[Rom] [Gsm] Cm10 Stock Jellybean Nightlies Compiled By X
Posted 29 September 2012 - 12:01 PM
These are development ROMS in hopes to fine tune CM10 for this device.
I just stopped by DroidRzr.com to see how things were going, and it looks as if the GSM users are getting the shaft. Maybe this will help them out a bit.
- Ramdanih and HSD-Pilot like this
Posted 04 October 2012 - 08:50 AM
This device is FULLY supported by the STS-Dev-Team with @dhacker29 as the primary support dev. The XT910 community made sure that he had a device to use for testing, so he went out and got GSM service to use on it. He's doing a bang up job making sure that all of our base ROMs run on this device.
STS-Dev-Team is running builds for the XT910 here:
ROM devs can pick-up the local_manifest.xml for either CM or AOKP in both STOCK or KEXEC flavors from our git at:
CM-STOCK-KERNEL:
CM-KEXEC-KERNEL:
AOKP-STOCK-KERNEL:
AOKP-KEXEC-KERNEL:
Note: We run CM builds on even days and AOKP builds on odd days
Posted 04 October 2012 - 09:35 AM
I think you guys do a great job and in every thread I make sure people know how important what you two do, actually is. Hardware development for a device is what i consider real development, so I hope you don't think I'm knocking on anybody. I was merely referencing the nightly frequency in a time with an unknown schedule.
X
Posted 06 October 2012 - 03:56 PM
Setup the 06 Nightligh right now and added it in my OP in Germany (of course with link to OP and credits )
Soundcloud <> Bassgrow
Posted 15 November 2012 - 10:35 PM
Thanks in advance and thanks for the work!
Posted 18 November 2012 - 04:36 AM
Thanks!
Posted 19 November 2012 - 09:01 PM
Posted 29 November 2012 - 03:29 PM
Sorry for the noob question, but what's the way to flash this ROMs? It's posible do it using CWM installed with Bootstrap?
Safestrap 3 would be the best IMO, so use that unless specified by the developer that you need boot menu or bootstrap
Posted 29 November 2012 - 03:30 PM
Bootstrap or even BootMenu replacing the Stock Motorola Stock... is posible that? Nodoby knows?
Thanks!
Nope, unless scumbag Motorola decides to unlock our boot loaders, which won't be happening any time soon.
- nande likes this
Posted 03 December 2012 - 01:31 AM
