Not a maxx and same apps i have always used.i get > 24hrs easy with moderate use. HD 1.1 (Razr Maxx)
#1041
Posted 08 December 2012 - 04:10 AM
#1042
Posted 09 December 2012 - 03:29 PM
Thank you
#1043
Posted 09 December 2012 - 04:30 PM
I am looking for a Droid Razr rom that has the Cm9 theme options. So that if i download a cm9 theme from google play store, i can hit menu > Themes> and select a cm9 theme. Does this Rom support that? If not does someone know one that does?
Thank you
Any CM or AOKP based ROM will have this. Its called theme Chooser it only work on those roms unfortunately.
#1044
Posted 09 December 2012 - 05:34 PM
#1045
Posted 09 December 2012 - 06:27 PM
#1046
Posted 10 December 2012 - 01:20 AM
I'm not seeing any battery issues with this rom. I am getting 36 hours on light to moderate use.So wait theres a battery issue with the newest update?
Sent from my Droid Razr Maxx using Tapatalk2.
#1047
Posted 10 December 2012 - 03:56 AM
#1048
Posted 10 December 2012 - 05:41 AM
Sent from my DROID HD 1.1 RAZR using Tapatalk 2
#1049
Posted 10 December 2012 - 05:54 AM
This rom really does rock it needs nothing,but screenshot (power menu) would be great thanks guys for making this rom
It's power and volume down...works on both versions...
#1050
Posted 11 December 2012 - 09:42 AM
Btw, checking for update in settings fc's settings.
Sent from my toilet (probably) using Tapatalk 2.
Same here, Droid HD Settings -> Check for Update force closes.
Everything else works great so far, been running 1.2 since 12/4 without any issues. I haven't experienced unusual battery drain, I loose about 2% per hour with the screen off.
Great job on this rom!
#1051
Posted 11 December 2012 - 09:45 AM
#1052
Posted 11 December 2012 - 01:24 PM
For those still having problems with Google Now, I fixed mine by doing what someone else said in the artic thread. Uninstall googlesearch with TB, reboot into safestrap and clear caches. This brought Google Now back to working order. Now if it was only updated to the newest version:rolleyes:
I did this now i lost Google now. How do i get it back?
#1053
Posted 11 December 2012 - 04:38 PM
Anyone else having this issue?
I was able to get to youtube after repeatedly pressing the back button a couple of times...
#1054
Posted 11 December 2012 - 05:45 PM
Ok, my fellow members. All of a sudden today. Youtube tells me that I need "Google Play Services" When I try to download it fails installation, saying...Incompatible with other application(s) using the same shared user Id.....
Googles problem, has nothing to do with the ROM.
#1055
Posted 12 December 2012 - 11:08 PM
- BADDINOROX99 likes this
#1056
Posted 13 December 2012 - 05:44 PM
#1057
Posted 13 December 2012 - 11:30 PM
#1058
Posted 27 February 2013 - 04:07 AM
#1059
Posted 07 March 2013 - 11:02 AM
#1060
Posted 11 March 2013 - 09:16 AM
This was my go to everyday Rom, however when I went back to unrooted stock (I know, why would anyone do that) my phone updated to JB and of course the Rom won't work for me now.
So just wondering if something is coming along, or if I need to begin looking around.
