[Rom][Razr-Cdma][Aokp] {Updated-10/03} Scalpel V1.3 {Links Fixed}
206 replies to this topic
#1 tucstwo
  • Google+:tucstwo@gmail.com
Posted 25 September 2012 - 09:59 AM
*Scalpel v1.3*
AOKP Jelly Bean
(Updated 10/03/2012-See Post #2 for Add-ons, Changelog and Bugs/Oddities)
See Post #3 For Overclocking
Please Also Try Scalpel's Sister Roms:
To help avoid confusion: This is Scalpel AOKP, my other thread is Scalpel CM10. They are similar ROM with 2 completely different bases. If you are currently running Scalpel CM10 and want to switch to Scalpel AOKP, you Must wipe everything or you'll have issues and members have now noticed. Just an FYI!
Scalpel is a Jelly Bean Android Open Kang Project Rom I built from source. It is a work in progress and is the sister rom to Scalpel CM10. Be patient with her. This rom has tons of tweaks and mods that I did to make it my own. I still consider it a beta, but it is daily drivable. You are encouraged to submit bugs, complains, comments or complements in this thread or through PM.
This is a Droidrzr.com EXCLUSIVE. While I encourage you to share this rom, please only post links back to this thread and not directly to my files.
Myself, Droidrzr.com, Cyanogenmod, dhacker, hashcode, and everyone else are not responsible for your phone or what you do with it. Your device, your choices. I made this rom FOR ME and decided to share it with you all. Enjoy
Scalpel is only for those on ICS (.211/.215 or leaks).
You MUST have Safestrap 2.11 installed.
Safestrap 2.11 is the only official install method. I can not support you if you used bootstrap (if you even know how to find bootstrap anymore)
Features of Scalpel
Data on boot
Camera Working
Overclockable
0 Bloat-built from AOSP 100%
Deodexed/Zipaligned
Zipaligned at Boot
Google Now-100% Working
Init.d support-More Scripts Coming
Tons of build.prop tweaks for speed, functionality, fluidity and battery life
kernel logging disabled
Rooted with SU, Busybox and Superuser Pre-installed
All of the AOKP features you've come to love:
Pull down toggles, power menu, 1% battery, theme manager, TOO MANY TO LIST!
Also Includes:
Google Now-Native to Jelly Bean
Google Chrome Browser as a System App
Google Play Music
CPU Sleeper app-Run Twice on first setting
Your choice of Nova or Apex Launcher
Blur data icons (So you can actually see)
All AOSP goodies, dialer, lockscreen, gallery
Also, lightly themed here and there.
What Doesn't Work:
The Typical bluetooth bugs in AOKP or CM
Webtop
HDMI
Screen rotations are wonky
Screenshots need to be cropped in post
MMS settings force close
Some users report having problems sending picture messages. Some have no problems at all. Some can only do it with GoSMS or Handcent. I have no problem, it's hard for me to repair what isn't broken on my phone.
Youtube-Some users are reporting issues using Youtube. I personally have no had any issues so it's hard for me to look into why some are if I can't replicate. The only suggestion I can make: If you are restoring Youtube with an app like Titanium backup and still having problems. Perhaps uninstall the version of Youtube on your phone and then d/l the latest from the Playstore. From what I remember, there is a different version of Youtube made special for Jelly Bean. Other than that..I have very little to offer at this point.
Still to Come:
Overclock Support-coming VERY soon
Init.d scripts
Beats Audio
Maybe 1 day, rotation and screenshot fixes, but I doubt it
We'll see. This is the first release.
Inverted GApps to help with battery life on a blazing fast rom. Sit tight folks.
Credits and Thanks:
dhacker -
Hashcode -
STS-Dev-Team -
All Credit goes to these guy for the source and their countless hours of selfless work bringing us all this base.
Without these guys we would all be very bored crackflashers.
AOKP-
For the awesome tweaks to the AOSP source
Google
For giving us Android to play with
Whirlyeyes -
For Overclock support
For providing me with they System App for Google Chrome
For getting me motivated motivated to build and for hosting
Bytecode aka Leviathan26
For his help with Init.d scripts and with the Settings menu stuff
bigdaddyhicks
24v emericcanx
and countless others who have helped me along the way
www.crackflasher.com for hosting my rom
Droidrzr.com for having such an awesome community for which I can share this with.
