Unable to Install Custom Recovery Kit Kat leak
Best Answer livinginkaos , 14 May 2014 - 06:57 PM
There is a cwm specific for KK. You must use that one. There is no twrp for this build yet.
Sent from my Unlocked Moto G
For UNLOCKED XT926 on 4.4.2, the only working recovery currently is CWM and it specifically has to be THIS ONE.
Go to the full post
7 replies to this topic
#1 karthakon
karthakon
  • 57 posts
  • LocationBoston
  • Current Device(s):Motorola Droid Razr M
Posted 14 May 2014 - 06:53 PM
I've got an unlocked bootloader and I went ahead and reverted to stock and then installed the motorola kitkat.  It looks like there is something in there that reinstalls the stock recovery image.  I've tried to flash CWM and TWRP from fastboot.  The command seems to execute correctly but when I try to boot into recovery I always end up in the Stock Recovery.
Luckily I can use fastboot to fxz back to a previous the old 98.30.1 build and install the a custom recovery, but once I'm on the Official KitKat, I can't do it.
Any one else having that issue?
  • brando likes this
#2 livinginkaos
Posted 14 May 2014 - 06:57 PM   Best Answer
  • karthakon, brando and joshsurvival like this
#3 karthakon
karthakon
  • 57 posts
  • LocationBoston
Posted 14 May 2014 - 07:22 PM
I was trying the cwm 6.0.4.6 that dhacker29 has over on android hosting. Is that right?
#4 karthakon
karthakon
  • 57 posts
  • LocationBoston
Posted 14 May 2014 - 07:55 PM
OK I found the kk-cwm for xt926 6.0.4.8 and that worked.  Just had to boot to recovery after fastboot without booting the system first.
Thanks.
  • livinginkaos likes this
#5 livinginkaos
Posted 15 May 2014 - 04:40 AM
I added the link to my post above for the CWM so if others come across this thread, they have it.  I meant to give you a link last night, but got side tracked.
  • karthakon and neckchop like this
#6 karthakon
karthakon
  • 57 posts
  • LocationBoston
Posted 15 May 2014 - 04:59 AM
Thanks a lot. It helped just to know I needed a build specifically for Kit Kat.
#7 joshsurvival
joshsurvival
  • 6 posts
  • LocationAlabama
  • Current Device(s):Razr HD
Posted 04 August 2014 - 09:27 AM
Thank you for posting this. Finally got a recovery
#8 linkindrew
linkindrew
  • 12 posts
Posted 13 October 2014 - 08:02 AM
can anyone post a link to CWM 6.0.4.8 recovery image for razr m ?
