Hahahah if only the wallpaper you are missing, then you are fine, i included them so just re set it once it boots upCan someone post a screenshot of the original set up screen please? Cuz the very first time I flashed it, I got a totally different set up screen from the other times, so I thought that was the correct setup. Maybe not. Maybe I've been wrong the whole time. I just don't understand why that when I flash the ROM, even after fastbooting to stock, this one wallpaper that I downloaded keeps sticking, even when I flash a new ROM.
#421
Posted 29 October 2012 - 04:53 AM
#422
Posted 29 October 2012 - 05:14 AM
This is the first ROM I've installed and it looks fantastic. The only bug I've discovered so far is that Auto Rotate will not stay on. I can toggle it on in the phone settings (device->display->auto-rotate screen, but as soon as I exit the settings, it reverts to being 'unset'. I even tried toggling it on and off in the Aokp settings. Has anyone else experienced this issue on an XT912?
Keep up the good work!
#423
Posted 29 October 2012 - 06:44 AM
Sent from my XT912 using Xparent SkyBlue Tapatalk 2
#424
Posted 29 October 2012 - 06:59 AM
I believe auto rotation is a bug in Aokp roms.
I appreciate the reply. I thought the bug had to do with the screen shrinking before rotation. I had no idea that it meant auto-rotate in general. Thanks for clearing that up.
#425
Posted 29 October 2012 - 07:06 AM
Actually auto rotate works, just go into the smart rotator app and disable it in the settings, it will work thenI appreciate the reply. I thought the bug had to do with the screen shrinking before rotation. I had no idea that it meant auto-rotate in general. Thanks for clearing that up.
#426
Posted 29 October 2012 - 07:44 AM
Awesome! Thank you for that. It's working great now! I hope Sandy doesn't get you too bad. The only thing I've gotten out of Sandy is a day off of work and being stuck in the house with the rugrats.
- Rootuser94 likes this
#427
Posted 29 October 2012 - 11:28 AM
#428
Posted 29 October 2012 - 12:35 PM
Its because it switches the ext sd to the regular sd and confuses all the players/gallery, so you have to go into like poweramp manually and select the music folders to usesorry if this has already been answered( i tried to look for the answer) ROM is great love it, my only issue is where did all my music go =( I can find everything fine via the file manager. but nothing shows up in Apollo or play Music. any suggestions would be handy. seems like my gallery is empty as well.
#429
Yeah i got some cancelled afternoon classes so that was rather niceAwesome! Thank you for that. It's working great now! I hope Sandy doesn't get you too bad. The only thing I've gotten out of Sandy is a day off of work and being stuck in the house with the rugrats.
#430
Posted 29 October 2012 - 12:58 PM
so there is no way to access my music unless i use this 3rd party app ? seems kinda silly to me. thanks for the quick reply thoughIts because it switches the ext sd to the regular sd and confuses all the players/gallery, so you have to go into like poweramp manually and select the music folders to use
#431
Posted 29 October 2012 - 01:59 PM
Hahah that was just an example, but just play around and try that type of stuffso there is no way to access my music unless i use this 3rd party app ? seems kinda silly to me. thanks for the quick reply though
#432
Posted 29 October 2012 - 05:58 PM
#433
Posted 29 October 2012 - 06:12 PM
#434
Posted 29 October 2012 - 06:13 PM
You can!has anyone tested on 2.11 yet?
#435
Posted 29 October 2012 - 06:14 PM
#436
Posted 29 October 2012 - 07:34 PM
#437
Posted 29 October 2012 - 07:54 PM
It probably does, whats the error?s voice doesnt work
#438
Posted 30 October 2012 - 09:02 AM
It doesn't for me either. My issue is you say something and the app freezes. Been that way since I flashed. Non issue for me but I am confirming it isn't an isolated incident.
#439
Posted 30 October 2012 - 11:54 AM
Hmm alrighty sorry about that, next version it shall be fixedIt doesn't for me either. My issue is you say something and the app freezes. Been that way since I flashed. Non issue for me but I am confirming it isn't an isolated incident.
#440
Posted 30 October 2012 - 01:39 PM
No biggie. Like I said for me it isn't an issue as I don't use that or Google now often. I am not one to complain about a port of a system when I can't do anything to help lol.