Install Destructions: If this is your FIRST time installing Scalpel AOKP
Make sure you are using Safestrap 2.11
Download Scalpel Rom AND GApps from the downloads section below
Put BOTH zips on your SD card
Boot into Safestrap
MAKE A BACK UP
Wipe Data/Factory Reset
Wipe Cache
Under Mounts and Storage: Format System
Under Advanced: Wipe Dalvik Cache
Install Rom
Install GAaps
Reboot
Data Wipe Aren't Necessary If You Are Updating Scalpel, But DON'T forget to flash GAapps!
PATIENCE IS KEY WITH SCALPEL ON INITIAL BOOT
Once you boot for the first time BE PATIENT: Because Scalpel has a boat load in script and gidgets and wizzards going on during first boot, it may appear to be boot looping on you. SIT TIGHT. While I admit the first boot does take a retarded amount of time, it's only the first time that I've noticed. This rom does boot up a whole lot faster than Jekyll does.
YOU MUST WIPE EVERYTHING IF COMING FROM ANYTHING ICS. THIS COULD CAUSE PROBLEMS OF UNIMAGINABLE PROPORTIONS. DON'T TRY TO CHEAT, WIPE!
Updating: EVERYONE SHOULD READ THIS
Scalpel is going to be updated OTA or "over the air". You will no longer have to come to the forum or check up on this thread to see if this rom has any updates. You will find an app in your app drawer called "OTA Updater". (It is also on the Play Store if you somehow lose it.) This app will give you a summary of what the current build of Scalpel you have on your phone is. It will also notify you if there is any updates available or not. This is just like the OTA's you would be getting from Verizon. In OTA Updater's menu there is settings options to refresh check for updates or also have notifications turned on or off. You will now ALWAYS know if this rom is up to date or has been updated and you are due.
Now, if there IS an update you will have the option to download it. I would only do so on WiFi unless you're in a 4G area and have unlimited data as my rom is over 200mb.
The Steps if you have an update:
1. Click download update
2. Once it completes update it will give you the option to install it. DO NOT DO IT! This fancy app was developed for most normal devices that use a traditional recovery and not our Safestrap "bootstrap style" recoveries. Just let the download finish and close it out
3. Reboot your phone
4. When you hit the Safestrap Splashscreen hit Menu to enter recovery.
5. Wipe Cache and under Advanced>Wipe Dalvik Cache
6. Choose install zip from sdcard
7. Choose internal sdcard
8. Browse to /OTAUpdater/downloaded/
9. In this folder you will see the fresh new update you just downloaded, click it to install.
10. Reflash GApps!
11. Once booted up you can move the rom from /mnt/sdcard/OTAUpdater/downloaded/ to you SDcard-ext or where ever your prefer to store your downloaded roms.
12. Profit
You will never need to come back to this op to check and see if you're up to date, you phone will just tell you from now on!
Downloads:
MD5: 9F29882BEFC726C6CAB7FCC6A4864265
MD5: F62CFE4A827202899919FD932D5246D7
Safestrap 2.11:
MD5: 5E24B7710E5A50DB5DE654C2F1D01564
Old Versions:
Scalpel v1.1:
MD5: C3642F5CC3D7DBCE8E31D1267F0188A5
Scalpel v1.2:
MD5: 252B0B001167B7D95704D63BA220E20F
Scalpel v1.2.1:
MD5: 7082B10E3D798DCCD02312342ECDABA8
Screens:
  62.51KB   165 downloads
  81.67KB   196 downloads
  30.5KB   200 downloads
  38.15KB   182 downloads
  37.68KB   148 downloads
  37.52KB   125 downloads
  37.72KB   119 downloads
  16.21KB   84 downloads
It's Never Expected, but everyone loves a fresh brewski! And to show my appreciation, every donation I do receive, I will forward 25% of which to Droidrzr.com every week!
  • mugsy77, mike_augie, Zierm and 5 others like this
#2 tucstwo
Posted 25 September 2012 - 10:09 AM
Changelog:
Scalpel v1.0:
Created...bootlooped.
Scalpel v1.1:
Pulled out some stuff that needs going over. Otherwise, up and running :D
Scalpel v1.2:
added in init.d support, more scripts on the way
Added in all the modules (governors, schedulers, etc) that you loved from Jekyll
See Post 3 for Overclocking Support!
