#121
Posted 09 September 2012 - 02:09 PM
#122
Posted 09 September 2012 - 02:16 PM
#123
Posted 09 September 2012 - 03:24 PM
Thanks!
Here is a widget that has the circle clock
F.T.S.
#124
Posted 09 September 2012 - 03:40 PM
#125
Posted 09 September 2012 - 04:10 PM
#126
Posted 09 September 2012 - 04:19 PM
#127
Posted 09 September 2012 - 06:11 PM
#128
Posted 09 September 2012 - 06:52 PM
Ah, I always end up forgetting that. I'll update that now.
EDIT: New DL link for it is on OTA Update Center, but will not notifiy you as an update if you are on 1.02 already.
We will be posting this in its own thread "soon"
I'm on Arctic HD right now, but want to switch to Droid HD (without softkeys). Should I wait for the new thread, or just go ahead with this link? Basically, I'm wondering if you're working on changes and will post it to the new thread when they're done. Thanks!
#129
Posted 09 September 2012 - 07:09 PM
Installed 1.02. Very nice, smooth good looking ROM.
But I'm getting FC's on Corporate email, Calendar, and Google search.
Is Corporate email (Exchange) working for others? I need it for work so that's a deal-breaker for me.
Any help is appreciated.
Thanks!
was going to jump from Arctic (non HD) and wondering about this Exchange Q. i also need this for work.
thx!
Droid Razr Maxx | SS3.6 AviatorBlur / CM11 N10 | RastaKat Xoom Wifi | Big Part 4.3 N7 | MultiROM / RastaKat OG Droid | kfazz CM10 port
#130
Posted 09 September 2012 - 07:12 PM
Go ahead and use the link. If we update it you will get a notification.I'm on Arctic HD right now, but want to switch to Droid HD (without softkeys). Should I wait for the new thread, or just go ahead with this link? Basically, I'm wondering if you're working on changes and will post it to the new thread when they're done. Thanks!
- adamjmtz likes this
#131
Posted 09 September 2012 - 07:17 PM
#132
Posted 09 September 2012 - 07:36 PM
#133
Posted 09 September 2012 - 07:50 PM
No need to wipe, and the OTA does the same to me, well kinda, after checking for updates it takes about 5 minutes to show it, then it says downloading, never does.Noob question: Do i have to wipe anything when i upgrade or can i just directly install over previous version? thanks in advance. Also OTA isnt working for me i select where it is says available update but nothing happens am i doing something wrong?
#134
Posted 09 September 2012 - 08:08 PM
Anybody try NFL Mobile on this rom yet? And while I'm asking does any of the devlopers know which verizon system apps one would need for this to work. Thanks for all the awesome Roms.
Tried it earlier this evening, was a no-go for me. I'm pretty sure at least one requirement is Verizon Login, as I disabled / froze that when installing avast! Anti-Theft on a previous ROM since it complained about the SMS Priority that Verizon Login. Next time I tried NFL Mobile I got symptoms similar to what I got tonight (Error: Services are temporarily unavailable ... Error Code -303), and once I made the connection between that and Verizon Login and unfroze / re-enabled it, NFL Mobile started working again. Thing is, this ROM provides Verizon Login and it is not disabled, so it must be missing something else.
#135
Posted 09 September 2012 - 08:13 PM
Thanks.
#136
Posted 09 September 2012 - 08:14 PM
1) Motorola Dock modes (both for Car Dock and HD Dock).
2) Visual Voicemail (I'm aware of alternatives; I like Visual Voicemail and would prefer to keep using it).
3) Motorola Music Player - I'm willing to give Apollo a shot, as it looks nice, but doesn't seem to have a landscape mode when in a car dock. If someone could make that work, I'd be willing to keep evaluating Apollo.
Devs, don't get me wrong, I think this ROM is by far what Motorola / Verizon should have shipped for ICS in the first place. The items I mentioned above would simply be icing on the cake for me.
#137
Posted 09 September 2012 - 08:51 PM
- dwz07 likes this
#138
Posted 09 September 2012 - 09:05 PM
Love this ROM! Smooth, looks good, no issues(except nfl app). Love you can get updates straight from setting's.
Another question, I'm on .215, anyone tried all three kernels ? Any idea which works best with this ROM ?
Thanks guys, keep it up!
#139
Posted 09 September 2012 - 09:15 PM
#140
Posted 09 September 2012 - 10:52 PM
215 works best kernal wise. I use SIO and eother hotplugx or pegususq
What do u set your min cpu to?
