Razr-M / Atrix-Hd Mod's For Bionic
38 replies to this topic
#1 twinkyz1979
twinkyz1979
    Veteran Flasher
  • 188 posts
  • LocationOhio
  • Current Device(s):Motorola Droid Ultra XT1080
Posted 20 September 2012 - 07:53 PM
Modification download links are located below (You must be on 6.7.232, 6.7.244, 6.7.246, or 6.7.247 Deodexed and be Rooted)
Everything does work on 235, 238, and 242 except i will not be supporting the uninstalling of them. So if you are on any of those use at your own risk.
Steps for installating/uninstalling: (Uninstalling CircleWidgets steps are listed in the other sections below)
  • Must be done using BootStrap
  • Download the file from a link below
  • Place on your phones external sdcard
  • Boot into CWM recovery using BootStrap
  • Select intall ZIP from sdcard
  • Choose ZIP from sdcard
  • Locate the ZIP file and select it
  • When installation is complete choose reboot system now
  • Once you get by the BootAnimation you will see android is upgrading applications (may not always see this don't be scared)
  • Once that is done you will then be able to enjoy your newly installed modifications
I am not responsible if you do something wrong and mess up your phone.
Thanks goes out mattlgroff without his help this could not have been done
Thanks also to Mhous33 for his support.
  • mhous33, T3T3droid and dwhiteley87 like this
#2 twinkyz1979
twinkyz1979
    Veteran Flasher
  • 188 posts
  • LocationOhio
Posted 20 September 2012 - 07:54 PM
RazrM Flasables For The Bionic:
Calendar: (Will work on stock 232, 244, 246, or 247 Deodexed by itself. No need to have the CircleWidgets installed)
Installer
Uninstaller (244 only)
Uninstaller (246 only)
Uninstaller (232 only)
Uninstaller (247 only)
Messaging: (Will work on stock 232, 244, 246, or 247 Deodexed by itself. No need to have the CircleWidgets installed)
Installer
CircleWidgets: (Works on 232, 244, 246, or 247 Deodexed)
(Includes the following apps: Favorite Contacts, HomeScreen, Weather, and CircleWidget) (This removes the stock Weather app)
(You will have 2 Favorite Contact widgets but only 1 works)
(Issue with GPS Quick Setting not working) - Thanks to Mhous33 For pointing that out
Installer
  • After your phone reboot slide to unlock it
  • Check use by default and select the HomeScreen that says com.motorola.homescreen
  • Then you can start applying your widgets and such to your liking
  • To put a widget on your HomeScreen open the app drawer select widgets
  • Push and hold a widget doesn't matter which and put it on your HomeScreen
  • A menu will now pop-up this is where you will select the real widget that you want to place on your HomeScreen
Uninstaller (As of right now must be done manually. I am working trying to get this flashable as well but no luck yet)
  • Go into manage apps
  • Scroll down to HomeScreen (The 1 you want will be around 16-17mb which it will say at the bottom)
  • Select it and clear defaults
  • Clear data
  • Now uninstall it
  • Now scroll up to Favorite Contacts
  • Select it
  • Clear Data
  • Uninstall it
  • Now scroll up to Circles
  • Select it
  • Clear data
  • Uninstall it
  • Now scroll down to Weather
  • Select it
  • Clear data
  • Uninstall it
  • Now you need to download my Stock-Weather-Installer and use the steps listed in the OP for doing installations if you really want the WeatherWidget back.
