Maybe reflash the gapps, they should be installing.I didn't see any Samsung apps and Chrome was not preinstalled. I had no issues with installing the ROM and everything is working well. I'll test my camera to see if I have any issues.
I did have the FC for the camera. I force stopped and wiped data for the gallery and camera works again. It seems that for me, when you have all those sweet options from touching the screen and select one of them, it will cause my FC. I haven't tried each one to see because that would be a lot of back and forth for wiping the gallery. Just some info from what I tested. Hope this helps.
Edit: Seems to be for me only trying to use the FFC causes the FC of the camera. Wiping gallery does work to restore camera function.
#501
Posted 08 November 2012 - 06:06 PM
#502
Posted 08 November 2012 - 06:07 PM
Its just an app that comes with the s3, you dont need to do anything with it if you dont want.I don't know about chrome, but the samsung apps were on the home screen waiting to be installed. I didn't install them because I don't know what they are.
#503
Posted 08 November 2012 - 06:28 PM
#504
Posted 08 November 2012 - 06:32 PM
I assumed the Samsung apps were part of the ROM. Didn't notice the desperate gapps file. I'll flash it soon.
#505
Posted 08 November 2012 - 07:28 PM
#506
Posted 08 November 2012 - 08:13 PM
I dont know if i can haha, I dont even have a razr so this one is hard enough. What is the GSM razr's name. Ie the regular razr is spyder so whats the gsm one?Hope a GSM Version for XT910 RAZR MAXX
#507
Posted 08 November 2012 - 10:42 PM
#508
Posted 08 November 2012 - 10:59 PM
The only thing that does not work for me is Skype Video Chat. But, hey you gotta give a little to get a whole lot!! Best Rom ever cheers!
#509
Posted 09 November 2012 - 12:10 AM
#510
Posted 09 November 2012 - 12:54 AM
Sent from my Droid Razr Maxx using Tapatalk2.
#511
Posted 09 November 2012 - 01:52 AM
Edit:
Where's my swagger toggle ;_;!!!!!
Without swagger this update is just 9.5/10 ;_;
- Rootuser94 likes this
#512
Posted 09 November 2012 - 02:33 AM
Hopefully that will get worked out.
#513
Posted 09 November 2012 - 04:36 AM
#514
Posted 09 November 2012 - 06:28 AM
#515
Posted 09 November 2012 - 06:49 AM
This is a known bug. Use gosms proHas anyone had success sending MMS?
#516
Posted 09 November 2012 - 06:51 AM
All these apps are working fine on my end with my 32 gb card. Try downloading "rescan SD" from Google play store.Overall good Rom, but as long as the camera, gallery, and music players can't see my external SD card, it's unusable.
#517
Posted 09 November 2012 - 07:14 AM
The GSM version is XT910...
I believe that you can flash this with SS3.05, I think so because we can flash on our xt910 the cm10 rom, just a warning you have to flash it as a 2nd rom or you will break!!! just go with the instillation order and after you flash gapps flash the gsm patch. it worked for me on flick 4 and cm10. thank you HSD-PILOT for given me the patch
#518
Posted 09 November 2012 - 08:06 AM
Thanks man, I think i may do a gsm version, shouldnt be too hardThe GSM version is XT910...
#519
Posted 09 November 2012 - 08:36 AM
#520
Posted 09 November 2012 - 09:12 AM
