1389 replies to this topic
#381 mike_augie
mike_augie
  • 74 posts
Posted 25 October 2012 - 01:00 PM
I am having problems sticking in boot. I have tried using safestrap 3.0.5 and 2.11. After i install rom and gapps, and restart it goes in to a boot loop and keeps flashing moto logo and the safestap enabled. When flashing ROM it only takes a sec or so for it to flash, seems to quick.
been running this for several days ... just checking a few things .. you did load safestrap on stock side correct and i verified that it works on both 211 and v304 and v305 without issue on any ... but if your bootlooping , u do need matts tool and just start fresh
#382 the.internet
the.internet
  • 31 posts
Posted 25 October 2012 - 01:56 PM
Also been running this for a few days. Gotta say, it's been great, very smooth, haven't really had any issues. Told RU94 I'd test battery out, and so far, here's my findings from today:
#383 hd0120
hd0120
  • 65 posts
  • LocationUSA
Posted 25 October 2012 - 02:16 PM
I just flashed 3.0 with SS2.11 with no issue.
Thanks a lot to Rootuser94 for such an excellent rom.
#384 jmack778
jmack778
  • 12 posts
Posted 25 October 2012 - 02:20 PM
I'm having issues when attempting to unlock the phone it will only work if I press the menu key. The slider doesn't unlock the phone.
#385 theviper90210
theviper90210
  • 28 posts
Posted 25 October 2012 - 02:24 PM
I was messing around with the slide lock screen apps and now I set it back to default 3 with the Google, camera, and unlock. But when u select unlock the lock screen just flashes and doesn't unlock. But Google or camera will unlock it. Any ideas on fix other than reflashing?
#386 the.internet
the.internet
  • 31 posts
Posted 25 October 2012 - 02:26 PM
Did you change the slider settings in the phone? When I went in and changed it to 5 shortcuts and went in to edit them, I had the same issue. If you look at the shortcut for the unlock icon, it shows a bunch of code, my guess is because it doesn't correctly identify with the unlock action (which is not available as an option when selecting an action from what I could see).
You may want to try resetting the lock screen back to default.
I was only able to fix by flashing.
#387 theviper90210
theviper90210
  • 28 posts
Posted 25 October 2012 - 02:41 PM
Yea I tried the same things as you. Looks like I might have to reflash.
#388 theviper90210
theviper90210
  • 28 posts
Posted 25 October 2012 - 02:49 PM
One other bug I notice is when u go to change the CPU governor and schedule. And click run on boot. Then when you reboot the phone the change you made does not stick, it goes back to default
#389 chumboy
chumboy
  • 93 posts
Posted 25 October 2012 - 02:58 PM
any luck with bluetooth phone audio?
i'm blown away by this rom and want to use it as my dd.
seem all jb roms have bt phone audio problems.
#390 flashman2002
flashman2002
  • 104 posts
Posted 25 October 2012 - 04:07 PM
Everyone will know once that is working. Until then, it is no different.
  • chumboy and Rootuser94 like this
#391 chumboy
chumboy
  • 93 posts
Posted 25 October 2012 - 05:23 PM
loud and clear.
#392 2EdgeSword
2EdgeSword
  • 8 posts
Posted 25 October 2012 - 06:56 PM
A little off topic here, but I need some serious help I think I soft bricked my phone. I'm in fastboot mode using DroidRazrUtility 1.42 and when i try to do a restore im getting "PreFlash Validation Failure"
#393 blaten22
blaten22
  • 194 posts
Posted 25 October 2012 - 07:37 PM
Update to Matt's new utility. I think it's 1.82? May help.
#394 kuroespino
kuroespino
  • 22 posts
  • LocationCalifornia
Posted 25 October 2012 - 08:06 PM
cant log into recovery with SS 3.05 . im on a fresh OTA ICS from Matts utility. gonna try to flash this with 2.11
edit:
was using the wrong Safestrap (droid 3 version).
Restored phone using matt's utility, and installed correct version.
Flashed rom and worked like a charm. Thanks for the great rom :D
#395 lxperius
lxperius
  • 34 posts
Posted 26 October 2012 - 02:29 PM
Is there a way to hide app names on the home screen?
#396 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • Twitter:@Rootuser94
  • LocationPA
Posted 26 October 2012 - 02:45 PM
no
#397 Rinkle McBally
Rinkle McBally
    Perv McGert
  • 860 posts
  • Twitter:Rinkle_McBally
  • LocationForest Lake MN
Posted 26 October 2012 - 03:21 PM
Different launcher
#398 kuroespino
kuroespino
  • 22 posts
Posted 26 October 2012 - 09:28 PM
having some issues with awesome beats audio. the audio effects seem to stop after I get a text, or a track changes. It fixes itself when i manually skip a track though. I've used 5 different audio players and this issue seems to persist. Gonna try to restore to ICS and reflash and to see if this keeps occurring.
Flawless JB ROM besides this minor bug
#399 medic7046
medic7046
  • 19 posts
  • Twitter:medicp7046
  • Google+:medic7046@gmail.com
  • LocationRichmong HIll, Ga
Posted 27 October 2012 - 02:41 AM
Got ROM flashed. Had a bad download...my question is...is it better to use the built in ROM control CPU settings or use ROM toolbox and what are the best settings?
#400 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • LocationPA
Posted 27 October 2012 - 05:02 AM
I dont think it matters. I recommend pegasusq governor and sio scheduler