Camera: (Will work on stock 232, 244, 246, or 247 Deodexed by itself. No need to have the CircleWidgets installed)
Installer
Stock WeatherWidget:
Installer (244 only)
Installer (246 only)
Installer (232 only)
Installer (247 only)
  • johnlgalt, T3T3droid and dwhiteley87 like this
#3 twinkyz1979
twinkyz1979
    Veteran Flasher
  • 188 posts
  • LocationOhio
AtrixHD Flasables For The Bionic:
Installer
Installer
Installer
  • Slide to unlock your phone
  • Clear data
  • Now uninstall it
  • Select it
  • Clear Data
  • Uninstall it
  • Select it
  • Clear data
  • Uninstall it
  • Select it
  • Clear data
  • Uninstall it
Installer
QuickView: (Works on 232, 244, 246, or 247 Deodexed but only works with the AtrixHD HomeScreen included in the CircleWidgets) - Thank you Mhous33 for sharing this working feature
Installer
Uinstaller
  • T3T3droid and dwhiteley87 like this
#4 twinkyz1979
twinkyz1979
    Veteran Flasher
  • 188 posts
  • LocationOhio
Posted 20 September 2012 - 08:41 PM
RazrM MOD's Screen Shots
Home Screen Setup--------------Favorite Contacts-------------Calendar Widget-----------Circle Widget
  310.97KB   42 downloads
  294.67KB   45 downloads
  198.09KB   63 downloads
  396.33KB   66 downloads
Quick Settings--------------------App Drawer--------------------Text Messaging-----------------Text Messaging
  348.06KB   59 downloads
  47.79KB   47 downloads
  31.49KB   41 downloads
  104.67KB   49 downloads
Camer-------------------------------Video Camera
  24.34KB   43 downloads
  22.62KB   34 downloads
The Messaging icon shown is RazrM and the Camera icon shown is RazrM in the pics above.
#5 twinkyz1979
twinkyz1979
    Veteran Flasher
  • 188 posts
  • LocationOhio
Posted 20 September 2012 - 08:54 PM
AtrixHD MOD's Screen Shots
Circle Widget----------------------Calendar Widget---------------Favorite Contacts---------Home Screen Setup
  395.92KB   36 downloads
  198.48KB   37 downloads
  294.93KB   31 downloads
  310.98KB   26 downloads
Text Messaging---------------------Text Messaging------------------App Drawer------------------Video Camera
  27.92KB   28 downloads
  103.98KB   31 downloads
  146.1KB   30 downloads
  26.52KB   27 downloads
Camera-----------------------------QuickView Widgets(I don't have stock browser so this pic is missing one)
  28.72KB   31 downloads
  407.89KB   27 downloads
The Messaging icon shown is AtrixHD and the Camera icon shown is AtrixHD in the pics above.
#6 johnlgalt
johnlgalt
    Antidisestablishmentarianist
  • 7,296 posts
  • Location3rd Rock
Posted 20 September 2012 - 08:59 PM
Thanks, Twinkz! Any chance on screenies so I can see what the diff is between my stock ICS and these?
#7 twinkyz1979
twinkyz1979
    Veteran Flasher
  • 188 posts
  • LocationOhio
Posted 20 September 2012 - 09:02 PM
working on it once i get the links up :)
I haven't played with the messengers all that much but haven't noticed a real difference other than the icon color for atrixhd is blue and the razrm is green. the homescreen, which is part of the criclewidgets, on the razrm if you swipe left pulls up a settings menu which the atrixhd doesn't have. the circlewidgets include favorite contacts, homescreen, weather, and of course the circlewidgets. the calendars of both the atrixhd and razrm seem to be the same as far as the widget can show the monthly calendar or your upcoming events where the stock ICS one just shows upcoming events.
  • johnlgalt likes this
#8 johnlgalt
johnlgalt
  • 7,296 posts
  • Location3rd Rock
Posted 20 September 2012 - 09:09 PM
That gives me a little idea. Still have no idea what the hell a circle widget is though lol....I'll Google it....
#9 mhous33
mhous33
  • 480 posts
Posted 21 September 2012 - 10:16 AM
Nice work! Just a few notes...
I don't know about the calendar, camera, and messaging apps as I haven't tried them, but the homescreens and widgets can be installed just like any other side loaded app, tap to install.
For the weather app, you need to rename the existing one with a ". bak" extension and reboot before installing the new one.
No need to bother with the new favorites widget on stock ics as the existing favorites widget works fine with the new homescreens.
On razr m homescreen, quick settings gps toggle doesn't work, which is why I use the atrix hd homescreen. It also supports the quickview widget, which the razr m doesn't.
Also all of these should work on any ics build, odexed or deodexed.
  • twinkyz1979 and johnlgalt like this
#10 twinkyz1979
twinkyz1979
    Veteran Flasher
  • 188 posts
  • LocationOhio
Posted 21 September 2012 - 10:25 AM
I find things get used more often than not if people can just simply flash something rather than try the manual method. Also thanks for the heads up on the quickview and the gps issue. I for one am not even sure what quickview is but i am about to find out. I also leave my gps on so i never tried the quick setting for it.
