#921
Posted 04 November 2012 - 07:02 PM
#922
Posted 05 November 2012 - 07:08 AM
#923
Posted 05 November 2012 - 03:45 PM
Yeah, but I was wondering if that is the same as the actual calendar, if it syncs correctly, and if it replaces calendar already on there, don't want to mess it up or make it unstable or something... lol it is pretty good right now, just that little thing. Thanks, though.Google Calendar by Google in the Play Store will give you a white calendar.
#924
Posted 05 November 2012 - 04:07 PM
#925
Posted 05 November 2012 - 05:39 PM
#926
Posted 06 November 2012 - 05:16 AM
Under Safestrap v2, it defaults to root and I can use adb remount.
Any ideas on when/if this will get corrected?
Thanks!
- fito_l4 likes this
#927
Posted 07 November 2012 - 10:47 PM
Tell it those pants make it look fat.
Too funny, lol
#928
Posted 07 November 2012 - 11:04 PM
#929
Posted 07 November 2012 - 11:05 PM
#930
Posted 08 November 2012 - 12:07 AM
#931
Posted 08 November 2012 - 06:48 AM
#932
Posted 08 November 2012 - 07:30 AM
Why can't I update gmail and YouTube? Says incompatible update, uninstall and re download.
I am getting an update available for google search (Google Now) but it says not compatible for my device... Any way to get that apk or something, or not? I just hate seeing an update and not being able to get it. lol
Get TitaniumBackup so you can go and uninstall both apps. Then reboot into Safestrap recovery and wipe the cache and dalvik. Reboot back into your phone and then install them clean from Play Store and all should be good.
#933
Posted 08 November 2012 - 11:50 AM
#934
Posted 08 November 2012 - 10:07 PM
Sent from my portable telecommunications box
#935
Posted 09 November 2012 - 01:38 PM
Does anyone know if the 4.2 camera and gallery will work on this rom? If so any tutorial to get it working? lol
Yes it works. but it's not fully functional. You can't apply effects to the photos (it FC's) and Photosphere doesn't work. I think it's a lack of hardware here. Most features work.
#936
Posted 09 November 2012 - 05:53 PM
it's because this is a JB Google Now ported to ICS. won't be able to update to latest JB version and the ICS port devs have moved on (search XDA for the dev thread)
Droid Razr Maxx | SS3.6 AviatorBlur / CM11 N10 | RastaKat Xoom Wifi | Big Part 4.3 N7 | MultiROM / RastaKat OG Droid | kfazz CM10 port
#937
Posted 12 November 2012 - 06:44 PM
#938
Posted 14 November 2012 - 11:06 PM
#939
Posted 15 November 2012 - 03:41 AM
Thanks for your hard work. I truly like this rom apart from small glitches. Looking forward to flash a newer version, if there's any chance of adding international languages, that would be fantastic,too.
#940
Posted 15 November 2012 - 03:46 AM
