Below is the original post or if you're lazy, .
DISCLAIMER: PLEASE FLASH AT YOUR OWN RISK. ALTHOUGH FASTBOOT IS AVAILABLE, YOU CAN STILL BRICK YOUR DEVICE. YOU WERE WARNED. INSTALL SAFESTRAP BEFORE PROCEEDING. INSTRUCTIONS HERE:
This is the OTA Verizon CDMA Razr version 6.11.748. This is the system partition only (preinstall/data not included. Sorry, no 128mb let's golf or whatever). No kernel/boot.img. This will not update your radio or webtop. It will not change any partition except 'System'.
THIS WILL NOT WORK FOR NON-VERIZON NON-US RAZR's.
Features:Instructions:
- Stock - not debloated - does include bloatware and is NOT de-odexed
- Rooted with Superuser installed
- Works pre or post OTA upgrade - will work with original radio
- Does not wipe data - though I always recommend it
Download:
- Only flash if you are using Safestrap - info can be found here:
- Download and copy to your SD card
- Reboot into Safestrap Recovery
- Make sure safe system is enabled
- (recommended) Factory Reset - Format data and cache
- Install from SD Card
- Restart
MD5: 0284c1b04ddb84ce623286e445d8d0a2
Koush
Hashcode
Motorola
Note: This will not be updated unless there are unknown issues that I have not seen. Anyone else is free to use this as a base for whatever you want. No permission necessary.
