Droid Razr Utility 1.82 [Linux/mac] For Verizon Droid Razr And Droid Razr Maxx Only
linux utility mac utility matts utility linux mac 1.82
125 replies to this topic
#21 rmoya5150
rmoya5150
  • 96 posts
  • Locationconcord, ma
  • Current Device(s):Razr converted into a Maxx
Posted 29 October 2012 - 11:03 AM
okay so my razr wont get recognized by the utility, i followed the directions and did everything right, and my usb port and cable are good because it works with other utilities....any suggestions?
#22 johnthehillbilly
Posted 29 October 2012 - 11:10 AM
is it giving you any kind of error,,,, or ???
#23 theBonVoyage
theBonVoyage
  • 118 posts
  • LocationCharleston, SC
Posted 29 October 2012 - 11:22 AM
Ok this might seem like a trivial question bit have you set up adb the linux way?
Sent from my DROID RAZR using Xparent ICS Tapatalk 2
#24 johnthehillbilly
Posted 30 October 2012 - 09:44 AM
New Update available now........ DL link for the update has been added to OP...... thanx again to obeygiant for all the help on this....
#25 simon_lefisch
simon_lefisch
  • 265 posts
  • Current Device(s):Razr Maxx
Posted 30 October 2012 - 07:38 PM
hi guys, so i got a replacement razr cuz my screen cracked and im trying to root it with the utility and nothing happens. ive got debugging on, its in mtp mode, nonmarket apps is selected and so is allow mock locations. as soon as i bring up the utility with the choices and select option 2 (root 4.0.4) it just hangs. i know the usb cable is good as when i switch to mass storage mode my sd cards mount. any ideas?
system number 6.16.211
build 6.7.2-180_DHD-16_M4-31
#26 obeygiant
obeygiant
    Utility Pro
  • 79 posts
  • Twitter:obey22giant
  • Google+:https://plus.google.com/109248393171126077439/about
Posted 30 October 2012 - 08:19 PM
Try switching from mtp to ptp mode. We've seen many phones, for whatever reason, only work in ptp mode.
Also, what type of computer are you running the utility on?
#27 simon_lefisch
simon_lefisch
  • 265 posts
Posted 30 October 2012 - 08:24 PM
thanks for the response. didnt work either. not sure whats going on. ive used this method before and had no probs. im tempted to do a fastboot and see what happens. any other ideas? ive even tried it on a windows platform and had the same thing. even tried the original rosenberg utility and nothing.
#28 obeygiant
obeygiant
    Utility Pro
  • 79 posts
Posted 30 October 2012 - 08:33 PM
Open a terminal inside the ./files folder and type "adb devices" without quotes and see if your device is recognized by your system
#29 simon_lefisch
simon_lefisch
  • 265 posts
Posted 30 October 2012 - 08:51 PM
nothing :/ heres what came up
[my name]-MacBook-Pro:~ [username]$ cd ~/Downloads/LinuxMacUtility1-82/files
[my name]-MacBook-Pro:files [username]$ adb devices
-bash: adb: command not found
man this sucks. been forever since ive had to root my phone and now that i have to, i cant! lame :/
#30 obeygiant
obeygiant
    Utility Pro
  • 79 posts
Posted 30 October 2012 - 09:02 PM
Generally that error is given when either the utility files did not extract correctly, or they were extracted to a different folder after you unzipped them
#31 simon_lefisch
simon_lefisch
  • 265 posts
Posted 30 October 2012 - 09:08 PM
here are the files that were extracted
#32 obeygiant
obeygiant
    Utility Pro
  • 79 posts
Posted 30 October 2012 - 09:31 PM
Oops i lead you astray on the devices. Could you reboot your system first, and then, from the files folder type "adb.osx devices" without quotes. I forgot the difference in the filenames for Mac vs Linux. When/if you get a "waiting for device" error for a long time, toggle MTP and PTP mode. Sorry, Im not at home with my computer and the utility to run. Im doing this from memory on a dirty Windows computer at work!
#33 simon_lefisch
simon_lefisch
  • 265 posts
Posted 30 October 2012 - 09:40 PM
yea same thing. from the directory i posted above i get the same error message:
-bash: adb.osx: command not found
did i mention my phone is refurbished? maybe that has something to do with it? btw, i appreciated your help :)
#34 obeygiant
obeygiant
    Utility Pro
  • 79 posts
Posted 30 October 2012 - 10:03 PM
Probably doesnt have anything to do with it being refurbished. If the adb commands are not initialising, it seems to be a problem with the utility finding the files and permissions. Could you try running "chmod +x LinuxMacUtility1-82.sh" from within the folder you extracted to, and then re-running the script?
Its no problem helping, we are all here to help each other.
Edited by obeygiant, 30 October 2012 - 10:04 PM.
#35 johnthehillbilly
Posted 30 October 2012 - 11:32 PM
Chances are if you have tried the windows utility, linuxMac utility and dan rosenburg's..... the issue may lie within the phone itself..... (maybe they corrupted something while 'refurbishing')..... possibly try option 1 and fastboot back to stock.... then try rooting again....
#36 SamuriHL
  • 44,378 posts
Posted 31 October 2012 - 03:51 AM
./adb.osx devices
#37 obeygiant
obeygiant
    Utility Pro
  • 79 posts
Posted 31 October 2012 - 04:16 AM
./adb.osx devices
Yup yup that's the one! (Night shift isn't agreeing with my brain at the moment)
  • SamuriHL and johnthehillbilly like this
#38 simon_lefisch
simon_lefisch
  • 265 posts
Posted 31 October 2012 - 08:42 AM
ive already tried that multiple times and had the same results about 'bad commands' and such.
im fastbooting my phone right now and will try to see if i can root....
edit: ok after 15-20 minutes the utility got stuck during the fastboot (see link below)
im now convinced its the phone. im gonna send the phone back and get another replacment.
#39 johnthehillbilly
Posted 31 October 2012 - 09:25 AM
maybe (just to narrow it down some more) try fastbooting using the windows version? ....... it's worth a shot, at this point....
#40 simon_lefisch
simon_lefisch
  • 265 posts
Posted 31 October 2012 - 10:23 AM
ok tried fastbooting using rsd lite and it worked, however when i tried using rosenbergs exploit it wasnt able to root (see attached link for screenshot)
gonna try rooting with the windows utility however i have a feeling it wont work. ill try anyway. anyone else got any other ideas? thanks again for your help.
Also tagged with one or more of these keywords: linux utility, mac utility, matts utility, linux, mac, 1.82
