Wipe cache and dalvik and reboot. You can also try toggling network modesJust reflashed in hopes that my 4g would start working. Still no 4g :-) Idk what the deal is, but no 4g, and this time, touchwiz keeps fc'ing.
#321
Posted 16 October 2012 - 12:31 PM
- team420 likes this
#322
Posted 16 October 2012 - 03:32 PM
Wiped and toggled every network mode, still no lte :-( actually, when I toggled CDMA/lte/gsm... etc I lost all data, and had to reboot, same with lte only mode.Wipe cache and dalvik and reboot. You can also try toggling network modes
#323
Posted 17 October 2012 - 09:34 AM
- Rootuser94 likes this
#324
Posted 17 October 2012 - 10:15 AM
#325
Posted 17 October 2012 - 11:09 AM
#326
Posted 17 October 2012 - 11:28 AM
Does the Wifi Hopspot work in this ROM?
It does for me. USB tether isn't atm still, again at least for me. Just chose to switch to something else when I need to hook up to the PC.
#327
Posted 17 October 2012 - 01:00 PM
Good deal. I went ahead a flashed it and it worked for me. I had trouble with an earlier version connecting when i needed it to. Thanks
#328
Posted 17 October 2012 - 04:48 PM
#329
Posted 17 October 2012 - 04:57 PM
Its a bug in the base. Read the op. Jelly bean is not fully functional yetError in turning BT on mutes all sound from ingoing/outgoing calls. Very annoying
#330
Posted 17 October 2012 - 05:56 PM
However, the radio reception is sub par. My phone is getting 1 bar 4G in the same spot where I was getting 3-4 bars with Black widow JB
Any tips would be much appreciated. Or if there is something you could do with the next update, that'd be much appreciated!!!
#331
Posted 17 October 2012 - 06:02 PM
Maybe try wiping cache and or toggling radio modesI LOVE this rom! Love the theme, love the speed, love the tweaks
#332
Posted 18 October 2012 - 06:36 AM
Has anyone tried to change the boot animation under the general UI settings? I havent been able to get it to work.
+1I used ROM Toolbox and it worked perfectly.
#333
Posted 18 October 2012 - 07:25 AM
#334
Posted 18 October 2012 - 09:10 AM
Make sure you have flash installed!Anyone having the issue where videos won't play on scorecenter or nfl mobile ..keeps saying cannot play file media error
#335
Posted 18 October 2012 - 12:30 PM
#336
Posted 18 October 2012 - 01:11 PM
Flash and use dolphin
#337
Posted 18 October 2012 - 01:46 PM
#338
Posted 18 October 2012 - 02:15 PM
#339
Posted 20 October 2012 - 08:33 AM
#340
Posted 21 October 2012 - 06:43 PM
Like others, I couldn't get to the homescreen after setup. Clicking 'Finish Setup' causes an FC, and then goes to a black screen. I tried to install Apex from the Play Store, but I got an error trying to download it. I've tried reinstalling, but no luck. 1.0 worked for me, but it would cause hang-ups.
had same problem. tried 2 times didn't work. I finally got it to work.
This is what I did
Using safestrap 2.11
Home screen ----Wipe Data/Factory reset
Then go to advanced---wipe Delvik Cache
*****Go Back To Home Screen****
Select -Mounts and Storage
then ---Format /System
Then Install Rom
Then Install Gapps
Then Reboot
Thats what I did and Bingo it worked. this Rom is Worth it, I would try again
