[Rom][Razr-Cdma][Aokp] {Updated-10/03} Scalpel V1.3 {Links Fixed}
#61
Posted 26 September 2012 - 04:54 AM
#62
Posted 26 September 2012 - 04:56 AM
Some people are having luck with MMS using other texting apps (Go SMS, or Handcent), give it a shot.
I tried go SMS last night. Froze Messaging using TiBu and installed go SMS. Still no MMS messages but get SMS just fine. *shrug* Maybe handcent?
Edit: On a side note, does everyone trust these messaging replacements? I mean, theres no tom foolery going on with my personal messages getting sent to other companies now is there?
#63
Posted 26 September 2012 - 05:12 AM
Great rom so far!
#64
Posted 26 September 2012 - 05:27 AM
EDIT: I can use the web and tapatalk and YouTube, but the only issue is with the play store. On 4g nothing will download. But WiFi and 3g work.
#65
Posted 26 September 2012 - 05:46 AM
#66
Posted 26 September 2012 - 06:44 AM
looks like there is some Bluetooth work to be done unless it is just my load.
I can't stay on this rom with Bluetooth not working since I use it all day while I am driving.
I hope there is a fix for it.
#67
Posted 26 September 2012 - 07:14 AM
one issue that i've seen (seems to be on all JB roms for me) is that the gallery and music apps can't see any of the files on my external SD card. however, certain apps (any file explorer + quickpic) can see them. weird. Has anyone else seen issues like this, or do i have an anomalous device?
keep up the great work!
#68
Posted 26 September 2012 - 07:31 AM
#69
Posted 26 September 2012 - 07:42 AM
AS I learned with ES file explorer the change occurred in the naming of the ext SD card. It is named differently then ROM's based off of stock ICS. If you want to go in to the music app and rename the source for music and it will find it. I kind of like it as I have the music on my main partition and on the sd card (backup), this way I don't have duplicates all over the place.
cool, thanks for the info! do you use google play music? also, is that possible in the gallery?
#70
Posted 26 September 2012 - 07:48 AM
#71
Posted 26 September 2012 - 07:53 AM
Just go to Settings>Accounts>Facebook and check sync with contactsI can't get Facebook to sync with my contacts is this normal? I have syncing all setup but in never works.
Great rom so far!
Bluetooth is buggy with EVERY AOKP/CyanogenMod. Its a kernel issue, we have locked bootloaders. outside of kexec, kernel issues will live on forever.I also have a problem with Bluetooth when I'm using it for phone calls.I hear the little beeps when the call starts but the is no audio in the actual call itself.It works fine for listening to music or something else on the phone so that is good just not on phone calls. Another thing is when bluetooth is enabled I can't use the little microphone and speak in the keyboard.
Right the ES file trick fixes a lot of this stuff
#72
Posted 26 September 2012 - 07:59 AM
#73
Sorry, i tried finding it, but not sure what the ES file trick is?
#74
Posted 26 September 2012 - 08:47 AM
#75
Posted 26 September 2012 - 09:11 AM
any idea why the dl for 1.2 is taking 2 hours?
download took about 5 minutes for me. Don't forget to flash gapps again like I did.
#76
Posted 26 September 2012 - 09:18 AM
OK thanksRom Updated with new Blur Data Icons. Sometimes it shows up and doesn't turn blue as is you're not connected. Trust me, you are. I'm working on getting that ironed out, it's a weird bug...more annoying than anything.
#77
Posted 26 September 2012 - 09:34 AM
Thoughts, workarounds?
#78
Posted 26 September 2012 - 09:47 AM
Working fantastic, but has anyone else gone in the stock messaging app and tried to disable the notifications? It causes a FC of the messaging app.
My stock messaging app did the same thing. I just froze it and installed Handcent. now I get my MMS messages too.
- aktrazer likes this
#79
Posted 26 September 2012 - 09:51 AM
Thanks for the workaround on that one!!
#80
Posted 26 September 2012 - 10:10 AM
