1389 replies to this topic
#361 Marcos915
Marcos915
  • 17 posts
  • Twitter:marx915
  • LocationEl Paso, TX
Posted 24 October 2012 - 09:10 PM
Just finished flashing and......Holy bouncing testicles batman! i have greatness on my phone....just GREATNESS
  • Mossyoak228 likes this
#362 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 669 posts
  • Twitter:@MrFrankReyna
  • Google+:frankreyna
  • LocationSoCal, USA
Posted 24 October 2012 - 09:59 PM
In SS 3.0.5, it is unable to open and flash the ROM 3.0 zip file.
#363 Badger50
Badger50
  • 241 posts
  • Google+:badger50@gmail.com
  • LocationKansas City
Posted 25 October 2012 - 02:49 AM
3.05 worked just fine here. Awesome work on the Rom buddy. Donation will be provided.....Happily. Thanks again :-)
#364 desireaftergod
desireaftergod
  • 536 posts
  • LocationNH
Posted 25 October 2012 - 02:51 AM
Yep, this is a very nice ROM! Even more smoother than before and more apps. TIBU all my apps and running very well. Nice work R94!
+1
#365 hd0120
hd0120
  • 65 posts
  • LocationUSA
Posted 25 October 2012 - 03:42 AM
Can I use SS2.11 to flash this rom? Thanks.
#366 2EdgeSword
2EdgeSword
  • 8 posts
Posted 25 October 2012 - 04:01 AM
Need a little help stuck in bootloader and dont know what happened. I uninstalled older version of safestrap and installed 3.5. When i went to reboot it brought up the intitial screen which had safestrap disabled and droid 3 in upper lefthand corner. When I select to boot into recovery it goes into the old traditional red eye bootloader for droid and stays there.
#367 twith70
twith70
  • 180 posts
Posted 25 October 2012 - 04:06 AM
I would suggest a fastboot back to stock with Matt's utility and start over. It sounds like you have the wrong version of SS installed as there are several versions out there.
#368 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • Twitter:@Rootuser94
  • LocationPA
Posted 25 October 2012 - 04:28 AM
Thanks a bunch man, your guys support is much appreciated!
#369 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • LocationPA
Posted 25 October 2012 - 04:35 AM
See if you have checked, check for verification and like md5 everytime or something like that, i was having that problem if i didnt
#370 theviper90210
theviper90210
  • 28 posts
Posted 25 October 2012 - 04:39 AM
Roots, works great now no problems so far!!!!, also will confirm it works on safestrap 2.11!! Thanks for a great rom!
#371 theviper90210
theviper90210
  • 28 posts
Posted 25 October 2012 - 05:25 AM
One question. I notice that the signal bars don't turn blue. Like they are connected to Google is this just the way the rom.is and everything is fine. Is is it supposed to be blue
#372 MrFrankRazr
MrFrankRazr
    Dedicated Supporter
  • 669 posts
Posted 25 October 2012 - 05:37 AM
Re-downloaded zip file and I was able to flash it and gapps no problem. Got logged in and just going through TIBU restores now. Just did a fresh installed from the test rom. Still looks and runs great!
#373 flashman2002
flashman2002
  • 104 posts
Posted 25 October 2012 - 06:16 AM
They won't turn blue as this is TW launcher. It will stay gray and the arrows will turn green and orange.
I am happy V 3.0 is working on my phone. Only issues I had were caused on my own and after a fastboot using Matt's utility I am flying on this. SS3 takes a little getting used to, but once set up all is gravy. Thanks again for your work! I enjoy the TW launcher and this is a wonderful rom.
  • desireaftergod likes this
#374 desireaftergod
desireaftergod
  • 536 posts
  • LocationNH
Posted 25 October 2012 - 06:47 AM
What is the best Gov/IO combo for this? Is it the default? :)
#375 rswizz
rswizz
  • 7 posts
Posted 25 October 2012 - 06:51 AM
Any knows why I can't get videos to play that comes from an app..apps like score center NFL mobile videos don't play?
#376 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • LocationPA
Posted 25 October 2012 - 07:05 AM
Pegasusq governor and sio scheduler i recommend, but you can try other combos too
#377 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • LocationPA
Posted 25 October 2012 - 07:06 AM
You need to install flash player i would guess, so just search for it online maybe
#378 rswizz
rswizz
  • 7 posts
Posted 25 October 2012 - 07:13 AM
Yea tried that didn't work ..seems to be happening on all the aokp roms
#379 medic7046
medic7046
  • 19 posts
  • Twitter:medicp7046
  • Google+:medic7046@gmail.com
  • LocationRichmong HIll, Ga
Posted 25 October 2012 - 07:30 AM
I am having problems sticking in boot. I have tried using safestrap 3.0.5 and 2.11. After i install rom and gapps, and restart it goes in to a boot loop and keeps flashing moto logo and the safestap enabled. When flashing ROM it only takes a sec or so for it to flash, seems to quick.
#380 thaijunk
thaijunk
  • 109 posts
Posted 25 October 2012 - 12:19 PM
I would try re downloading the rom and flash again. Flash took about three to five minutes for me.
