1073 replies to this topic
#161 Kebob
Kebob
    Dev
  • 246 posts
  • Google+:kebob.rzr@gmail.com
  • LocationWashington
Posted 10 September 2012 - 01:57 PM
THE POSTED IS NOT A FIX. It is a non softkey rom
  • crbdenver likes this
#162 Ednica78
Ednica78
  • 7 posts
Posted 10 September 2012 - 02:04 PM
Kebob first of all Thanks for this rom.
I'm having problems with the game asphalt 7 is to laggy, if I install this rom could improve gaming on my razr maxx?
#163 AngelRyux
AngelRyux
  • 45 posts
Posted 10 September 2012 - 02:05 PM
It does have sound.
Nvm lol it does have sound but i had to clear cache or fix permissions one of the two..
#164 runcieb
runcieb
  • 24 posts
  • Twitter:runcieb
  • LocationTennessee
  • Current Device(s):HTC Droid DNA
Posted 10 September 2012 - 02:09 PM
Is there a possibility of throwing on an options key in the softkeys? Either to the right or left?
Sent from my DROID RAZR using Xparent ICS Tapatalk 2
#165 Marukka562
Marukka562
  • 10 posts
Posted 10 September 2012 - 04:07 PM
Holy $#!+basket I love this ROM... This is by far superior to anything else I've tried to day except maybe some of the older GB stuff but for ICS... takes the cake. Minor things will be worked out I'm sure but my hats off to you cats. Matt, 10X better than the beta I flashed forever ago... Can I get some more control now on the updates? You know a little "woot woot" here and a little "woot woot" there and the ability to add a "menu" soft key would be fanfriggintastic!
#166 Kebob
Kebob
    Dev
  • 246 posts
Posted 10 September 2012 - 04:13 PM
@Ednica It will fix it most likely. It may also help to have a OC
A extra softkey might be possible. Ill look into it
#167 jonniec34
jonniec34
  • LocationOver Yonder
Posted 10 September 2012 - 04:17 PM
This is the only ROM I like :( I can't stand the soft keys though. I'll keep using stock until you guys get rid of them. I'm looking forward for when you do!
Well nevermind. The non softkey version just did it. This is amazing
#168 Kebob
Kebob
    Dev
  • 246 posts
Posted 10 September 2012 - 04:21 PM
Jonniec34 they have been removed in another version 1 page back, enjoy
  • PillClinton, steven.rn and jonniec34 like this
#169 neur0tk
neur0tk
  • 123 posts
  • Twitter:neur0tk
  • Google+:neur0tk1@gmail.com
  • LocationLatrobe, Pennsylvania
Posted 10 September 2012 - 04:27 PM
Swipe to the left for quick settings plz :)
  • RaSuRaDoRa and moksha51 like this
#170 steven.rn
steven.rn
  • 11 posts
  • LocationNortheast Ohio
Posted 10 September 2012 - 04:33 PM
Kebob, many many thanks for this ROM implementation. I'm really enjoying this.... I'm sure a lot of others are too! Mucho appreciado.
#171 RaSuRaDoRa
RaSuRaDoRa
  • 132 posts
Posted 10 September 2012 - 05:44 PM
this rom would be even better with a trasparent status bar and transparent bar for the soft keys and the latest version of google play. mine doesnt update to the newest. other than that this rom is one of the best with soft keys because the main keys are actually disabled lol good job :) andd i forgot to add the swipe left for quick settings. :P
Edited by RaSuRaDoRa, 10 September 2012 - 05:46 PM.
#172 Chuckleb0ne
Chuckleb0ne
  • 262 posts
Posted 10 September 2012 - 07:18 PM
Where is the rom without the soft keys?
#173 greentail
greentail
Posted 10 September 2012 - 07:23 PM
How long should the first boot up take? Phone has stuck in the boot up screen for about 15 minutes. This is my first ROM, running 2.15 leak. DROID HD non soft v1.02.
#174 willjohnson
willjohnson
  • 32 posts
  • LocationSavannah, Georgia
Posted 10 September 2012 - 07:42 PM
Is anyone else having trouble with the lap dock. i get constant systemui force closes no matter what, tried multiple whipes, and installs. Everything in the rom works flawlessly until i try to use the lapdock. Any help would be appreciated.
#175 adamjmtz
adamjmtz
    Internet Searcher
  • 357 posts
  • LocationAthens, GA
Posted 10 September 2012 - 08:03 PM
Between this and Kebob saying there isn't any difference between the non-softkey version and ArcticHD, I take it the only difference is the boot-up animation? It is kind of confusing having both versions being the same instead of just saying if you don't want soft keys then run Arctic. Not complaining, just wondering why. I was going to switch and try this one out but it sounds like there is no point in running this if you are already on Arctic HD. Am I missing something else that is different?
Thanks again for the great roms!
Arctic HD will eventually be themed to fit its name, but I prefer the stock look so I switched to DroidHD nonsoft because I'll be doing it eventually anyway.
#176 nsaechao
nsaechao
  • 48 posts
Posted 10 September 2012 - 09:36 PM
I was having the same issue in Arctic HD (Im still on Arctic HD)- I extracted the welcomewebtop.apk from simplex rom - and replace with the one in Arctic HD (system/app) one and set the permission and hit install - booted to ss recovery wipe cache and dalvik - reboot - not sure what it did but it seem to do the trick on my rzr. see if it would work for yours
#177 Kebob
Kebob
    Dev
  • 246 posts
Posted 10 September 2012 - 09:40 PM
Ok ill fix that apk also in version 1.1.0 thanks for the heads up
#178 djspy
djspy
  • 24 posts
  • Twitter:djspy
  • Google+:DJ SPY
Posted 10 September 2012 - 11:30 PM
I haven't rooted in a while and never installed safestrap recovery before so would it be possible to post the video you had again? I preferto see what eeverything should look like if done right. Quick question, if I want to go back to completely stock not rooted can I justboot into AP Fast boot, hit option one (1) on the RAZR Utility and be done with it? Safestrap and everything else will be gone?
Thanks for this ROM guys! Looks pretty sweet. Can't wait to try out Google now.
#179 djspy
djspy
  • 24 posts
  • Twitter:djspy
  • Google+:DJ SPY
Posted 10 September 2012 - 11:31 PM
One last question, after I download the file should I move it to the root of my SD Card?
#180 djspy
djspy
  • 24 posts
  • Twitter:djspy
  • Google+:DJ SPY
Posted 11 September 2012 - 02:05 AM
i have read all pages on this thread and could not find an anwer.. does this rom have the new live icons? i really like them and would be awesome if they are there.
