How to downgrade 4.4.2 to 4.12?
11 replies to this topic
#1 Rocco1388
Rocco1388
  • 5 posts
  • Current Device(s):Motorola droid razr m xt907
Posted 27 May 2014 - 05:52 AM
I had updated my (droid razr m xt907) phone last night to 4.4.2 and i dont like it. I was running 4.1.2 before the update and it was great. How do I go about getting it back to 4.1.2? Im not very savy with phones, so the simpler its explained the better. Thank you and please only serious answers.
#2 johnthehillbilly
Posted 27 May 2014 - 06:18 AM
If you have an locked bootloader... You cannot downgrade......
#3 Rocco1388
Rocco1388
  • 5 posts
Posted 27 May 2014 - 06:35 AM
How would I know if it has a locked bootloader? The phone was unlocked and on AT&T but when I upgraded it, it wouldnt read the sim, so i believe it went back to the verizon network.
#4 johnthehillbilly
Posted 27 May 2014 - 06:39 AM
Power off the phone...... Then hold all 3 buttons until the menu comes up..... Use volume down to highlight fastboot..... Then volume up to select it......it will tell you there if its unlocked or locked ...:)
#5 johnthehillbilly
Posted 27 May 2014 - 06:40 AM
Then to boot back normally..... Press power to power off..... Then power on normally
#6 Rocco1388
Rocco1388
  • 5 posts
Posted 27 May 2014 - 07:03 AM
yea it says locked. Thats why i want to downgrade it back to 4.1.2 so it can be unlocked again.
#7 johnthehillbilly
Posted 27 May 2014 - 07:30 AM
It can't be bootloader unlocked ..... Now carrier unlocked may be a different thing..... I would research radiocomm for that.... I'm not sure if can still be done....
#8 SamuriHL
  • 44,375 posts
Posted 27 May 2014 - 07:55 AM
There's a lot of confusion in this thread.  Lemme clear it up.
First, carrier unlocked is different than bootloader unlocked.  I'm also not sure if 4.4.2 can be carrier unlocked or not.
Second, your bootloader is locked so this is an entirely moot discussion if 4.4.2 can't be carrier unlocked.  There is no downgrading a bootloader locked phone to a previous version.
  • johnthehillbilly likes this
#9 Rocco1388
Rocco1388
  • 5 posts
Posted 27 May 2014 - 08:08 AM
Can I boot loader unlock it?
#10 livinginkaos
Posted 27 May 2014 - 08:14 AM
NO
#11 Rocco1388
Rocco1388
  • 5 posts
Posted 27 May 2014 - 08:15 AM
Thanks for all the help guys
  • shane1 likes this
#12 tr3v0r92
tr3v0r92
  • Current Device(s):xt907
Posted 23 September 2014 - 08:18 AM
Just found an awesome tutorial was stuck with a recovery but legit this guide led me through it mad props to Mr. Blue Coat http://mrbluecoat.bl...ml#comment-form
