This is a thread to give you all the De-Odedexed Ics Leak zip files
(thanks for the suggestion JohnLGalt)
Ok so here's the deal...the files in these zips are de-odexed meaning the classes.dex files of the apk's are placed back into the apk from the .odex file. This makes it so that you can edit the files with less of an issue. Instead of having blah.apk AND blah.odex, you simply have blah.apk. If for instance you want to flash the 1% battery mod by Dluke ( ) on stock, it wont work because of that odex file. There is no need to wipe or format anything when flashing this because all it's doing is swapping the files out. So basically if your not a moder, themer, developer or editor of your own stuff then you dont need these files...
*FLASH EACH ZIP ON ITS CORRESPONDING LEAK OR YOU'LL SCREW UP YOUR PHONE!*
Flash this zip after installing if you don't see the SuperUser app in your drawer -
(Don't wipe anything when flashing the SuperUser.zip)
All you have to do is:
1. Download zip file
2. Place zip on sdcard-ext
3. Boot into CWM recovery via bionic bootstrapper
4. Scroll to "install zip from sdcard"
5. Scroll to "choose zip from sdcard"
6. Find deodexed zip and choose it
7. Once done flashing, press "reboot system now"
8. It will run through "optimizing applications" (DON'T RESET OR PULL BATTERY!)
9. ENJOY DEODEXED ICS! :-)
Thanks go to: DLuke, John L. Galt + Twinkyz1979 THANKS GUYS!
Downloads:
De-odexed 6.7.247 by T3T3droid - ( )
De-odexed 6.7.246 by T3T3droid - ( )
De-odexed 6.7.244 by Twinkyz1979 - ( ) ( )
De-odexed 6.7.242 by Twinkyz1979 - ( ) ( )
De-odexed 6.7.238 by T3T3droid - ( )
De-odexed 6.7.235 by T3T3droid - ( )
De-odexed 6.7.232 by Mhous33 -
Disclaimer - I nor Twinkyz1979 nor Mhous33 take responsibility for what you do to your phone. Flash at your own risk!
