1389 replies to this topic
#541 jcherrick731
jcherrick731
Posted 09 November 2012 - 08:02 PM
Follow spchicks inductions in his thread it worked for me for the free WiFi tether app from the market you may have to go back to his ics ROMs to find the directions but i know i saw someone post them on this thread somewhere in the last few pages
#542 SyrStorm
SyrStorm
  • 65 posts
Posted 09 November 2012 - 09:07 PM
For the life of me I can't find that post, and also I should mention add a bug I guess that any photo editing from the gallery doesn't work and causes a force course
#543 tmyinc
tmyinc
    Resident Insomniac
  • News Writer
  • 1,276 posts
  • Twitter:TMYINC
  • LocationPA
Posted 09 November 2012 - 10:39 PM
Download the wireless tether app from the play store. Go into settings and change the device profile to generic ics/jb wlan0. Change the set up method to netd-ndc master. Scroll down and tick "routing fix". If all that doesnt work change the device profile from wlan0 to wlan1.
Sent from my DROID BIONIC using Xparent ICS Tapatalk 2
#544 tmyinc
tmyinc
    Resident Insomniac
  • News Writer
  • 1,276 posts
  • Twitter:TMYINC
  • LocationPA
Posted 09 November 2012 - 10:40 PM
This is the app
#545 chumboy
chumboy
  • 93 posts
Posted 10 November 2012 - 04:42 AM
Well, I'm pretty sure it has nothing to do with this ROM but I ran into an issue. I'm not even sure this is the proper place. But since it happened after installing this ROM I'm not sure where else to post.
I installed the ROM and really like it, but I needed to go back to my stock ROM for a few things. When I tried booting into my stock ROM the screen was all screwed up. I cannot see a thing and the screen looks like about a half inch line in the middle. Almost like everything is scrunched into that area. I did factory reset and wiped everything to no avail.
Anyone have any clue what might have happened? I am using Safestrap 3.
Thanks for any assistance.
I had the same thing happen to me...as the rom is booting, all the graphics are squeezed into a 1/2 inch rectangle in the middle of the screen...and same for the home screen when it finishes booting.
i spent about 8 hours trying to fix it and finally had to use nvflash to restore fastboot files...in other words, you need to go back to stock, then re-root, reinstall safestrap and reload a backup rom into one of the slots.
sorry for the bad news, maybe someone else can give you a less drastic method.
there are a few posts in the development section of this forum that will show you how to fastboot back to stock.
if you figure out a less drastic method, please let me know.
#546 sativaman
sativaman
  • 43 posts
  • LocationVirginia
Posted 10 November 2012 - 06:57 AM
Which governor do you guys think works the best with this rom? I know performance locks the processor to Max and sucks the battery dry. I've had the best quad scores using ondemand. It'd be nice to be able to set sio mode as well. I tried using system tweak to restore on boot completed but it made the phone really slow. I might try having sio set through the kernel exec instead and see what happens.
#547 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • Twitter:@Rootuser94
  • LocationPA
Posted 10 November 2012 - 07:29 AM
I like pegasusq governor
#548 theviper90210
theviper90210
  • 28 posts
Posted 10 November 2012 - 08:18 AM
Hey I have noticed on a few ROMs including this one that my hardware buttons don't light up like they used to. Is this a common problem or am I missing something.
#549 team420
team420
  • 24 posts
Posted 10 November 2012 - 08:20 AM
Is LTE working yet? I have tried just about every version of this rom, and got no 4g... Love the rom, but gotta have my lte.
#550 Pinnacle
Pinnacle
  • 21 posts
Posted 10 November 2012 - 08:42 AM
Thanks for the reply. Doesn't seem all that drastic really. Of course I haven't read how to do it yet. I guess I'll get crackin'.
#551 sativaman
sativaman
  • 43 posts
  • LocationVirginia
Posted 10 November 2012 - 08:54 AM
For everyone who can't change IO mode in the rom, I found a work around. Install System Tuner. Then set the IO mode in there and tell it to load through init.d. reboot the phone then uninstall system tuner. Now, you can pick whatever IO mode you want. You only need system tuner once than you can uninstall it.
#552 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • LocationPA
Posted 10 November 2012 - 12:36 PM
LTE is definately working, Try wiping cache and toggling network modes in the settings
#553 lxperius
lxperius
  • 34 posts
Posted 10 November 2012 - 02:59 PM
I keep having trouble with downloading files it usually starts downloading fine but after 30-70% it says download unsuccessful?
#554 nkendrick91
nkendrick91
Posted 10 November 2012 - 03:05 PM
File downloaded fine for me. Try a different browser or reset your internet connection.
You might need to clear your cache too. Or reboot your computer.
I just tried it and works fine.
#555 lxperius
lxperius
  • 34 posts
Posted 10 November 2012 - 03:07 PM
Im talking about on the phone, not my computer.
#556 nkendrick91
nkendrick91
Posted 10 November 2012 - 03:09 PM
Well, I don't seem to be having that issue either. I've downloaded quite a few files.
Sometimes, it is just where you are downloading the file from. The connection between you and the server where the file is could be having issues.
Not the phone but where you get the files from.
#557 SyrStorm
SyrStorm
  • 65 posts
Posted 10 November 2012 - 03:26 PM
You have to switch browsers to get it to download
#558 tyrate
tyrate
  • 30 posts
  • LocationVirginia
Posted 10 November 2012 - 03:27 PM
Love the ROM the only issue I've had has been with the IO scheduler but the system tuner work around worked for me. But i do wish that you'd included the weather panel for the notification bar and lock screen on it other than that awesome ROM.
#559 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • LocationPA
Posted 10 November 2012 - 04:09 PM
Go to settings/interface/lockscreen/weather and you will find what your heart desires
#560 Pinnacle
Pinnacle
  • 21 posts
Posted 10 November 2012 - 05:18 PM
I had the same thing happen to me...as the rom is booting, all the graphics are squeezed into a 1/2 inch rectangle in the middle of the screen...and same for the home screen when it finishes booting. i spent about 8 hours trying to fix it and finally had to use nvflash to restore fastboot files...in other words, you need to go back to stock, then re-root, reinstall safestrap and reload a backup rom into one of the slots. sorry for the bad news, maybe someone else can give you a less drastic method. there are a few posts in the development section of this forum that will show you how to fastboot back to stock. if you figure out a less drastic method, please let me know.
I used what I think was an extremely simple process to fix my problem. All I used was the RAZR Utility 1.82. Put my phone in AP Fastboot, ran the utility and chose option 1. The utility did the rest. Once it was done, maybe 10 minutes, I had a 100% stock out of the box RAZR with ICS 211. Then I used the utility to re-root and viola. The whole process took less than 30 minutes.
Just wish I knew what the heck I did to cause the issue in the first place so as to not repeat it.
  • Rootuser94 likes this