#11 mhous33
mhous33
  • 480 posts
Posted 21 September 2012 - 11:14 AM
quickview widgets are the browser, dialer, email, messaging, and people widgets that look like the standard icons, but you can swipe up on the little arrows on the side to quickly view recent activity. also when you have missed calls and/or messages, the widgets display little tabs to show number of missed items. overall, i think they're more useful than the quick settings panel on the razr m homescreen, personal preference of course :)
*edit*
They are a little of a pain to use as they don't show up in the widget drawer like other widgets. to acess them, start by choosing a widget that is in the widgets drawer, like the circles widget. then when the widgets list pops up, you'll see them in the list.
#12 twinkyz1979
twinkyz1979
    Veteran Flasher
  • 188 posts
  • LocationOhio
Posted 21 September 2012 - 12:11 PM
*edit*
I just tried QuickView for the RazrM and it didn't like it lol might have to look at it later on and see if i can't find out what the problem is but haven't got time right now. By the way is there anymore info you have on these? Sounds like you have messed around with this a bit more than i have as far as trying things out.
I just tried to install it manually and it told me it will replace another app. I wonder if for some reason there is some stock ICS app that has to be removed for the RazrM version to work?
Never mind I made another mistake not paying attention.
Edited by twinkyz1979, 21 September 2012 - 12:29 PM.
#13 mhous33
mhous33
  • 480 posts
Posted 21 September 2012 - 12:53 PM
quickview doesn't work on the razr m homescreen, only works on the atrix hd homescreen. not sure why razr m has quickview widget but doesn't work. so gotta decide between razr m quick settings or atrix hd quickview widgets. everything else, circles widget, favorites, weather, work on either one. that's about it as far as info i've gathered on these apps.
  • twinkyz1979 and Brandroid1984 like this
#14 twinkyz1979
twinkyz1979
    Veteran Flasher
  • 188 posts
  • LocationOhio
Posted 21 September 2012 - 01:07 PM
ok lol had to try it for myself. Anyhow the camera, messaging, and calendar all work on stock deodexed ICS don't have to have the HomScreens or any of that for them to work and i must say i love the RazrM camera and calendar.
-Edit-
I love the CircleWidget as well but if people don't want to try it or don't like it but want one of the other 3 app's mentioned above don't be afraid to have a go with them as they will work on their own.
  • johnlgalt and Brandroid1984 like this
#15 mhous33
mhous33
  • 480 posts
Posted 21 September 2012 - 01:44 PM
curious, what's better about the razr m calendar and camera?
#16 twinkyz1979
twinkyz1979
    Veteran Flasher
  • 188 posts
  • LocationOhio
Posted 21 September 2012 - 03:00 PM
I like the way the camera looks and i think it runs smoother and quicker. As for the calendar i don't think there is a difference it's just i am running the RazrM circlewidgets so i just want to run everything else RazrM. I mean the only thing i see not working correctly is the gps quick settings that you mentioned but i like the fact of everything else being right there so i don't have to use so many screens cause i have widgets everywhere just to do system stuff without going into the actual settings menu.
  • mhous33 likes this
#17 mhous33
mhous33
  • 480 posts
Posted 21 September 2012 - 03:15 PM
yeah i was really stoked about the razr m homescreen until i found out the gps toggle didn't work. i'd use it anyway though if i didn't want to use quickview. also use widgetsoid to create wifi, bluetooth, gps, and data toggles in my dropdown menu, works pretty well...
#18 Halloween240
Halloween240
  • 83 posts
  • Twitter:Twitter.com/Halloween240
  • Google+:Halloween240
  • LocationCharlottesville, VA
Posted 22 September 2012 - 05:46 PM
This is really freaking pimp, thanks
#19 johnlgalt
johnlgalt
  • 7,296 posts
  • Location3rd Rock
Posted 23 September 2012 - 05:53 PM
I may have to try this. Of course, though, I also need to see about getting GNow and Google Ears on my Infinity...managing 2 devices (full time) is a hella lot harder than a single device, especially since I'm still toying with the D1 too!
#20 kaikea
kaikea
  • 15 posts
  • LocationHawaii
Posted 24 September 2012 - 12:19 AM
Thanks for this awesome mod. And just a heads up for anyone interested. I was able to flash the circles widget onto my phone and I'm running .232 deodexed.
