[Rom][Bionic] Sonofskywalker3's Blackhole Bionic 1.0 Ics-247 Base By T3
73 replies to this topic
#21 T3T3droid
T3T3droid
    D3v3lop3r/Th3m3r/Machin3
  • 1,115 posts
  • Google+:t3t3droid@gmail.com
  • LocationConnecticut
  • Current Device(s):Droid Bionic, Droid Razr M, SGS4
Posted 04 October 2012 - 10:46 AM
which email clients do you have in this one? If I remember on the original betas we tested you had to make me a new file so I could connect with a corporate sync account.
Sorry i added it to the OP now. Thanks for reminding me :D
Sig by Bama
If you like our work please consider
Donating towards
Phones and Site costs :D Thanks!!
#22 T3T3droid
T3T3droid
  • 1,115 posts
Posted 04 October 2012 - 10:47 AM
Wifi hasn't been a issue for me too. Nice to see it debloated :D
Glad youre liking it :)
Sig by Bama
Donating towards
#23 Thepatriotvirus
Thepatriotvirus
  • 68 posts
  • LocationCalifornia
Posted 04 October 2012 - 10:59 AM
Yea.. I was flashing this at 3 am. So thank you for giving me something flash.
  • T3T3droid likes this
#24 craig8769
craig8769
  • 10 posts
Posted 04 October 2012 - 11:03 AM
I rebooted and WIFI is now working. Still can't get the Google Play Store to work? No browser, this is bare bones. What browser are you guys using?
#25 Thepatriotvirus
Thepatriotvirus
  • 68 posts
Posted 04 October 2012 - 11:36 AM
Chrome, Dolphin browser beta
#26 T3T3droid
T3T3droid
  • 1,115 posts
Posted 04 October 2012 - 11:42 AM
Yeah I like dolphin browser and I'm swapping to safe side now to check play store
edit: Play store is working fine for me...
Sig by Bama
Donating towards
#27 mattgaitan
mattgaitan
  • 33 posts
  • Twitter:matthewgaitan
Posted 05 October 2012 - 12:42 AM
Upon installing in bootstrap all the bloat from the .247 leak is still there. On top of the regular /preinstall/app and /system/vendor/app is all the other stock junk. Is there anything that can be done to remedy this? Seeing as this is an extremely debloated rom, I feel it's kinda pointless to install on bootstrap if all the bloat is still there. I tried formatting /system on my first install (SPJESTER has you do this for his bootstrap rom and it clears out all the bloat) but all it did was give me a black screen on initial boot. I guess I'll just use safestrap for the time being, I just thought I would let you know just incase :) Thanks for this rom! Off to safestrap i go ;)
#28 T3T3droid
T3T3droid
  • 1,115 posts
Posted 05 October 2012 - 02:27 AM
Thanks for the info. I will try when I get home from work today and if it doesn't or does work I'll let you know. Far as I can tell the updater-script should delete the entire system folder but I'll double check.
Sig by Bama
Donating towards
#29 craig8769
craig8769
  • 10 posts
Posted 05 October 2012 - 04:09 AM
I reinstalled rom without installing google apps and the play store works now. Everything is good except I can't install Verizon login app. Which is needed to get Verizon Nfl Mobile to work. I did get an error with panaroma camera.
#30 T3T3droid
T3T3droid
  • 1,115 posts
Posted 05 October 2012 - 04:16 AM
The Rom has gapps integrated that's why it worked without flashing it :) I'll make a flashable zip for Verizon login and post it in the OP. I don't know what camera you're using but the blur one is in the OP and I'll add one for cameraics.apk and we'll see if that works.
Sig by Bama
Donating towards
#31 craig8769
craig8769
  • 10 posts
Posted 05 October 2012 - 06:38 AM
Yep just need to have the verizon login app integrated or offered as a download just like you've done with the other apps (I need my NFL Mobile app to work). So far smooth as butter. I tried to download the Verizon Login app from PlayStore but it said my device is incompatible. Also there are very limited ringtones, what's up with that?
#32 craig8769
craig8769
  • 10 posts
Posted 05 October 2012 - 06:49 AM
Still can't connect to my WIFI at work, must be something to do with the MAC address. I've connected at home without any issues. Gotta switch back to the unsafe side, I need my WIFI.
#33 TragicRemedy
TragicRemedy
  • 87 posts
Posted 05 October 2012 - 07:35 AM
FYI I did fxz > 905 > 232 > bs touch recovery > wipe data/cache/dalvik/system > flash rom and I got a black screen after Motorola logo.
If it matters I do have a 4 slot bionic.
#34 T3T3droid
T3T3droid
  • 1,115 posts
Posted 05 October 2012 - 09:13 AM
im gunna make the verizon login zip now. the reason its incompatible is because thats the GB one lol remember ICS doesnt technically exist yet :) the reason there are limited ringtones is because they take up a TON of system space. i can make a zip specifically for you if you want....and im gunna try flashing it in bootstrap too
Sig by Bama
Donating towards
#35 T3T3droid
T3T3droid
  • 1,115 posts
Posted 05 October 2012 - 09:16 AM
1. you have to be on 247 to flash this and 2. i am working on fixing bs flash now
If you want the one for 232 the use this one (
Sig by Bama
Donating towards
#36 TragicRemedy
TragicRemedy
  • 87 posts
Posted 05 October 2012 - 09:30 AM
I know :-) just letting others know what I tested in case anyone else was wondering.
#37 T3T3droid
T3T3droid
  • 1,115 posts
Posted 05 October 2012 - 10:21 AM
oh ok thank you :D
Sig by Bama
Donating towards
#38 T3T3droid
T3T3droid
  • 1,115 posts
Posted 05 October 2012 - 10:30 AM
Craig8769 - I added the log-in client to the OP and here are the ringtones -
Sig by Bama
Donating towards
#39 Aldroid33
Aldroid33
    Superuser
  • 766 posts
Posted 05 October 2012 - 04:06 PM
Flashed the ROM in bootstrap. Everything looks the same as stock 247, even System Settings/ About phone. How can I tell? What is different?
Samsung S4, Rooted, Encrypted, Stock JB 4.4.3 GPE and Echo TW v.24 4.4.2
Moto Xoom WiFi-EOS Big Part 4.4.4 w/ TWRP 2.7.1. Thanks BRD & R'nH!
#40 T3T3droid
T3T3droid
  • 1,115 posts
Posted 05 October 2012 - 04:21 PM
I changed the OP to say don't flash in bootstrap cause its not working. to answer your question though it seems to be "flashing" fine but its not actually deleting the system partition...so when it goes to put all the files from the rom in there there isnt enough room. BUT, and thats a big but, if you FORMAT the system partition then flash the rom it still "flashes" fine but then doesnt add anything to the system partition from the rom...this in turn soft bricks you and you have to HoB back to stock. Therefore i say again PLEASE DON'T FLASH IN BOOTSTRAP FOR THE TIME BEING! Luckily you seemed to have only did wipe data/factory reset and/or wiped cache/dalvik which means you really didn't do anything to your phone seeing as it didnt flash. Thus, you see all the same stuff in there cause it IS the same. Hope this answers your question, but if you want to flash in safestrap on safe side please go for it! Works fine that way for some reason...Thanks for posting the issue though! I like to know what i can fix for you guys to have a kick arse rom! :D (bootstrap fix to come!)
  • Aldroid33 likes this
Sig by Bama
Donating towards
