[Rom][Razr-Cdma][Aokp] {Updated-10/03} Scalpel V1.3 {Links Fixed}
206 replies to this topic
#21 streetpounder
streetpounder
  • 56 posts
  • LocationHillsboro, OH
Posted 25 September 2012 - 12:58 PM
Running great man. Just came over from the other bajillion builds the past couple of days to try it. Cheers
#22 Guest_purplehaze50o_*
Posted 25 September 2012 - 01:20 PM
I follow the safestrap instructions for this rom but every time i flash this rom after i reboot the splash screen comes up and it the safestrap menu appears and when i click continue the screen just goes black i been waiting 15 min now. is this normal?
#23 tucstwo
  • Google+:tucstwo@gmail.com
Posted 25 September 2012 - 02:12 PM
Not normal at all. You've got some kind of issue. You're on Safestrap 2.11 right? This rom normally boots up pretty quick.
#24 mugsy77
mugsy77
  • 235 posts
  • Current Device(s):RAZR MAXX
Posted 25 September 2012 - 02:26 PM
tucstwo, with AOKP being more stable lately, how does CM10 and AOKP JB differ in performance, battery, functionality?
#25 hd0120
hd0120
  • 65 posts
  • LocationUSA
Posted 25 September 2012 - 02:36 PM
Great rom but somehow, mms doesn't work for me.
#26 james
james
  • 620 posts
  • Locationsouthern cali
  • Current Device(s):LG G2 Verizon
Posted 25 September 2012 - 02:48 PM
did u put the rom on the safe side and did u enable safe system
#27 srzero
srzero
  • 370 posts
  • LocationArlington
Posted 25 September 2012 - 03:13 PM
yes flash doesn't work or taking pictures while recording video.
sorry i commented on the wrong one, i thought this was 1.0..too many new ROMs!!! does the flash work???
Make It Your Own
#28 aarnold0805
aarnold0805
  • 70 posts
  • Twitter:aarnold3273
  • Google+:aarnold0805@gmail.com
  • LocationRiverton, WY.
Posted 25 September 2012 - 03:40 PM
After finally getting this to download I must say this rom is exactly what I've been waiting for. Great job
Sent from my XT912 using Xparent Blue Tapatalk 2
Sent from my 209 KOA RAZR
#29 srzero
srzero
  • 370 posts
  • LocationArlington
Posted 25 September 2012 - 03:56 PM
Will voltage settings ever be enabled on our phones? Any scripts we can use to control that. I have one but it says directory not found.
Make It Your Own
#30 hd0120
hd0120
  • 65 posts
  • LocationUSA
Posted 25 September 2012 - 03:58 PM
Tucstwo, is there a way to make mms work? I love everything else of the rom.
Thanks in advance.
#31 Brad92
Brad92
  • 624 posts
  • LocationTexas
Posted 25 September 2012 - 04:12 PM
Working great. I don't know if its an issue with google now, or the rom, but I asked for directions with my voice and it pulled up the correct location, but when I tried to select directions to it, nothing happened. I even tried pressing and long pressing the map...
#32 Torin_93
Torin_93
  • 137 posts
Posted 25 September 2012 - 04:18 PM
Small bug. Cant get into sms settings.
#33 srzero
srzero
  • 370 posts
  • LocationArlington
Posted 25 September 2012 - 04:23 PM
if you want navigation you need to say "Navigate To" yadayadayada
Make It Your Own
#34 tucstwo
Posted 25 September 2012 - 04:43 PM
Thanks in advance.
Mms is a minor issue in the source that im sure will be ironed out by the STS guys. Once it's fixed, I will update.
Does anyone remember when the iPhone first came out? The original back in 07 and it didn't support mms! For now, if u guys can live with it, find another way to share pictures, there's gotta be 5 I can think of off the top of my head.
Anyway. Yeah.
Sent from my peanut butter and jelly sandwich
#35 tucstwo
Posted 25 September 2012 - 04:44 PM
Big Announcement!
Myself and Bytecode (developer of the Flick rom) are going to be teaming up on the development of this rom. So everyone expect stuff to be coming faster and better! This is awesome, great news.
  • mugsy77, moksha51, natethepaintman and 2 others like this
#36 sgtguthrie
sgtguthrie
  • 135 posts
  • Twitter:@sgtguthrie1
  • LocationMichigan
Posted 25 September 2012 - 04:50 PM
Big Announcement!
That is great news! Thanks for sharing :-) I knew Bytecode had something in the works too, and when projects merge, there's a potential for greatness thru collaboration. I'd guess that's what's on its way :-)
Sent from my DROID Razr Maxx via Tapatalk 2
#37 srzero
srzero
  • 370 posts
  • LocationArlington
Posted 25 September 2012 - 04:52 PM
Wooohooo! Mind is blown! How can it get better....oh BTW go SMS should fix you MMS issues
  • Torin_93 likes this
Make It Your Own
#38 curse3800
curse3800
  • 56 posts
Posted 25 September 2012 - 04:54 PM
is anyone else having a problem playing video?? not sure if its a rom thing or a bad flash.
#39 loonie01
loonie01
  • 190 posts
Posted 25 September 2012 - 04:56 PM
Camera not working for me. Keep getting gallery FC.
#40 thekantorfour
thekantorfour
  • 16 posts
Posted 25 September 2012 - 04:58 PM
Downloading now. Will report back when loaded and running.
Thanks for the work tucstwo!! With the combo of this & flick, it's going to be nothing but great things to come
