Downgrade from 4.4.2 to 4.1.2
17 replies to this topic
#1 marxman3
marxman3
  • 290 posts
Posted 01 June 2014 - 10:27 AM
FOR UNLOCKED BOOTLOADERS ONLY!!!!
Steps:
  1. BE BOOTLOADER UNLOCKED!
  2. Download:
  3. Unzip
  4. Make sure you have the motorola drivers installed
  5. OPEN RSD lite – I’m using 6.1.6 no clue if it works on other versions
  6. Navigate to unzipped folder and load : Modded_XML_for_Downgrade_to_JB.xml
  7. Boot into AP Fastboot
  8. Plug cable that came with phone into the phone then your computer (must be USB 2.0 and I tested on Windows 7)
  9. Press Start
  10. Wait for reboot
  11. Profit and enjoy crack flashing once again
  • dieemg likes this
#2 livinginkaos
Posted 01 June 2014 - 10:42 AM
Doing the impossible one day at a time.......
[b][color=#FF0000][size=4]
From here I used saferoot to gain root and flashed TWRP 2.7.0 and everything works like a charm. This process (may) will wipe your internal SD so prepare accordingly.....
For those on a locked bootloader – no clue if it works for you, but I have a XT907 with a locked bootloader and decided I wasn’t brave enough to try because I didn’t want the hassle of fixing a bricked phone with a locked bootloader. Try if you dare, but ask yourself if you are comfortable and have the knowledge to fix your phone yourself, because I’m not helping you……
First off, if you are unlocked, you don't need to use an exploit for root. Just flash a custom recovery then the supersu.zip in recovery.
It's a good thing you don't try it on your locked bootloader. Won't work, period
Sent from my S-Offed One M8
#3 marxman3
marxman3
  • 290 posts
Posted 01 June 2014 - 11:39 AM
And here is why I don't post often anymore. Thanks for telling me I don't need an exploit when I just mentioned what I did because well, that the way I find easiest. Not like I was the guy putting out Roms for this phone when no one else was, oh wait that was me. Second, you know it won't work because why? You said so? Statements made without proof are utterly meaningless and without value. If on the other hand, you have evidence to offer that works back up your absolute statement it should be included so that your absolute statement has value.
Lastly, your welcome for me sharing something that I spent hours working on.
You can all thank this guy for me being done here. I'llthank him for for all the meaningless words that offered nothing.
#4 marxman3
marxman3
  • 290 posts
Posted 01 June 2014 - 11:55 AM
Quite frakly I'm riled up now because the idea of someone proclaiming something can't be done because they said so is ludicrous. They said you couldn't downgrade from KK to JB, but guess what YOU CAN!
I don't think this will work on a locked bootloader, which is what I clearly stated, however I don't know if it will work and that is the way it deserves to be framed until proven otherwise. Life lesson here folks - only believe wha can be proven not what others believe to be true, even if spoken with complete confidence. Use your minds to thinks critically for yourselves, otherwise you are just another sheep in the herd......Now that's off my chest I'm done
#5 SamuriHL
  • 44,375 posts
Posted 01 June 2014 - 12:26 PM
*I* have experience here and I'm going to weigh in because of your horrid attitude.  You WILL brick downgrading from KK to JB on a locked bootloader.  I know cause I've helped over 50 people in the last couple weeks FIX said problem.  Second, without MODIFYING the FXZ for JB, even unlocked users will not be able to downgrade.  This is why I wrote a tool to create RSD scripts for any FXZ that unlocked users can use to move between versions with ease.  I won't even comment on the root thing.  You claim no one should simply believe what someone else says without proof.  I agree.
#6 cmh714
Posted 01 June 2014 - 12:50 PM
A dev that doesnt know you flash root....hmm
#7 marxman3
marxman3
  • 290 posts
Posted 01 June 2014 - 01:37 PM
Nevrmind, close the thread, I pulled the link since all the mods get so defensive when one of their own gets called out for acting like a know it all then gets called out for being a shlong.
To CMH - can you read or are you just slow?
#8 SamuriHL
  • 44,375 posts
Posted 01 June 2014 - 01:41 PM
Has nothing to do with him being a mod.  He simply wasn't wrong and you freaked out like a child throwing a temper tantrum.
#9 livinginkaos
Posted 01 June 2014 - 01:49 PM
Honestly, no one here claimed to know it all and I will be the first to admit that I don't.  Not even close. I do know, as Sam stated, that downgrading on these locked devices won't work anymore. They did away with that ability many updates ago - in in specific to what you were doing, we've been dealing with many of those who tried and bricked since the recent KK update.  Rather than deal with any more of those, I wanted to dispel that notion immediately.
  • rickw and SamuriHL like this
#10 cmh714
Posted 01 June 2014 - 04:40 PM
Yup, read it just as you wrote it :)
#11 Someolddude
Someolddude
  • 426 posts
Posted 01 June 2014 - 04:54 PM
I got nothing but love for the new update and couldn't wait to get rid of 4.1.2. Doing something as simple as tap on a contact and wait what seemed forever was getting old. Don't want boat just delete what you don't want. I would bet in time recovery will get updated and work fine and stock based custom Roms will emerge. And if they don't it won't bother me because my phone got new life and works great.
#12 SamuriHL
  • 44,375 posts
Posted 01 June 2014 - 05:10 PM
TWRP will be updated as soon as the kernel source is released.
#13 dvj215
dvj215
Posted 04 June 2014 - 01:24 AM
droid razr m xt907 after kitkat 4.4.2 update, not able to activate the data. Also can not add the APN. Do we have any solution or need to go back to JB 4.1.2? Please  help to solve. Thanks in advance.
#14 SamuriHL
  • 44,375 posts
Posted 04 June 2014 - 01:32 AM
Are you unlocked?
#15 dieemg
dieemg
Posted 04 June 2014 - 07:40 PM
hi, i can't download link
#16 livinginkaos
Posted 05 June 2014 - 03:21 AM
Drive has been having some issues. I just tried it and it worked from my location.
  • dieemg likes this
#17 nabeelnav
nabeelnav
Posted 06 June 2014 - 11:50 AM
i reaaly need help where i can download moded xml file please give me link  ... nabeelnav@icloud.com
#18 SamuriHL
  • 44,375 posts
Posted 06 June 2014 - 11:57 AM
Create your own.
