[Rom][Razr-Cdma][Aokp] {Updated-10/03} Scalpel V1.3 {Links Fixed}
#181
Posted 07 October 2012 - 06:40 PM
But I did want to throw a bug out there. For some reason my Youtube tries to play videos but the app just tries to load the video and I get the error "there was a problem while playing. Touch to retry." Has anyone else seen this? I apologize if this has already been mentioned.
-AP
#182
Posted 08 October 2012 - 01:08 PM
#183
Posted 10 October 2012 - 09:32 AM
#184
Posted 11 October 2012 - 08:40 AM
#185
Posted 11 October 2012 - 09:08 AM
#186
Posted 11 October 2012 - 03:18 PM
#187
Posted 11 October 2012 - 08:15 PM
But by far this is my favorite JB ROM for my droid razr! Happy flashing!
#188
Posted 11 October 2012 - 08:18 PM
#189
Posted 12 October 2012 - 12:03 AM
#190
Posted 12 October 2012 - 08:23 AM
I'd really like to give this ROM another go but I'm afraid the battery may explode lol.Going back to unsafe side to charge battery and then do another full wipe on the safe end.
EDIT: Since many haven't had these issues I'm assuming it's something on my end... but what it is I haven't a clue.
#191
Posted 12 October 2012 - 02:56 PM
#192
Posted 12 October 2012 - 05:20 PM
#193
Posted 13 October 2012 - 08:42 AM
It's a free download from Google Play. What it does is it updates the SU Binaries. It's more a of precautionary measure to make sure you Linux base is firing on all cylinders. When we change around ROM's, all that gets re-flashed over. And, there's a chance one of the lines of code might be outdated/changed, etc
force that down to your phone. When you first open it up and grant it Root Permission, let it run. What it is doing is looking at all the binary code and determining what is missing. It will ask you if you want to do a smart install or an install. If you don't know what you are doing, click "Smart Install." BusyBox has determined what was missing, and will ONLY install the ones missing. A regular "Install" will let you know pick and choose. Unless you are a Linux guy and know what you are doing, just click Smart Install. It's a pretty sophisticated little piece of software. And, when it updates from the Play Store, have it do another check and do another Smart Install.
After doing the smart install, I cleared my cache and since then virtually all the problems disappeared. I installed Busybox three days ago and have not had any problems with overheating, lag, or charging. My battery life is amazing now too, even with constant use and with CPU sleeper off. I am loving the ROM now. Thanks to all the devs for their hard work. The only thing I have noticed is the flash not working when taking pictures (minor bug).
I hope this helps some of you out there experiencing problems!
- james likes this
#194
Posted 13 October 2012 - 09:47 AM
+ 3When I first flashed the ROM (proper clean install) I was having many of the same problem reported numerous times on this thread. The phone was lagging and overall behaving like crap. I was having overheating issues and a quickly draining battery. Also experienced some bugs with charging where the phone would not charge fully overnight and overheat. All this happened with a normal clockspeed and the default governors. I was super bummed so I started reading through all the other JB ROM's to see if there was a better alternative. I found that the other JB ROM's had similar bugs. Luckily I came across the post of another member (The Doctor) that gave me a priceless pearl: I needed to install Busybox. Here is what he told me:
#195
Posted 13 October 2012 - 11:18 AM
#196
Posted 13 October 2012 - 04:01 PM
#197
Posted 13 October 2012 - 04:56 PM
#198
Posted 13 October 2012 - 05:02 PM
#199
Posted 13 October 2012 - 05:23 PM
how did u get such a good score
#200
Posted 13 October 2012 - 08:54 PM
Also reboot to moto recovery and clear /cache, reboot into safestrap clear /cache/dalvik and fix permissions..
