I wanted to share this with the brave few of you... this recovery has a few major flaws. I am not responsible for anything you do to your device. Your phone has a locked bootloader unfortunately and true recovery permanently is not possible without unlocking it... however we CAN tether boot the CWM.
Flaws:
- Backups do NOT work correctly. CWM stock backs up boot.img, a partition we cannot actually get into because of the strange system of Huawei on this device and others in the past. If someone figures out to mod CWM to NOT backup boot.img, this flaw should be fixed.
- Random reboots. A HUGE flaw. This can lead to bricked devices at the moment since backups do not work. Highly unrecommended that you flash files bigger than 50MB to be "safe" but I am not sure even then. I have a few times flashed 180MB file, but 8 times out of 10 tries it did not fully flash before the random reboot. When the phone reboots in CWM, it goes back to normal boot. Not sure exactly what causes this to fix it, but it is very annoying.
- You MUST be at a computer to launch this CWM. Since it does not actually flash onto the device, it instead boots the CWM from the fastboot menu. (Thus the Tethered title) This can be fixed with an unlocked bootloader.
Windows:
http://174.132.194.6...nix_Windows.zip
Linux:
http://174.132.194.6...eonix_Linux.zip
Mac:
http://174.132.194.6...Pheonix_Mac.zip
