Rooted xt926 trying to unroot (SWDL.txt attached)
3 replies to this topic
#1 xhddtdroid
xhddtdroid
Posted 24 April 2014 - 01:28 PM
I'm trying to use HouseofMoto to roll back to VRZ_XT926_9.8.1Q-94-1_CFC.
I forgot to enable the usb debugging before I initially run the RSD (after I got locked out, I found houseofmoto)
sorry if I didn't provide enough information for your kind help. attached is the SWDL.txt
  • Attached File  SWDL.txt   15.31KB   9 downloads
#2 SamuriHL
  • 44,535 posts
Posted 24 April 2014 - 01:38 PM
04/24/14 15:02:35  ERROR: 15/27 flash boot "boot.img" -> USB error occurred while reading/writing. - on device ID 0.
04/24/14 15:02:35  [Device ID: 0] 15/27 flash boot "boot.img" -> USB error occurred while reading/writing.
04/24/14 15:02:35  ERROR: Failed flashing process. - on device ID 0.
Yea that's not good.  Means your USB connection isn't stable.  Usual advice applies here....Make sure it's not a USB 3 port, ensure you are using the latest Motorola USB drivers, make sure you're using the original OEM USB cable that came with the phone (yes, it matters).
  • meandg5 likes this
#3 xhddtdroid
xhddtdroid
Posted 24 April 2014 - 01:49 PM
THANKS A LOT! I will try w/ other computer later tonight.
#4 xhddtdroid
xhddtdroid
Posted 25 April 2014 - 08:48 AM
Report back: HouseofMoto run smoothly and got my phone back to breathing. it turned out that my previously used computer is bad w/ the usb ports.
thanks you for making such a great tool!
  • SamuriHL, cmh714 and meandg5 like this
