Droid Razr Utility 1.82 [Linux/mac] For Verizon Droid Razr And Droid Razr Maxx Only
linux utility mac utility matts utility linux mac 1.82
125 replies to this topic
#61 thebluegod
thebluegod
  • 66 posts
Posted 06 January 2013 - 09:18 PM
i have a linux mac version of the dual boot..... and there is another one posted on the thread as well if you want.....
Just saw that actually. I'll try it on my Mac otherwise I'll use a PC. Thanks!
  • johnthehillbilly likes this
#62 thebluegod
thebluegod
  • 66 posts
Posted 06 January 2013 - 10:26 PM
One more problem, when trying to root with any of the utilities, I get the same error after rebooting the first time:
rm failed for /data/local.prop, No such file or directory
./dualboot.sh: line 107: /data/local.prop: No such file or directory
And then everything after that fails. Does this mean I did a bad flash or something?
#63 johnthehillbilly
Posted 06 January 2013 - 10:38 PM
no....... not a bad flash..... a bad flash would not boot..... i will look into that.....
unless someone beats me to it....... it will probably be tomorrow.....:)
  • thebluegod likes this
#64 johnthehillbilly
Posted 06 January 2013 - 11:08 PM
#65 thebluegod
thebluegod
  • 66 posts
Posted 06 January 2013 - 11:10 PM
unless someone beats me to it....... it will probably be tomorrow..... :)
No rush, I got it to work on the Windows version. But if I could get it working on my Mac it would be sweet.
#66 NicholasPeckham
NicholasPeckham
  • Current Device(s):Motorola Razr Maxx HD
Posted 24 February 2013 - 07:05 PM
Hey, I am new to the Motorola world. I just want to make sure that this will work on the Maxx HD. Thanks in advance for the answer.
#67 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 24 February 2013 - 07:08 PM
there is an HD Utility for that. This won't work.
#68 johnthehillbilly
Posted 24 February 2013 - 07:13 PM
Here is the HD utility thread
#69 NicholasPeckham
NicholasPeckham
Posted 24 February 2013 - 07:18 PM
You guys both just rocked my world. Thanks for the quick responses.
#70 johnthehillbilly
Posted 24 February 2013 - 07:21 PM
You're welcome..... good luck and have fun :)
#71 83Matt
83Matt
  • 12 posts
Posted 22 May 2013 - 09:21 AM
ok tried this but i get stuck when i try to put the input command ./files/adb devices like it says.  tried unzipping all zipped files still nothing!!
#72 johnthehillbilly
Posted 22 May 2013 - 09:30 AM
Typically you don't really need to do that..... try opening terminal.... then CD to where you extracted the utility..... then chmod +x (or chmod a+x) LinuxMacUtility1-82.sh .... then ./LinuxMacUtility1-82.sh
The utility should start...:)
Just make sure you are charged up.... in AP Fastboot and connected by USB...:)
Sometimes the ./adb/devices command does not work.....
Everything that is required is included in the utility :)
Piece of advice..... if you are running 64 bit linux distro. You may need to get ia32-libs before continuing ....
tapadriving.....hillbilly style
#73 83Matt
83Matt
  • 12 posts
Posted 22 May 2013 - 10:04 AM
when i imput chmod +x (or chmod a+x) LinuxMacUtility1-82.sh and hit return it say syntax error near unexpected token `('
oh i have the rare 32 bit mac and changed the names like it said to do if that matters
#74 johnthehillbilly
Posted 22 May 2013 - 10:44 AM
I should have been more clear LOL .... i meant, either.... chmod +x ..... or chmod a+x ..... but you should be ok with.... chmod +x LinuxMacUtility1-82.sh ....
#75 83Matt
83Matt
  • 12 posts
Posted 22 May 2013 - 11:51 AM
Hey sorry i am so outta my league didnt notice this is not for the razr maxx hd.   Noticed the other thread but it says the file is no longer stored there.   Do you have a link that will give me the Utility i need to root a razor maxx hd on a 32 bit mac.  and thanks for all your help with a rookie  had the iphone before this so its all still new!!
#76 johnthehillbilly
Posted 22 May 2013 - 12:06 PM
No worries :)
That is the latest utility for the HD :)
  • Memnoch73 likes this
#77 83Matt
83Matt
  • 12 posts
Posted 22 May 2013 - 01:36 PM
its me again downloaded the newest utility app for droid razr maxx hd  saved it to the desktop and followed the instructions but when i drag the unzipped file over this is what i get:
Matt-Lindseys-MacBook:~ mattlindsey$ /Users/mattlindsey/Desktop/DROID_RAZR_HD_Utility_1.20.zip
-bash: /Users/mattlindsey/Desktop/DROID_RAZR_HD_Utility_1.20.zip: cannot execute binary file
did i miss something
#78 johnthehillbilly
Posted 22 May 2013 - 01:40 PM
It appears you are dragging the .zip file into terminal......
#79 obeygiant
obeygiant
    Utility Pro
  • 79 posts
  • Twitter:obey22giant
  • Google+:https://plus.google.com/109248393171126077439/about
Posted 22 May 2013 - 01:48 PM
Unzip the utility and only drag the file with the .sh extension into the terminal.
#80 johnthehillbilly
Posted 22 May 2013 - 01:50 PM
Unzip the utility to desktop..... open terminal ... type CD ..... then drag the entire ubzipped folder to terminal press enter.......it should CD you into find the utility directory........now type chmod +x .... then drag the executable (.sh) file to terminal press enter....... finally type ./ and drag the executable (.sh) again to terminal...... press enter.......:)
Also tagged with one or more of these keywords: linux utility, mac utility, matts utility, linux, mac, 1.82