Scalpel v1.2.1:
Fixed force closing in MMS app
Updated Apex Launcher for latest version with no issues
Small other little fixes
Scalpel v1.3: Current
Updated AOKP base
Added Beats-Credit to BigDaddyHicks!
New Boot Animation...Initiating Swagger bitches!!
#3 tucstwo
Setting Clock Speeds for Scalpel AOKP:
All versions of Scalpel AOKP from 1.2 and forward can be over or under clocked. I've also added in a bunch of different modules for you to try to your liking.
In this post are 3 flashable zips. You simply download them, put them on your SD card, boot into Safestrap and flash. Once overclocks, one sets you back to stock clock speed and one underclocks you down to 1000MHz for batter savings. I HIGHLY SUGGEST you put BOTH the overclock AND the stock clock zips on your SD at the same time. While it's somewhat of an anomoly, certain phones just DO NOT LIKE 1325MHz. I don't know why but the God's have spoken and if you phone runs bad at 1325mhz, then sadly you have one of the twitchy ones. Since you should already have the stock clock zip on your SD card, it shouldn't be an issue to return to stock.
Enjoy!
Downloads:
Edited by tucstwo, 16 October 2012 - 04:27 PM.
links fixed
#4 Shinare
Shinare
  • 235 posts
Posted 25 September 2012 - 10:38 AM
First... really? Never been first. heh
LOL
Now I gotta try this ROM out. :)
#5 tucstwo
Screens Up
#6 tucstwo
Posted 25 September 2012 - 10:39 AM
LOL
Don't know where everyone is today!? I personally, I ECSTATIC to have AOKP back on my phone...and working no less
#7 quangtran1
quangtran1
  • 243 posts
Posted 25 September 2012 - 10:41 AM
I'll gladly give it a swirl. Thanks for the ROM.
#8 Shinare
Shinare
  • 235 posts
Downloading now!
#9 tucstwo
Posted 25 September 2012 - 10:47 AM
Enjoy everyone. I am so happy we have guys like STS (dhacker and Hashcode) that bring this base for us to play with. Those guys make it happen.
#10 RAZR2012
RAZR2012
  • 82 posts
  • Google+:antwuan.tws@gmail.com
  • LocationPeoria IL
Posted 25 September 2012 - 11:20 AM
AWESOME! does this have Rom control?
#11 RAZR2012
RAZR2012
  • 82 posts
  • LocationPeoria IL
Posted 25 September 2012 - 11:21 AM
nevermind!!
#12 tucstwo
Posted 25 September 2012 - 11:31 AM
indeedy
#13 aarnold0805
aarnold0805
  • 70 posts
  • Twitter:aarnold3273
  • Google+:aarnold0805@gmail.com
  • LocationRiverton, WY.
Posted 25 September 2012 - 11:39 AM
trying to download now, but it is going really, really slow over a fast wifi connection. Anybody else experience this?
Sent from my 209 KOA RAZR
#14 Shinare
Shinare
  • 235 posts
Posted 25 September 2012 - 11:41 AM
went suprisingly fast for me. :)
#15 aktrazer
aktrazer
    SMod/News Team Leader
  • 537 posts
  • LocationGreensboro, NC
  • Current Device(s):Smasung Galaxy Note 2, ASUS TF700T
Posted 25 September 2012 - 11:46 AM
I'm downloading now, not exactly screaming fast but its going.
#16 bobreiter
bobreiter
  • 6 posts
camera flash still broken?
#17 Torin_93
Torin_93
  • 137 posts
Posted 25 September 2012 - 12:15 PM
This ROM is LEGITTTT!!!! Thanks so much! Havent rebooted yet but im in love so far. Never really played with an AOKP rom before.before today I didnt really know what an AOKP rom was. Its actually exactly what ive been looking for this whole time. One question. Whats with the "swagga baby!" when you click the purple icon in the app drawer?
Oh....Swag toggle. Got it. Funny funny.
Antutu score of 6792. My highest score to date.
#18 kr33py
kr33py
  • LocationOhio
Posted 25 September 2012 - 12:29 PM
Once again, another awesome rom. Thank you so much
#19 srzero
srzero
  • 370 posts
  • LocationArlington
Posted 25 September 2012 - 12:50 PM
yes flash doesn't work or taking pictures while recording video.
Make It Your Own
#20 aarnold0805
aarnold0805
  • 70 posts
Posted 25 September 2012 - 12:56 PM
still can't download. Anybody want to put up a mirror?
