About:
This is a _really_ low cost astrophotography device implementation, simple to build and not intended to do complicated (i.e. long exposition, tracking) photography. My main inspiration to build it was my nephew
Just love this using a Telescope that's under $50. Now that's inexpensive with accessories
http://tinyurl.com/ndayc7q telescope on Amazon Prime
Intro build @ http://blog.dragon-tortuga.net/?p=1263
Not sure but if this works would double it's magnification:
With some servo's and a bit of hacking it should be possible to auto track your target.
Check out this build. It does use a more advanced telescope but that could be an upgrade for later.
http://www.raspberry...e-camera-board/
The following is just an example. Note it uses a $700 Telescope and a PC. Just here for a reference. http://www.celestron...rized-telescope.
We even have a node-telescope-server
https://www.npmjs.or...elescope-server
