Posted 15 April 2014 - 04:52 AM
001.JPG 83.66KB 9 downloads
002.JPG 92.95KB 9 downloads
Albeit fairly straightforward, this project does require a few adapters and some hacking/soldering. I ordered an active hdmi-vga adapter since the monitor only has vga input. Also, I ordered a solderable breadboard to create a new circuit board with power headers. I plan to reuse most of the headers from the original PCB.
003.JPG 93.42KB 9 downloads
004.JPG 81.23KB 9 downloads
I plan to use some of the extra space in the case to create storage for things like jumper wires and extra leds. It also has a shelf that should allow me to attach a breadboard and leave projects pieced together while being protected by the case.
005.JPG 48.25KB 9 downloads
006.JPG 121.63KB 9 downloads
007.JPG 106.42KB 10 downloads
As I start to put the case back together and get everything working, I'll post the results with some more pictures.
**Update 4/24/14
After unsuccessfully desoldering some headers from the old PCB, I have decided to just solder the power adapters and switch directly to the PSU. I'll be working on that tonight and will post results then. Below are a few shots of the power switch (salvaged from the receipt printer) and the shelf that will hold the bread board and cables.
IMG_20140424_090303.jpg 76.62KB 8 downloads
IMG_20140424_090321.jpg 83.26KB 7 downloads
IMG_20140424_090337.jpg 137.13KB 6 downloads
**UPDATE 4/26/14**
Although possibly borking my USB hub in the process, I have successfully gotten the Pi powered by the PSU and configured for VGA output. Now to clean up some wiring and put the case back together. Pics below.
IMG_20140425_082454.jpg 94.47KB 6 downloads
IMG_20140426_104317.jpg 109.3KB 6 downloads
IMG_20140426_104118.jpg 94.16KB 6 downloads
- johnlgalt, johnthehillbilly, soocold and 1 other like this
Posted 15 April 2014 - 12:12 PM
N⁴
Posted 15 April 2014 - 02:05 PM
Great idea to use an older POS for this. It ought to be interesting, to say the least....
- soocold likes this
Posted 26 April 2014 - 08:06 AM
Posted 05 May 2014 - 05:41 AM
I am curious what are you going to use the pi for with your brewing? I have seen the BrewPi project that uses the Pi for fermentation temperature control.
- s3inks likes this
Posted 05 May 2014 - 04:06 PM
I've seen that project as well. In fact, I've gotten some inspiration there. My plan is to have an arduino running as PID controller on the hot liquor tank. This will ensure accurate strike and sparge water. Initally i wanted to go all gas, but that proved to be cost prohibitive for a side project so the system will be combi gas/electric with the capability to go all gas or all electric. I plan to incorporate a rims system which will recirculate the wort from the mash run through a coil in the hot liquor tank allowing the arduino to again maintain temperature control. The Pi will act as an interface and master control for the arduino, collecting and storing/serving data. I'm still in the planning phase of how to control the transfer pumps. Ideally the pi would actuate another arduino that would control flow rate.
Posted 06 May 2014 - 06:58 AM
It's awesome that another member is a follow brewer. I personally have got into the hobby about 9 months ago and really enjoy making meads.
I have been thinking creating something similar to the BrewPi project. I want to make a fermenter/clearing system. I would like to have fermenter part of the system maintain temp and also stir the must through out fermentation (meads tend to ferment better when they are stirred through out the fermentation process) then have the system move the must from the primary to the secondary and filtering out the lee's and yeast during the transfer. The clearing chamber would then keep the mead at a lower temp to help it to clear then once clearing is finished have it transfer through a final filter to a bottling station.
If you haven't figured it out one of the differences between meads and beer is that meads don't have a mash to be boiled. Just put the ingredients into the primary and let them ferment.
