Droid Razr Utility 1.82 [Linux/mac] For Verizon Droid Razr And Droid Razr Maxx Only
linux utility mac utility matts utility linux mac 1.82
125 replies to this topic
#41 johnthehillbilly
Posted 31 October 2012 - 10:34 AM
ok tried fastbooting using rsd lite and it worked, however when i tried using rosenbergs exploit it wasnt able to root (see attached link for screenshot)
gonna try rooting with the windows utility however i have a feeling it wont work. ill try anyway. anyone else got any other ideas? thanks again for your help.
here is the "failsafe" batch file from the windows Utility.... maybe try running it......
#42 simon_lefisch
simon_lefisch
  • 265 posts
  • Current Device(s):Razr Maxx
Posted 31 October 2012 - 10:42 AM
actually the windows utility did it. i got root :) weird man....why would the windows utility work and not the LinuxMac utility? not even the rosenberg exploit worked. anyways, thanks for all your guys' help....it is much appreciated. now time to ROM this b**ch! might give kexec a try
#43 johnthehillbilly
Posted 31 October 2012 - 10:57 AM
I find it weird that the utility (windows or linuxmac) was giving you trouble..... glad you got it with RSD Lite tho..(which actually has NOT worked for some)........ no prob helping, thats what we're here for :) ......
#44 simon_lefisch
simon_lefisch
  • 265 posts
Posted 31 October 2012 - 11:15 AM
yea right? totally strange. i actually just tried the LinuxMacUtility to push SS to my phone and still have the same prob, however when i use the windows utility to push SS it worked just fine. i am running lion (not mountain lion) on my mac. maybe that has something to do with it? :/ regardless im just glad i have a virtual windows machine on my mac to use the utility :)
#45 johnthehillbilly
Posted 31 October 2012 - 11:33 AM
im not as familiar with Mac as i am with Linux so that may be the prob...may not... someone with more Mac knowledge would have to answer that one....... bottom line tho, cases like this are EXACTLY why we have different varaitions of the Utility..... :)
#46 sgtguthrie
sgtguthrie
  • 135 posts
  • Twitter:@sgtguthrie1
  • LocationMichigan
Posted 26 December 2012 - 07:37 PM
I'm trying to run option 1 on a mac and it's been hung on "rebooting into bootloader" for about 10 minutes. What should I do? Here is the output in the terminal...
64 bit Mac System
[*] Simple Razr Restore to ICS 6.16.211
[*] Linux/Mac Version
[*] Before continuing, ensure your Razr is in the
[*] 'AP Fastboot' mode and connected via USB.
[*]--- Also press the keys after the screen flashes back on when asked---
[*]Get Ready To Break Out Your Sudo
[*]Press Enter To Continue
WARNING: Improper use of the sudo command could lead to data loss
or the deletion of important system files. Please double-check your
typing when using sudo. Type "man sudo" for more information.
To proceed, enter your password, or type Ctrl-C to abort.
Password:
sending 'mbm' (512 KB)... OKAY [ 0.042s]
writing 'mbm'... OKAY [ 0.497s]
rebooting into bootloader...
EDIT:
Nevermind, all I had to do was restart and it worked. It's running correctly now (fingers crossed)
#47 johnthehillbilly
Posted 26 December 2012 - 07:45 PM
64 bit Mac System
Password:
hmmm... thats an odd error..... maybe try toggling your USB .... (unplug then plug back in) ..... i really hate suggesting that but sometimes it does work..... if that does not work.... try rebooting your computer ... and your phone (if it will let you at this point) it may boot right into AP Fastboot.... will need to work rather quickly as your phone will not charge while in AP Fastboot and we do not want a dead battery in the middle of flashing.... speaking of which, how full was your battery when you started?
#48 thebluegod
thebluegod
  • 66 posts
Posted 06 January 2013 - 07:40 PM
Hey, trying to fastboot back to stock .211 and the option 1 is going through but it's getting stuck at random parts (like "sending boot") for way too long. I restarted the utility like 3 times but each time it's getting stuck at some part after pressing enter twice. This is really weird and I hope I can find a solution before my phone loses it's charge... will try the Windows utility once I get a hold of a PC.
#49 obeygiant
obeygiant
    Utility Pro
  • 79 posts
  • Twitter:obey22giant
  • Google+:https://plus.google.com/109248393171126077439/about
Posted 06 January 2013 - 07:58 PM
Some steps take 2-3 minutes, even with alot of RAM. My Macbook seemed liked it took forever because i didn't have enough ram, to the point i was afraid to let it finish in fear of draining the battery. The other possible issue could be an intermittent connection. Try a different USB port and cable, if you happen to have one.
#50 thebluegod
thebluegod
  • 66 posts
Posted 06 January 2013 - 08:05 PM
Alright I'll wait it out this time and see if there's any progress. I don't think it's an intermittent connection since the fastboot screen on my phone says USB connected the whole time and I tried different USB ports.
Also I don't know if this matters but on the AP fastboot screen it says "Devices is LOCKED", do I have to do something to unlock it?
#51 johnthehillbilly
Posted 06 January 2013 - 08:08 PM
device locked is normal....... when it hangs, try unplugging the usb.... then plugging it back in...... i hate recommending doing that but sometimes it works and then the utility continues.........
BTW ...... nice to see you obeygiant...... :) :)
#52 obeygiant
obeygiant
    Utility Pro
  • 79 posts
Posted 06 January 2013 - 08:09 PM
If you do figure that out, you will be a god amongst men! No one has an unlocked bootloader, except the Developer Edition.
  • johnthehillbilly likes this
#53 obeygiant
obeygiant
    Utility Pro
  • 79 posts
Posted 06 January 2013 - 08:10 PM
Hey John! I'm just nosing around, i don't even have a Razr anymore!
#54 thebluegod
thebluegod
  • 66 posts
Posted 06 January 2013 - 08:13 PM
Ahh, that refers to the bootloader no duh... haha that was pretty noobish of me considering this is probably my 100th time fastbooting/flashing a Moto device. Anyways thanks a bunch guys I'll follow your suggestions and see what happens.
#55 johnthehillbilly
Posted 06 January 2013 - 08:14 PM
that ok..... you know you are still family.... razr or no razr......
  • obeygiant likes this
#56 obeygiant
obeygiant
    Utility Pro
  • 79 posts
Posted 06 January 2013 - 08:20 PM
Trust me, we all have brain farts! Rebooting the computer and only letting the utility run has helped me in the past, if it is a low RAM issue.
#57 thebluegod
thebluegod
  • 66 posts
Posted 06 January 2013 - 08:23 PM
Awesome, I was able to boot into stock .211!!! Man, I almost had a mini heart attack. Now it's time to root and install Jellybean!
Thank you so much for your help! See you around in the forums! :D
  • obeygiant and johnthehillbilly like this
#58 johnthehillbilly
Posted 06 January 2013 - 08:25 PM
maybe check out the Dual boot thread....... then you can have JB but still keep ICS so you will be able to run this utility again if needed..... once you upgrade to JB there is NO GOING BACK to ICS.......
#59 thebluegod
thebluegod
  • 66 posts
Posted 06 January 2013 - 08:47 PM
Thanks, I think I will go with the dual boot. For some reason I'm not able to root with this utility on my Mac, but I got a hold of a PC so I'm gonna use the dual boot utility to root and so on...
#60 johnthehillbilly
Posted 06 January 2013 - 08:56 PM
i have a linux mac version of the dual boot..... and there is another one posted on the thread as well if you want.....
Also tagged with one or more of these keywords: linux utility, mac utility, matts utility, linux, mac, 1.82
