1073 replies to this topic
#1061 Memnoch73
  • 5,016 posts
  • Current Device(s):Pixel 3XL
Posted 11 March 2013 - 09:22 AM
Is there going to be an updated version of this great Rom for the OTA JB kernel do you know.
This was my go to everyday Rom, however when I went back to unrooted stock (I know, why would anyone do that) my phone updated to JB and of course the Rom won't work for me now.
So just wondering if something is coming along, or if I need to begin looking around.
Check
out man.. It will get you back up and going on this Rom. Not sure if this will see an update.
#1062 droid1177
droid1177
  • 49 posts
  • LocationGa, USA
Posted 11 March 2013 - 09:30 AM
You can also look into Matt's Rom for JB
#1063 jmbode
jmbode
  • 23 posts
Posted 11 March 2013 - 09:53 AM
I read all that... not exactly sure if I can dial boot from ota jb back to ics which is needed for this Rom
#1064 jmbode
jmbode
  • 23 posts
What's the name of Matt's jb Rom?
#1065 mattlgroff
mattlgroff
    The Dark Knight
  • 2,298 posts
Posted 11 March 2013 - 09:55 AM
BatakangROM
#1066 jmbode
jmbode
  • 23 posts
Posted 12 March 2013 - 06:04 AM
THANK YOU GUYS ... currently running BatakangROM and its practically the same as I was running here ... so I got my daily rom back!
  • mattlgroff likes this
#1067 Ethan82691
Ethan82691
  • 113 posts
  • Google+:blindside7x@gmail.com
  • LocationIdaho
Posted 20 March 2013 - 07:35 PM
I run into an extremely strange issue while running this rom. I was driving down the road and decided to take a picture. i than went into my photos and was going to look at the picture. Phone kinda froze up and all the images in the Gallary were black. The phone than shut off. I rebooted and got stuck at safestrap screen. Several reboots i decided to go back into the safestrap, and i found that it pretty much wiped the Rom slot. Nothing was there. I tried to reboot and it said no OS was found. So nothing was installed on the slot. So i had to go back to stock and start over by creating a new rom slot. Has this ever happened to anyone??? Any idea what would cause this?
Ethan82691
#1068 delk24
delk24
  • Current Device(s):razr maxx
Posted 20 April 2013 - 10:07 AM
ROM works great with the exception of the Calendar. It constantly closes and does not sync. I have wiped cache and dalvick cache and installed ROM again but no luck. Any ideas?
#1069 Radio2006
Radio2006
  • 7 posts
  • Current Device(s):Droid RAZR Maxx
Posted 24 April 2013 - 11:08 AM
Is anyone having issues with Google Play syncing with the website?
#1070 viperac39
viperac39
Posted 25 June 2013 - 05:57 PM
problem trying to download OTA update. everytime i try go to settings and check for update the settings FC. i cant even try to download the update to follow the rest of the directions on updating.
#1071 droid1177
droid1177
  • 49 posts
  • LocationGa, USA
Posted 25 June 2013 - 06:01 PM
What version are you using? If it's 1.2 then that's the latest anyway.
#1072 viperac39
viperac39
Posted 25 June 2013 - 06:10 PM
im on 4.0.4 trying to get to 1.2
#1073 droid1177
droid1177
  • 49 posts
  • LocationGa, USA
Posted 25 June 2013 - 06:13 PM
So you ROM version is 1.1 now?
#1074 viperac39
viperac39
Posted 25 June 2013 - 06:41 PM
android version:
4.0.4
Build number:
DROID HD HK 1.2
Build Date:
Sep 13 2012
Edit: okay i was able to upgrade to 4.1.2 and root using the droid razr utility (windows). thanks anyhow
