1389 replies to this topic
#221 DarkOverDroid
DarkOverDroid
    DROIDOSAPIEN
  • 502 posts
  • Twitter:@DarkOverDroid
  • Google+:DarkOverDroid@gmail.com
  • LocationMobile, Al
  • Current Device(s):DROID RAZR MAXX HD, DROID RAZR MAXX, iPhone 4, Galaxy Tab 2 10.1 (WiFi) 7" Acer Iconia Tab A-100 (Wifi)
Posted 13 October 2012 - 10:32 PM
I was able to get to the setup menu but when I would hit "finish" it force closes. Brings me to a black screen and no launcher.
Ouch! Well good luck this time around. :)
#222 punkchunkz
punkchunkz
  • 11 posts
Posted 13 October 2012 - 10:34 PM
Just flashed and having the same issue... I can go to settings and all but there is no launcher anywhere. It looks really really nice though, a real step up from v1.0 ;)
Gonna try re-wiping and flashing again...
Glad I'm not the only one having this issue, let me know if you find a fix and I'll do the same if I get it to work.
#223 DarkOverDroid
DarkOverDroid
    DROIDOSAPIEN
  • 502 posts
Posted 13 October 2012 - 10:37 PM
Looks like I'm going to have to fastboot to stock and re root. :(
Just P.M`d Rootuser94 to see if he had any idea as to why this would happen. I`m clueless, especially after the second flash failed. Mine worked fine after the first. :blink:
#224 thebluegod
thebluegod
  • 66 posts
Posted 13 October 2012 - 10:44 PM
Also having the same issue and tried twice. Version 1.0 worked fine though...
EDIT: Actually I can pretty much do anything but go to the launcher. Power button and everything works fine. Weird... trying to re-flash gapps.
#225 DarkOverDroid
DarkOverDroid
    DROIDOSAPIEN
  • 502 posts
Posted 13 October 2012 - 10:53 PM
K, I have not heard anything yet. It`s just so strange. Has me curious to what`s causing it.
#226 punkchunkz
punkchunkz
  • 11 posts
Posted 13 October 2012 - 10:59 PM
Okay, so Im back to fastbooted stock, re-rooted, re-installed safestrap 2.11, I'm on safe side, I'm going to install V1.0 and gapps, reboot and setup, then im going to boot back into recovery, wipe data, cache, dalvik and /system, and then install V 2.0 and see what the results are.
#227 BADDINOROX99
BADDINOROX99
  • 89 posts
Posted 13 October 2012 - 11:06 PM
does data and wifi tether work?
#228 ifonekillr
ifonekillr
  • 56 posts
  • Twitter:@ifonekillr
  • LocationIndiana
Posted 13 October 2012 - 11:11 PM
I had the same exact thing happen. I did a full wipe and reflashed. It works fantastic now. Not sure what caused it but don't give up. This rom is phenomenal. Big thanks to the dev. He will surely get it figured out.
My Razr is sharp thanks to Droidrzr.com, I will cut you with it if I must.
#229 thebluegod
thebluegod
  • 66 posts
Posted 13 October 2012 - 11:16 PM
I'm still on the safe side, didn't fastboot again or anything. Just did exactly what you said and now it's working! I didn't format /system last time, that may have been the issue.
#230 DarkOverDroid
DarkOverDroid
    DROIDOSAPIEN
  • 502 posts
Posted 13 October 2012 - 11:20 PM
Good deal. :D
#231 thebluegod
thebluegod
  • 66 posts
So v2.0 is pretty awesome, great work. Is there a way to customize lockscreen shortcuts?
#232 DarkOverDroid
DarkOverDroid
    DROIDOSAPIEN
  • 502 posts
Posted 13 October 2012 - 11:22 PM
Yes and Yes. Native tethering works and data connects and switches seamlessly.
  • BADDINOROX99 likes this
#233 DarkOverDroid
DarkOverDroid
    DROIDOSAPIEN
  • 502 posts
Posted 13 October 2012 - 11:26 PM
I don`t think so. You can add weather and change other things, but I`m not so sure about the shortcuts.
#234 blaten22
blaten22
  • 194 posts
Posted 13 October 2012 - 11:27 PM
Anyone tried usb tethering?
#235 thebluegod
thebluegod
  • 66 posts
Posted 13 October 2012 - 11:29 PM
Cool, not a huge deal since unlocking is super quick anyways.
#236 DarkOverDroid
DarkOverDroid
    DROIDOSAPIEN
  • 502 posts
Posted 13 October 2012 - 11:32 PM
and Lol. I said wipe and reflash back on post #208. Glad it`s going though. :D
#237 DarkOverDroid
DarkOverDroid
    DROIDOSAPIEN
  • 502 posts
Posted 13 October 2012 - 11:34 PM
Nope, could`nt get it to work. Maybe if you have Motocast installed, which I don`t. If you have a wifi adapter the native wifi tether app works great.
#238 blaten22
blaten22
  • 194 posts
Posted 14 October 2012 - 05:28 AM
Yea, I used it last night for my cod3 fix. Just won't connect for my linux box. It's no biggie, just thought i ask.
#239 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • Twitter:@Rootuser94
  • LocationPA
Posted 14 October 2012 - 06:54 AM
hmmmm not sure why it works for some and not for others. Its tough because i dont have a razr to test so i'm kinda working blind
#240 Rootuser94
Rootuser94
    Touchwiz Overlord
  • 1,019 posts
  • LocationPA
Maybe try flashing the rom with an earlier version of the gapps :
