 November 2012 - 06:50 AM
[quotexact sae='team420' timestamp='1352728838' post='132156']
[/quote]
Yeah exact same thing with me. Tried everything. I'm fine with it is though cause I like the ROM. I don't need just the lte option.
#603 Bartando
Bartando
  • 12 posts
  • Twitter:bartando
Posted 12 November 2012 - 09:26 AM
OK now I'm doing great just my camera crash like every time ;DO some fix ?
#604 Kimo91
Kimo91
  • 148 posts
  • Google+:elton.k.sales@gmail.com
  • LocationGoose Creek, SC
Posted 12 November 2012 - 10:58 AM
So anyone know the fix for MMS? I used handcent and that didn't work for me at all on this ROM
Sent from my DROID RAZR using Xparent Red Tapatalk 2
#605 ibdabigdog
ibdabigdog
  • 20 posts
Posted 12 November 2012 - 11:31 AM
GoSms Pro works for MMS
#606 hd0120
hd0120
  • 65 posts
  • LocationUSA
Posted 12 November 2012 - 12:41 PM
Handcent works fine for me with this rom.
#607 Pinnacle
Pinnacle
  • 21 posts
Posted 12 November 2012 - 04:15 PM
Love the speed, feel and look of this ROM. But no navigation is the killer for me. I rely on the nav quite a bit.
#608 kevinl
kevinl
  • 10 posts
Posted 12 November 2012 - 04:17 PM
Navigation worked for me last night.
#609 kevinl
kevinl
  • 10 posts
Posted 12 November 2012 - 04:20 PM
4. Swype, for some reason, won't auto space or capitalize, regardless of settings.
I don't know if that is this ROM. I use Swype and have the same issue but only in xscope browser. Every other place it is fine. This was the same coming from KOA also.
#610 Pinnacle
Pinnacle
  • 21 posts
Posted 12 November 2012 - 04:22 PM
When I installed the ROM the other day I could not find the nav app at all. I didn't have Google Maps either. I was able to get maps from the store, but you can't get nav from the store.
#611 sativaman
sativaman
  • 43 posts
  • LocationVirginia
Posted 12 November 2012 - 04:29 PM
Nav is a part of Google map. This rom didn't come with Google maps but I downloaded it and Nav was also installed. I use it daily.
#612 Pinnacle
Pinnacle
  • 21 posts
Posted 12 November 2012 - 05:07 PM
In that case...... ROUND TWO!!!
#613 logan3824
logan3824
  • 308 posts
  • LocationHouston, Texas. GO TEXANS!
Posted 12 November 2012 - 06:03 PM
I would suggest using MapQuest...It actually closes when you close it and I find it locks on GPS faster. When you close GoogleMaps there is still processes that run in the background which in turn kill battery faster.
#614 Bartando
Bartando
  • 12 posts
  • Twitter:bartando
Posted 12 November 2012 - 06:10 PM
Just download some :) like Navigon or whatever :)
#615 sombersp
sombersp
  • 14 posts
Posted 12 November 2012 - 11:27 PM
When I use wifi it disables 4g so that means I can't recieve or send picture messages while on wifi. Any way around this?
#616 Badger50
Badger50
  • 241 posts
  • Google+:badger50@gmail.com
  • LocationKansas City
Posted 13 November 2012 - 03:24 AM
I run wifi all the time and have no difficulty sending MMS whatsoever. However, I do use Handsent as my messaging app which may be why. Sometimes the stock messaging app can be a little wonky, as I have found out for myself. With that said, I still think this Rom is awesome :-)
  • Rootuser94 likes this
#617 Pinnacle
Pinnacle
  • 21 posts
Posted 13 November 2012 - 03:45 AM
I appreciate the suggestion, but I have grown to really like the Google Navigation and it has never ever failed me. I have looked at other navigation apps in the market and for my taste, no other apps compare.
#618 Pinnacle
Pinnacle
  • 21 posts
Posted 13 November 2012 - 03:54 AM
Ok. I'm giving this another go today. I have some questions though. I want to make sure I don't hose my stock ROM again. I am new to Safestrap 3 and maybe there in lies the issue.
I have the ROM downloaded and residing on the root of my SDcard. I go into SS3. (This is where I need some guidance.) Do I create a ROM Slot first or do I do a factory reset on the stock ROM first? When I create a ROM slot, what is the suggested space needed? I think there are 3 options. 1GB, 2GB or 3GB.
Sorry for the noob questions, but I just want to be sure.
TIA
#619 pm1066
pm1066
  • Validating
  • 140 posts
Posted 13 November 2012 - 04:05 AM
TIA
The problem is all of the instructions we've seen so far written before 3.0 came out. You do not need to do wiping of the system or clearing of memory or full memory wiper any of that sort of stuff when you're using 3.0 and a new ROM slot. Basically, the act of creating a brand-new ROM slot gives you a completely fresh and new area to write the system in and to create your data in. Additionally, this ROM wipes system data and formats the cache and davlik cache itself so really all you need to do is create a new ROM slot and install.
#620 Pinnacle
Pinnacle
  • 21 posts
Posted 13 November 2012 - 04:10 AM
Ok. Cool. Thanks for the reply. Any suggestions or opinions what size the ROM slot should be?
